Topic "Highlighting and actual file 'Not consequent'"
Dirk H
First things first: great, easy to use and very very fast FTP prgram. Thanks.
Then my report, which is not a functionnality bug, but a 'thing of beauty' error, which might cause horrible accidental DELETEs Sad
When you are in the main view of the WINSCP, you have the folder structure in the left panel, and the fileview in the right panel. Try this:
- select a folder 'FOLDER A' (left panel)
- select a file 'FILE A' (right panel)
- press delete: it will ask if you are shure to delete the file 'FILE A'
(don't do it Smile
This behaviour is logical, and correct.
Now try this:
- select again the folder 'FOLDER A' in the left panel
- press delete
It will ask if I want to delete the file 'FILE A'
That's strange, because on screen my active selection is the folder, not the file...
Even worse:
- select another folder 'FOLDER B' in the left panel
- press delete
It will ask if I want to delete '???'
That's strange, because on screen my active selection is the folder, not the file that I'm am proposed...
Thanks for your post. This issue has been added to tracker.
