Topic "Moving files within one server"
Splinty
Hi guys!
I'm really glad to look at UTF-8 support. It makes me almost happy Laughing
But would You clarify is it possible to move files on remote server without downloading it locally? I suspect that it's possiple only while using SCP... that doesn't support UTF-8...
Splinty
Oh well, thank You, but my question to be more correct, concerns FAR plugin, sorry.
As i understand plugin doesn't have such features like GUI application, right?
Sors mea Jesus!
No. But you would need SCP anyway for direct copy.
Splinty
I've found, that WinSCP itself is much more interesting for me and solve almost any my task. I do appreciate You for Your work!
By the way i found a bug while intense moving directories by means of dragNdrop.
I turned on a tree and moving directories from one to another and almost every 5-6 moves non critical error appears <invalid link removed>
I move "Third day" from ./musfull/5 to ./musfull/f
In fact everything are moved as ordered but it's something wrong with automatic tree repainting.
After pressing OK on error dialog tree shows old "Third day" <invalid link removed> on old place (in fact absent) and new "Third day" on new place (in fact present and just moved)
So you drag the directory from the tree into another place on the same tree, correct?
Splinty
Yes, I'm moving directories inside one tree in one session.
Sors mea Jesus!
OK, I'll send you a debug version soon.
Splinty
Sure! Feel free to knock me about testing Wink
Sasha.
Sors mea Jesus!
Splinty
I'm little late to say You THANK YOU!WinSCP is the greatest!
Sors mea Jesus!
