Topic "Session edit (error-bug)"
ozzytheking
I am using winscp 4.1.7
In this new version i faced with a bug that did not occur at previous versions. My OS is Vista.
I have 2 saved connections in Login interface. 1 of them is SFTP, other is FTP. when i try to click edit button for first connection, Edit dialog appears for a second and disappears after that, then, Winscp tries login to my 2 second connection. However, when i click edit button for my second connection, edit dialog appears and it works fine. Please fix this problem if possible.
I'm not able to reproduce that. Can you email me your configuration?
ozzytheking
After formatting my disk due to other reasons, the problem did not occur again. If it will, i will send the configuration immediately. Thanks for your help
