Topic "special characters in password"
juanmah
When I log in to a host with a user whose password has special characters like , the access is denied.
If I change the user's password in host to aeiou and I try to log in then it works.
The same special character password worked months before (I don't know what version I used), I suppose this is a new 'feature' in new version.
I also tried to enter with filezilla and the special character password worked.
What protocol are you using? Which version of WinSCP did work?
juanmah
Protocol: SFTP
Version: 4.0.5 and 4.0.6
juanmah wrote:
Protocol: SFTP
I'm not aware of such change between 4.0.6. and 4.1.7. Are you able to login now with 4.0.6? Or did it just work then?
juanmah
I've downloaded all disponible versions from 3.8.1 to 4.1.7, and I'm not able to login now with a special character password. But I'm sure before summer it worked. Maybe is a SSH issue?
In other way WinSCP doesn't log in with special character password, and other file transfer programs like filezilla do it correctly. Can anyone confirm this?
Can you try PuTTY?
juanmah
Putty fails when login with password: and do it correctly with password: a
It has the same behavior as WinSCP.
Than I doubt that Filezilla works. Because it is based on PuTTY as well. Are you sure you are using SFTP with Filezilla?
juanmah
Completely sure. I double checked.
juanmah
other test: one user is test1 with password a, other user is test2 with password
LOG TEST 1:
Prompt (6, SSH password, , &Password: )
Sent password
Waiting for the server to continue with the initialisation
Looking for incoming data
Looking for network events
Detected network event
Enumerating network events for socket 136
Enumerated 1 network events making 1 cumulative events for socket 136
Handling network read event on socket 136 with error 0
Access granted
Opened channel for session
Started a shell/command
LOG TEST2
Sent password
Enumerating network events for socket 132
Enumerated 1 network events making 1 cumulative events for socket 132
Handling network read event on socket 132 with error 0
Access denied
Access denied
Selecting events 0 for socket 132
Disconnected: Unable to authenticate
(ESshFatal) Connection has been unexpectedly closed. Server sent command exit status 0.
Using username "test2".
Access denied.
Authentication failed.
OK, I'll check that.
