Topic "Error: Access is denied"
Cracked
Very confusing Rolling Eyes ...I get an "Access is denied" error, after having WinSCP compare a local and remote directory for sync. Obviously I had access with correct username/password in order to analyz the remote directory. Why after having found a changed file in one directory do I get this error only when the program tries to copy the changed file to the remote to complete the sync?
Conf Agree ind.doc: Access is denied.
You probably do not have write permissions to the remote directory.
Cracked
Yes you are correct! Permissions were not set up properly.
Thank you!
