Topic "Host does not exist"
MikeD
I looked at the other posts about "Host does not exist" when running winscp from script, and I downloaded the latest version but I'm still running into the problem. When called from a batch file it fails with "Host does not exist", but when I copy and paste that same command in cmd prompt it runs flawlessly. Can you help?
Command:
E:\Progra~1\WinSCP\winscp.com XNS_PROD1 /script=d:\scripts\ftp\XNS\XNS_commands_ack.txt
Same exact command in a batch file results in the error, but if i run it in cmd prompt it works fine. This works fine on another host with previous version of WinSCP.
Have you tried to turn off firewall? It may have per-application rules that causes your problems.
