Topic "Login from saved session will not open an explorrer window"
stevegoodsell
This is getting progressively worse so I hope you can help.
I have a bunch of saved sessions. If I try and login to one of these sessions the initial dialog goes away after displaying the console type window showing it making a connection, but the explorer window does not show.
This also happens when manually entering connection details actually..
This does not happen every time, and in most cases if I do it say 10-15 times in a row it finally opens a connection.
I see that WinSCP is still running even though the window did not display.
Quite annoying when I need to get onto a box in a hurry.
Any ideas?
Steve
stevegoodsell
Here is a "debug 2" log file that I grapped whilst experiencing the problem:
---LOGFILE:
. 2008-09-11 08:41:56.109 --------------------------------------------------------------------------
. 2008-09-11 08:41:56.125 WinSCP Version 4.1.6 (Build 412) (OS 5.1.2600 Service Pack 3)
. 2008-09-11 08:41:56.125 Login time: 11 September 2008 08:41:56
. 2008-09-11 08:41:56.125 --------------------------------------------------------------------------
. 2008-09-11 08:41:56.141 Session name: HS VM FIXGW - HSADMIN
. 2008-09-11 08:41:56.141 Host name: vrtstfixh01.hs.local (Port: 22)
. 2008-09-11 08:41:56.141 User name: hsadmin (Password: Yes, Key file: No)
. 2008-09-11 08:41:56.156 Tunnel: No
. 2008-09-11 08:41:56.156 Transfer Protocol: SFTP (SCP)
. 2008-09-11 08:41:56.156 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2008-09-11 08:41:56.172 Proxy: none
. 2008-09-11 08:41:56.172 SSH protocol version: 2; Compression: No
. 2008-09-11 08:41:56.172 Bypass authentication: No
. 2008-09-11 08:41:56.172 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2008-09-11 08:41:56.188 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2008-09-11 08:41:56.188 SSH Bugs: -,-,-,-,-,-,-,-
. 2008-09-11 08:41:56.188 SFTP Bugs: -,-
. 2008-09-11 08:41:56.188 Return code variable: Autodetect; Lookup user groups: Yes
. 2008-09-11 08:41:56.203 Shell: default, EOL: 0
. 2008-09-11 08:41:56.203 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2008-09-11 08:41:56.203 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2008-09-11 08:41:56.219 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2008-09-11 08:41:56.219 Cache directory changes: Yes, Permanent: Yes
. 2008-09-11 08:41:56.219 DST mode: 1
. 2008-09-11 08:41:56.219 --------------------------------------------------------------------------
. 2008-09-11 08:41:56.250 Looking up host "vrtstfixh01.hs.local"
. 2008-09-11 08:41:56.250 Connecting to XX.XX.XX.XX port 22
. 2008-09-11 08:41:56.250 Selecting events 63 for socket 664
. 2008-09-11 08:41:56.266 Waiting for the server to continue with the initialisation
. 2008-09-11 08:41:56.266 Looking for incoming data
. 2008-09-11 08:41:56.266 Looking for network events
. 2008-09-11 08:41:56.281 Detected network event
. 2008-09-11 08:41:56.281 Enumerating network events for socket 664
. 2008-09-11 08:41:56.281 Enumerated 19 network events making 19 cumulative events for socket 664
. 2008-09-11 08:41:56.281 Handling network read event on socket 664 with error 0
. 2008-09-11 08:41:56.297 Server version: SSH-2.0-OpenSSH_3.9p1
. 2008-09-11 08:41:56.297 We claim version: SSH-2.0-WinSCP_release_4.1.6
. 2008-09-11 08:41:56.297 SSPI: acquired credentials for: goodses@IGI.IG.LOCAL
. 2008-09-11 08:41:56.313 Constructed service principal name 'host/vrtstfixh01.hs.local'
. 2008-09-11 08:41:56.313 GSSKEX disabled: The specified target is unknown or unreachable
. 2008-09-11 08:41:56.313 Using SSH protocol version 2
. 2008-09-11 08:41:56.328 Handling network write event on socket 664 with error 0
. 2008-09-11 08:41:56.328 Handling network connect event on socket 664 with error 0
. 2008-09-11 08:41:56.328 Waiting for the server to continue with the initialisation
. 2008-09-11 08:41:56.328 Looking for incoming data
. 2008-09-11 08:41:56.344 Looking for network events
. 2008-09-11 08:41:56.344 Detected network event
. 2008-09-11 08:41:56.344 Enumerating network events for socket 664
. 2008-09-11 08:41:56.359 Enumerated 1 network events making 1 cumulative events for socket 664
. 2008-09-11 08:41:56.359 Handling network read event on socket 664 with error 0
. 2008-09-11 08:41:56.359 Doing Diffie-Hellman group exchange
. 2008-09-11 08:41:56.359 Waiting for the server to continue with the initialisation
. 2008-09-11 08:41:56.375 Looking for incoming data
. 2008-09-11 08:41:56.375 Looking for network events
. 2008-09-11 08:41:56.375 Detected network event
. 2008-09-11 08:41:56.375 Enumerating network events for socket 664
. 2008-09-11 08:41:56.391 Enumerated 1 network events making 1 cumulative events for socket 664
. 2008-09-11 08:41:56.391 Handling network read event on socket 664 with error 0
. 2008-09-11 08:41:56.391 Doing Diffie-Hellman key exchange with hash SHA-1
. 2008-09-11 08:41:56.453 Waiting for the server to continue with the initialisation
. 2008-09-11 08:41:56.453 Looking for incoming data
. 2008-09-11 08:41:56.469 Looking for network events
. 2008-09-11 08:41:56.469 Detected network event
. 2008-09-11 08:41:56.469 Enumerating network events for socket 664
. 2008-09-11 08:41:56.484 Enumerated 1 network events making 1 cumulative events for socket 664
. 2008-09-11 08:41:56.484 Handling network read event on socket 664 with error 0
. 2008-09-11 08:41:56.547 Selecting events 63 for socket 664
. 2008-09-11 08:41:56.547 Host key fingerprint is:
. 2008-09-11 08:41:56.563 ssh-rsa 1024 08:81:da:8d:d5:fe:eb:c2:94:64:58:04:37:a2:1c:de
. 2008-09-11 08:41:56.563 Initialised AES-256 CBC client->server encryption
. 2008-09-11 08:41:56.563 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-09-11 08:41:56.563 Initialised AES-256 CBC server->client encryption
. 2008-09-11 08:41:56.578 Initialised HMAC-SHA1 server->client MAC algorithm
. 2008-09-11 08:41:56.578 Waiting for the server to continue with the initialisation
. 2008-09-11 08:41:56.578 Looking for incoming data
. 2008-09-11 08:41:56.594 Looking for network events
. 2008-09-11 08:41:56.609 Detected network event
. 2008-09-11 08:41:56.609 Enumerating network events for socket 664
. 2008-09-11 08:41:56.609 Enumerated 1 network events making 1 cumulative events for socket 664
. 2008-09-11 08:41:56.609 Handling network read event on socket 664 with error 0
! 2008-09-11 08:41:56.625 Using username "hsadmin".
. 2008-09-11 08:41:56.625 Waiting for the server to continue with the initialisation
. 2008-09-11 08:41:56.625 Looking for incoming data
. 2008-09-11 08:41:56.641 Looking for network events
. 2008-09-11 08:41:56.641 Detected network event
. 2008-09-11 08:41:56.641 Enumerating network events for socket 664
. 2008-09-11 08:41:56.641 Enumerated 1 network events making 1 cumulative events for socket 664
. 2008-09-11 08:41:56.656 Handling network read event on socket 664 with error 0
. 2008-09-11 08:41:56.656 Prompt (6, SSH password, , &Password: )
. 2008-09-11 08:41:56.656 Using stored password.
. 2008-09-11 08:41:56.672 Sent password
. 2008-09-11 08:41:56.672 Waiting for the server to continue with the initialisation
. 2008-09-11 08:41:56.672 Looking for incoming data
. 2008-09-11 08:41:56.672 Looking for network events
. 2008-09-11 08:41:56.703 Detected network event
. 2008-09-11 08:41:56.703 Enumerating network events for socket 664
. 2008-09-11 08:41:56.703 Enumerated 1 network events making 1 cumulative events for socket 664
. 2008-09-11 08:41:56.719 Handling network read event on socket 664 with error 0
. 2008-09-11 08:41:56.719 Access granted
. 2008-09-11 08:41:56.719 Waiting for the server to continue with the initialisation
. 2008-09-11 08:41:56.719 Looking for incoming data
. 2008-09-11 08:41:56.734 Looking for network events
. 2008-09-11 08:41:56.734 Detected network event
. 2008-09-11 08:41:56.734 Enumerating network events for socket 664
. 2008-09-11 08:41:56.750 Enumerated 1 network events making 1 cumulative events for socket 664
. 2008-09-11 08:41:56.750 Handling network read event on socket 664 with error 0
. 2008-09-11 08:41:56.750 Opened channel for session
. 2008-09-11 08:41:56.750 Waiting for the server to continue with the initialisation
. 2008-09-11 08:41:56.766 Looking for incoming data
. 2008-09-11 08:41:56.766 Looking for network events
. 2008-09-11 08:41:56.766 Detected network event
. 2008-09-11 08:41:56.781 Enumerating network events for socket 664
. 2008-09-11 08:41:56.781 Enumerated 1 network events making 1 cumulative events for socket 664
. 2008-09-11 08:41:56.781 Handling network read event on socket 664 with error 0
. 2008-09-11 08:41:56.781 Started a shell/command
. 2008-09-11 08:41:56.797 --------------------------------------------------------------------------
. 2008-09-11 08:41:56.797 Using SFTP protocol.
. 2008-09-11 08:41:56.797 Doing startup conversation with host.
> 2008-09-11 08:41:56.813 Type: SSH_FXP_INIT, Size: 5, Number: -1
> 2008-09-11 08:41:56.813 01,00,00,00,05,
. 2008-09-11 08:41:56.813 Sent 9 bytes
. 2008-09-11 08:41:56.813 There are 0 bytes remaining in the send buffer
. 2008-09-11 08:41:56.828 Looking for network events
. 2008-09-11 08:41:56.828 Detected network event
. 2008-09-11 08:41:56.828 Enumerating network events for socket 664
. 2008-09-11 08:41:56.844 Enumerated 1 network events making 1 cumulative events for socket 664
. 2008-09-11 08:41:56.844 Handling network read event on socket 664 with error 0
. 2008-09-11 08:41:56.844 Received 9 bytes (0)
. 2008-09-11 08:41:56.859 Read 4 bytes (5 pending)
. 2008-09-11 08:41:56.859 Read 5 bytes (0 pending)
< 2008-09-11 08:41:56.859 Type: SSH_FXP_VERSION, Size: 5, Number: -1
< 2008-09-11 08:41:56.859 02,00,00,00,03,
. 2008-09-11 08:41:56.875 SFTP version 3 negotiated.
. 2008-09-11 08:41:56.875 We believe the server has signed timestamps bug
. 2008-09-11 08:41:56.875 We will use UTF-8 strings for status messages only
. 2008-09-11 08:41:56.891 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2008-09-11 08:41:56.891 Getting current directory name.
. 2008-09-11 08:41:56.891 Getting real path for '.'
> 2008-09-11 08:41:56.891 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
> 2008-09-11 08:41:56.906 10,00,00,00,10,00,00,00,01,2E,
. 2008-09-11 08:41:56.906 Sent 14 bytes
. 2008-09-11 08:41:56.906 There are 0 bytes remaining in the send buffer
. 2008-09-11 08:41:56.922 Looking for network events
. 2008-09-11 08:41:56.922 Detected network event
. 2008-09-11 08:41:56.922 Enumerating network events for socket 664
. 2008-09-11 08:41:56.922 Enumerated 1 network events making 1 cumulative events for socket 664
. 2008-09-11 08:41:56.938 Handling network read event on socket 664 with error 0
. 2008-09-11 08:41:56.938 Received 65 bytes (0)
. 2008-09-11 08:41:56.938 Read 4 bytes (61 pending)
. 2008-09-11 08:41:56.953 Read 61 bytes (0 pending)
< 2008-09-11 08:41:56.953 Type: SSH_FXP_NAME, Size: 61, Number: 16
< 2008-09-11 08:41:56.953 68,00,00,00,10,00,00,00,01,00,00,00,14,2F,65,78,70,6F,72,74,2F,68,6F,6D,65,
< 2008-09-11 08:41:56.969 2F,68,73,61,64,6D,69,6E,00,00,00,14,2F,65,78,70,6F,72,74,2F,68,6F,6D,65,2F,
< 2008-09-11 08:41:56.969 68,73,61,64,6D,69,6E,00,00,00,00,
. 2008-09-11 08:41:56.969 Real path is '/export/home/hsadmin'
. 2008-09-11 08:41:56.969 Listing directory "/export/home/hsadmin".
> 2008-09-11 08:41:56.984 Type: SSH_FXP_OPENDIR, Size: 29, Number: 267
> 2008-09-11 08:41:56.984 0B,00,00,01,0B,00,00,00,14,2F,65,78,70,6F,72,74,2F,68,6F,6D,65,2F,68,73,61,
> 2008-09-11 08:41:56.984 64,6D,69,6E,
. 2008-09-11 08:41:57.000 Sent 33 bytes
. 2008-09-11 08:41:57.000 There are 0 bytes remaining in the send buffer
. 2008-09-11 08:41:57.000 Looking for network events
. 2008-09-11 08:41:57.000 Detected network event
. 2008-09-11 08:41:57.016 Enumerating network events for socket 664
. 2008-09-11 08:41:57.016 Enumerated 1 network events making 1 cumulative events for socket 664
. 2008-09-11 08:41:57.016 Handling network read event on socket 664 with error 0
. 2008-09-11 08:41:57.031 Received 17 bytes (0)
. 2008-09-11 08:41:57.031 Read 4 bytes (13 pending)
. 2008-09-11 08:41:57.031 Read 13 bytes (0 pending)
< 2008-09-11 08:41:57.031 Type: SSH_FXP_HANDLE, Size: 13, Number: 267
< 2008-09-11 08:41:57.047 66,00,00,01,0B,00,00,00,04,00,00,00,00,
> 2008-09-11 08:41:57.047 Type: SSH_FXP_READDIR, Size: 13, Number: 524
> 2008-09-11 08:41:57.047 0C,00,00,02,0C,00,00,00,04,00,00,00,00,
. 2008-09-11 08:41:57.047 Sent 17 bytes
. 2008-09-11 08:41:57.063 There are 0 bytes remaining in the send buffer
. 2008-09-11 08:41:57.063 Looking for network events
. 2008-09-11 08:41:57.063 Detected network event
. 2008-09-11 08:41:57.078 Enumerating network events for socket 664
. 2008-09-11 08:41:57.078 Enumerated 1 network events making 1 cumulative events for socket 664
. 2008-09-11 08:41:57.078 Handling network read event on socket 664 with error 0
. 2008-09-11 08:41:57.078 Received 1375 bytes (0)
. 2008-09-11 08:41:57.094 Read 4 bytes (1371 pending)
. 2008-09-11 08:41:57.094 Read 1371 bytes (0 pending)
< 2008-09-11 08:41:57.094 Type: SSH_FXP_NAME, Size: 1371, Number: 524
< 2008-09-11 08:41:57.109 68,00,00,02,0C,00,00,00,0C,00,00,00,0D,2E,62,61,73,68,5F,68,69,73,74,6F,72,
< 2008-09-11 08:41:57.109 79,00,00,00,45,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,20,31,20,68,73,61,64,
< 2008-09-11 08:41:57.109 6D,69,6E,20,20,64,65,76,20,20,20,20,20,20,20,20,20,31,30,35,33,39,20,53,65,
< 2008-09-11 08:41:57.125 70,20,31,30,20,31,38,3A,34,39,20,2E,62,61,73,68,5F,68,69,73,74,6F,72,79,00,
< 2008-09-11 08:41:57.125 00,00,0F,00,00,00,00,00,00,29,2B,00,00,1B,A7,00,00,1B,59,00,00,81,80,48,C8,
< 2008-09-11 08:41:57.125 08,C0,48,C8,08,C0,00,00,00,0B,2E,58,61,75,74,68,6F,72,69,74,79,00,00,00,43,
< 2008-09-11 08:41:57.125 2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,20,31,20,68,73,61,64,6D,69,6E,20,20,
< 2008-09-11 08:41:57.141 64,65,76,20,20,20,20,20,20,20,20,20,20,20,31,38,30,20,53,65,70,20,20,39,20,
< 2008-09-11 08:41:57.141 31,32,3A,31,38,20,2E,58,61,75,74,68,6F,72,69,74,79,00,00,00,0F,00,00,00,00,
< 2008-09-11 08:41:57.141 00,00,00,B4,00,00,1B,A7,00,00,1B,59,00,00,81,80,48,C6,5B,92,48,C6,5B,92,00,
< 2008-09-11 08:41:57.156 00,00,06,2E,65,6D,61,63,73,00,00,00,3E,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,
< 2008-09-11 08:41:57.156 20,20,31,20,68,73,61,64,6D,69,6E,20,20,64,65,76,20,20,20,20,20,20,20,20,20,
< 2008-09-11 08:41:57.156 20,20,33,38,33,20,46,65,62,20,31,34,20,20,32,30,30,38,20,2E,65,6D,61,63,73,
< 2008-09-11 08:41:57.172 00,00,00,0F,00,00,00,00,00,00,01,7F,00,00,1B,A7,00,00,1B,59,00,00,81,A4,48,
< 2008-09-11 08:41:57.172 84,68,0B,47,B4,67,FC,00,00,00,07,2E,62,61,73,68,72,63,00,00,00,3F,2D,72,77,
< 2008-09-11 08:41:57.172 2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,68,73,61,64,6D,69,6E,20,20,64,65,76,
< 2008-09-11 08:41:57.172 20,20,20,20,20,20,20,20,20,20,20,35,38,39,20,41,75,67,20,32,38,20,31,31,3A,
< 2008-09-11 08:41:57.188 33,39,20,2E,62,61,73,68,72,63,00,00,00,0F,00,00,00,00,00,00,02,4D,00,00,1B,
< 2008-09-11 08:41:57.188 A7,00,00,1B,59,00,00,81,A4,48,C8,CB,C4,48,B6,80,78,00,00,00,02,2E,2E,00,00,
< 2008-09-11 08:41:57.188 00,3A,64,72,77,78,72,2D,78,72,2D,78,20,20,20,31,31,20,72,6F,6F,74,20,20,20,
< 2008-09-11 08:41:57.203 20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,34,30,39,36,20,41,75,67,20,32,
< 2008-09-11 08:41:57.203 39,20,31,37,3A,31,39,20,2E,2E,00,00,00,0F,00,00,00,00,00,00,10,00,00,00,00,
< 2008-09-11 08:41:57.203 00,00,00,00,00,00,00,41,ED,48,C8,8A,2E,48,B8,21,93,00,00,00,0D,2E,62,61,73,
< 2008-09-11 08:41:57.203 68,5F,70,72,6F,66,69,6C,65,00,00,00,45,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,
< 2008-09-11 08:41:57.219 20,20,31,20,68,73,61,64,6D,69,6E,20,20,64,65,76,20,20,20,20,20,20,20,20,20,
< 2008-09-11 08:41:57.219 20,20,31,39,31,20,46,65,62,20,31,34,20,20,32,30,30,38,20,2E,62,61,73,68,5F,
< 2008-09-11 08:41:57.219 70,72,6F,66,69,6C,65,00,00,00,0F,00,00,00,00,00,00,00,BF,00,00,1B,A7,00,00,
< 2008-09-11 08:41:57.234 1B,59,00,00,81,A4,48,C7,ED,A3,47,B4,67,FC,00,00,00,0C,6D,6D,63,6C,69,65,6E,
< 2008-09-11 08:41:57.234 74,2E,69,6E,69,00,00,00,44,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,
< 2008-09-11 08:41:57.250 68,73,61,64,6D,69,6E,20,20,64,65,76,20,20,20,20,20,20,20,20,20,20,31,34,32,
< 2008-09-11 08:41:57.250 39,20,4A,75,6C,20,33,30,20,31,36,3A,34,37,20,6D,6D,63,6C,69,65,6E,74,2E,69,
< 2008-09-11 08:41:57.250 6E,69,00,00,00,0F,00,00,00,00,00,00,05,95,00,00,1B,A7,00,00,1B,59,00,00,81,
< 2008-09-11 08:41:57.250 A4,48,90,8D,1F,48,90,8D,1F,00,00,00,01,2E,00,00,00,39,64,72,77,78,2D,2D,2D,
< 2008-09-11 08:41:57.266 2D,2D,2D,20,20,20,20,34,20,68,73,61,64,6D,69,6E,20,20,64,65,76,20,20,20,20,
< 2008-09-11 08:41:57.266 20,20,20,20,20,20,34,30,39,36,20,53,65,70,20,20,39,20,31,32,3A,31,38,20,2E,
< 2008-09-11 08:41:57.266 00,00,00,0F,00,00,00,00,00,00,10,00,00,00,1B,A7,00,00,1B,59,00,00,41,C0,48,
< 2008-09-11 08:41:57.281 C8,CB,C5,48,C6,5B,92,00,00,00,10,62,72,6F,6B,65,72,63,6C,69,65,6E,74,2E,69,
< 2008-09-11 08:41:57.281 6E,69,00,00,00,48,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,68,73,61,
< 2008-09-11 08:41:57.297 64,6D,69,6E,20,20,64,65,76,20,20,20,20,20,20,20,20,20,20,31,34,33,30,20,4A,
< 2008-09-11 08:41:57.297 75,6C,20,33,30,20,31,36,3A,34,37,20,62,72,6F,6B,65,72,63,6C,69,65,6E,74,2E,
< 2008-09-11 08:41:57.297 69,6E,69,00,00,00,0F,00,00,00,00,00,00,05,96,00,00,1B,A7,00,00,1B,59,00,00,
< 2008-09-11 08:41:57.313 81,A4,48,90,8D,1F,48,90,8D,1F,00,00,00,08,2E,65,6D,61,63,73,2E,64,00,00,00,
< 2008-09-11 08:41:57.313 40,64,72,77,78,72,2D,78,72,2D,78,20,20,20,20,33,20,68,73,61,64,6D,69,6E,20,
< 2008-09-11 08:41:57.313 20,64,65,76,20,20,20,20,20,20,20,20,20,20,34,30,39,36,20,4A,75,6C,20,32,31,
< 2008-09-11 08:41:57.328 20,31,31,3A,34,35,20,2E,65,6D,61,63,73,2E,64,00,00,00,0F,00,00,00,00,00,00,
< 2008-09-11 08:41:57.328 10,00,00,00,1B,A7,00,00,1B,59,00,00,41,ED,48,C8,8A,2E,48,84,68,C0,00,00,00,
< 2008-09-11 08:41:57.328 0C,2E,62,61,73,68,5F,6C,6F,67,6F,75,74,00,00,00,44,2D,72,77,2D,72,2D,2D,72,
< 2008-09-11 08:41:57.344 2D,2D,20,20,20,20,31,20,68,73,61,64,6D,69,6E,20,20,64,65,76,20,20,20,20,20,
< 2008-09-11 08:41:57.344 20,20,20,20,20,20,20,32,34,20,46,65,62,20,31,34,20,20,32,30,30,38,20,2E,62,
< 2008-09-11 08:41:57.344 61,73,68,5F,6C,6F,67,6F,75,74,00,00,00,0F,00,00,00,00,00,00,00,18,00,00,1B,
< 2008-09-11 08:41:57.359 A7,00,00,1B,59,00,00,81,A4,48,C8,08,C0,47,B4,67,FC,00,00,00,04,2E,73,73,68,
< 2008-09-11 08:41:57.359 00,00,00,3C,64,72,77,78,2D,2D,2D,2D,2D,2D,20,20,20,20,32,20,68,73,61,64,6D,
< 2008-09-11 08:41:57.375 69,6E,20,20,64,65,76,20,20,20,20,20,20,20,20,20,20,34,30,39,36,20,41,75,67,
< 2008-09-11 08:41:57.375 20,32,38,20,31,31,3A,33,37,20,2E,73,73,68,00,00,00,0F,00,00,00,00,00,00,10,
< 2008-09-11 08:41:57.375 00,00,00,1B,A7,00,00,1B,59,00,00,41,C0,48,C8,8A,2E,48,B6,7F,CF,
> 2008-09-11 08:41:57.375 Type: SSH_FXP_READDIR, Size: 13, Number: 780
> 2008-09-11 08:41:57.391 0C,00,00,03,0C,00,00,00,04,00,00,00,00,
. 2008-09-11 08:41:57.391 Sent 17 bytes
. 2008-09-11 08:41:57.391 There are 0 bytes remaining in the send buffer
. 2008-09-11 08:41:57.406 Looking for network events
. 2008-09-11 08:41:57.406 Detected network event
. 2008-09-11 08:41:57.406 Enumerating network events for socket 664
. 2008-09-11 08:41:57.422 Enumerated 1 network events making 1 cumulative events for socket 664
. 2008-09-11 08:41:57.422 Handling network read event on socket 664 with error 0
. 2008-09-11 08:41:57.422 Received 32 bytes (0)
. 2008-09-11 08:41:57.438 Read file '.bash_history' from listing
. 2008-09-11 08:41:57.438 Read file '.Xauthority' from listing
. 2008-09-11 08:41:57.438 Read file '.emacs' from listing
. 2008-09-11 08:41:57.453 Read file '.bashrc' from listing
. 2008-09-11 08:41:57.453 Read file '..' from listing
. 2008-09-11 08:41:57.453 Read file '.bash_profile' from listing
. 2008-09-11 08:41:57.469 Read file 'mmclient.ini' from listing
. 2008-09-11 08:41:57.469 Read file '.' from listing
. 2008-09-11 08:41:57.469 Read file 'brokerclient.ini' from listing
. 2008-09-11 08:41:57.484 Read file '.emacs.d' from listing
. 2008-09-11 08:41:57.484 Read file '.bash_logout' from listing
. 2008-09-11 08:41:57.484 Read file '.ssh' from listing
. 2008-09-11 08:41:57.484 Read 4 bytes (28 pending)
. 2008-09-11 08:41:57.500 Read 28 bytes (0 pending)
< 2008-09-11 08:41:57.500 Type: SSH_FXP_STATUS, Size: 28, Number: 780
< 2008-09-11 08:41:57.500 65,00,00,03,0C,00,00,00,01,00,00,00,0B,45,6E,64,20,6F,66,20,66,69,6C,65,00,
< 2008-09-11 08:41:57.516 00,00,00,
< 2008-09-11 08:41:57.516 Status/error code: 1
> 2008-09-11 08:41:57.516 Type: SSH_FXP_CLOSE, Size: 13, Number: 1028
> 2008-09-11 08:41:57.516 04,00,00,04,04,00,00,00,04,00,00,00,00,
. 2008-09-11 08:41:57.531 Sent 17 bytes
. 2008-09-11 08:41:57.531 There are 0 bytes remaining in the send buffer
. 2008-09-11 08:41:57.531 Looking for network events
. 2008-09-11 08:41:57.547 Detected network event
. 2008-09-11 08:41:57.547 Enumerating network events for socket 664
. 2008-09-11 08:41:57.547 Enumerated 1 network events making 1 cumulative events for socket 664
. 2008-09-11 08:41:57.547 Handling network read event on socket 664 with error 0
. 2008-09-11 08:41:57.563 Received 28 bytes (0)
. 2008-09-11 08:41:57.563 Startup conversation with host finished.
--END
Hope this helps!
Thanks for your post. I'll send you a debug version soon.
stevegoodsell
Bumping this as it is really becoming a pain.
Any news?
Steve
Sorry, I have sent you an email.
