Topic "error code 3"
kimbedi
Hi
I'm trying to copy some files from my PC to my site and keep getting:
Permission denied.
Error code: 3
Error message from server: Permission denied
Request code: 6
any ideas why?
hunter
I am also getting error code 3. I am able to transfer files using the exe. but running it from the scheduler/console I get:
permission denied
error code 3
error message from server permission denied.
why would I get that from the console and not from the exe?
Mark Surprised
Compare the log files from console and the exe and you will see Smile If not please post the log files.
tp000147
I am trying to transfer files to the DHS side. I keep getting the error code 3. Cannot create remote file. Permission denied. Can you help me. Confused
You should ask for help someone you can grant you the permissions.
tapbistro
I am trying to put a .sqlite into a program folder, i keep getting error code 3!
zero3463409
I too get this error.
And this is not the problem I am logged in as root.
darkhelmet
Got this too with v434 and v5 beta - reverted to v429 and no more problems Smile
Killer Ninja Code Monkey
If you are logged in as yourself, make sure you have WinSCP configured to switch to sudo. This will give you the permissions you need to do everything.
try this in the connection configuration:
On your first screen, switch your File Protocol to SCP
Then on the SCP/Shell screen on the Shell Input field type /bin/bash -c 'sudo su -'.
