Topic "Search for string in all files in given directory"
sh1000
Is there feature in WinSCP which will allow me to search for a text string within all files under specified directory?
Not directly. You can use custom command for that. There's a predefined command "grep".
sh100
Thank you for reply.
These commands are disabled,
how can I enable them?
Hm, you probably use FTP protocol, which does not support them.
Search capability feature request is being tracked already.
siddy
i need to get the a particular filen which contains a string on to my destkop from server location from set of 1000 odd xml files. pls help
Grep is not working
need this using command inline
Grep is not working
See example:
http://winscp.net/eng/docs/library_example_recursive_search_text
