Topic "On the fly sfv and unrar"
Hi
Absolutly love winscp as it is. I use it manily as a safe alternative to ftp.
Idea A real time and space saver for me would be if you could build in sfv check and unrar on the fly.
Of course for that to work the files must be downloaded in the right order (.sfv , rar , r01 ...)
Br
DrKnowLittle
Sorry, but I do not plan to support this functionality. It is would not help too many people, I guess Sad
mawi
Hello! Validating data after a transfer is essential, and sfv is one good way of doing it.
More people are becoming aware of it and using it.
One simple way you could add such support is by allowing a commandline to be executed after each transfer. This would of course have to be defined as a "custom transfer command" that could be chosen, ie transfer and then execute a command.
Just that - one option in a dialogue and a new command would do it!
You may define a custom command and execute it by yourself after the upload. I do not want to add another option that would work only with SCP protocol, because I believe that SFTP is the future and with it you cannot do this.
Also I believe that as SSH has its own CRC, where is no need for another check on file level. Do you think that it is?
Note to future searchers - try http://www.milow.net/public/projects/parnrar/parnrar.html
Been using it for a couple of days and it works nicely.
Anthony Boone
He is right. No sense in including such features when you can use custom command. WinSCP seems to be a very orthodox and pure program, of which you should appreciate.
Custom Commands are awesome. The custom command to unrar remotely should be
unrar e !/!
Make sure you show your results via terminal to make sure your unrar came out All OK.
It may throw an error the first time you use it. The error is remote and generally says "No files to extract," and is bypassable by simply re-running the same custom command. Enjoy!
