Topic "BUG : Assertion failure - version 3 build 174"
gaspoda
I'm sorry , that this is not English. Sad
Assertion failure D:\Martin\knihovny.....\ToolBarPanel.pas , line 446
Od upgradu na WinSCP 3 jsem několikrt program spustil bez jakchkoli problmů , Teďka se mi po spěnm nalogovn na server na SSH konzoly zobrazil dialog Assertion failure... . odkliknul jsem ho , zobrazil jsem ho znova , pak jetě jednou (celkem 3x) a pak program normlně, bez chyby běel.
Same problem here with the new v3.3.0 build 177.
Exacte same error and line number when connecting to a host on the first use of the program.
This on my Win98SE machine.
The failure does not show up anymore after the first time connecting.
After displaying this error notice it displays several error dialogs like:
"Access violation at address 656E6150. Read of address 656E6150".
I think I stay with 2.x for a while until this bug is resolved.
Well, if it happes only on first use of the program, I would recommend you to use 3.3, 2.x has another bugs (see history), which I consider to be more serious.
