Topic "Ignore permission error - when running from script"
user33
We currently use winscp 4.0.3 in script form to place transmit numerous files to external servers.
This has been running fine, until this morning, when I added a new job.
The error recieved is: Upload of file 'test.csv' was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists, turn on 'Ignore permission errors' option.
I just want to ignore this error, the file goes ok - I just need a switch to use at command line in a script which ignores?
thanks
prikryl
prikryl
This request has been added to tracker.
user33
thanks for respose - but thats not any clearer for me.
This is in a batch with a lot of others which are all working ok, and I really dont want to mess with the rest of them, so I really need to try and do this at script level in the cmd file.
is this possible? if not, can you give me a little example of how you would do this using the method you linked me to? perhaps I will hav to call the ini file for this oen customer?
prikryl
You can use -nopreservetime and -nopermissions switches to put command.
cdlvj
I have hit this same error, 1st time in many moons.
What can the client at the server end do to prevent this error?
All our clients have it set correctly except for one.
prikryl
The file must be owned by the user who is overwritting it. It is not enough to have write permissions to update timestamps and/or set permissions.
matmak
If -nopermissions and -nopreservetime are supposed to be the fix for this, then those switches themselves need fixing.
winscp> put -nopermissions -nopreservetime "D:\filestore\etl\data\geography\Region Map Paths.csv" SSRS/
D:Region Map Paths.csv | 1456 KiB | 1789.1 KiB/s | binary | 100%
Upload of file 'Region Map Paths.csv' was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists, turn on 'Ignore permission errors' option.
The server does not support the operation.
Error code: 8
Error message from server (en): The request is not supported.
Request code: 9
winscp>
prikryl
Psi, Inc
Using Version 4.2.9 Build 938, I was having the same problems until I added the
-nopermissions and -nopreservetime. Worked like a charm after that.
user123
We're using Version 4.0.4 Build 346, and have the same problem. Added -nopermissions and -nopreservetime does not work, error:
File or folder '-nopermissions' does not exist. Any ideas?
prikryl
Please read FAQ:
http://winscp.net/eng/docs/faq_script_switch
http://winscp.net/eng/docs/faq_script_ini
Search winscp.net
Associations
Site design by Black Gate
