Topic "custom command : tar for folders?"
The new custom command menu is great!
But I have a problem =)
I wrote this to quickly compresse files and folders.
tar -zcf "!".tgz "!"
It does not work for folders. I right clicked on a folder to apply this compress command and winscp tried to compress every file inside the folder, not the folder itself..
Unsupported feature or did I do something wrong?
Olivier
Well, I understand. Problem is that sometimes you need a custom command to traverse thru subdirectories, sometimes to apply to folders. I'll try to find some solution.
Thank you and congrats for your app! Helps me stay away from the expensive SecureFX.
