Topic "Refresh directory listing on browse"
Is there some setting that makes winscp refresh the listing on browsing? Here's the scenario:
In winscp, I browse to some directory, say /usr/bin, do whatever, and then browse back to /usr
Then, through another program (e.g. shell session) I create a file or directory in /usr/bin, or alternatively some process does the same.
Then in winscp, if I browse back to /usr/bin, I get the *old* listing -- until I manually hit refresh.
Any suggestions? Or should this be a feature request? If this doesn't exist, it could reasonably be lumped into the "automatically refresh directory after operation" setting (that is, browsing to a new directory could count as an operation)
I've noticed the same behavior. Try moving up one level, or more, and then refresh.
Yes, I know that I can manually refresh to work around this.
But I think it would be better if there were an option to have WinSCP automatically ensure that it displays a current directory listing whenever I open a directory. I understand that it might not be a desirable default because it would slow down opening directories containing many files.
Just turn off directory cache.
