Topic "BUG: Duplicating folders and files with international symb"
Splinty
Hello.
It's definitely a problem for WinSCP to duplicate files and folders (inside one tree).
I'm using SFTP connection, host has UTF-8 encoding of file names.
PuTTY with Translation=UTF-8 connects to host and successfully performs a duplicating.
I mean, that i copy shell command failed in WinSCP separate session, then open PuTTY session, paste command into shell and run it without any problem. In fact PuTTY+Translation=UTF-8 doesn't have any problem while working with internationally named files and folders et all. So WinSCP also can do that, right?!
In fact error messages are the same if I set PuTTY Translation parameter emptied and try to run a command. I guess that WinSCP start its Terminal and try to run a command, but Terminal doesn't translate symbols like PuTTY do and failed.
In the same time moving of that folders and files works fine (except for http://winscp.net/forum/viewtopic.php?t=6178)
Here You are results (in fact the results of working Terminal)
English file from english folder to russian folder
Command 'cp -p -r -f "01-Best kept secret.mp8" "/home/test/bat/ДИР/01-Best kept secret.mp8"'
failed with return code 1 and error message
cp: cannot create regular file `/home/test/bat/\304\310\320/01-Best kept secret.mp8': No such file or directory.
English file from russian folder to english folder:
Command 'cd "/home/test/bat/ДИР"'
-jailshell: line 16: cd: /home/test/bat/ДИР: No such file or directory.
Command 'cp -p -r -f "01-Best kept secret.mp8" "/home/test/bat/FOLD/01-Best kept secret.mp8"'
cp: cannot stat `01-Best kept secret.mp8': No such file or directory.
Russian file from english folder to english folder
Command 'cp -p -r -f "Между небом и землей.mp8 "/home/test/bat/FOLD/Между небом и землей.mp8"'
cp: cannot stat `\314\345\346\344\363 \355\345\341\356\354 \350 \347\345\354\353\345\351.mp8': No such file or directory.
It's very sorry Sad It seems bug to be simple and have the same roots as one reported here http://winscp.net/forum/viewtopic.php?t=6193.
In fact WinSCP's Terminal needs to have Translation parameter and it will solve lot of problems!
Please try to fix it! WinSCP is close to be perfect!
It is still the same problem. You can use duplicating via local temporary copy instead as workaround.
Splinty
Yes, about "the same" but no about "workaround" Smile
Really good workaround is to copy command from Error dialog and run it in PuTTY session Wink
Sors mea Jesus!
