Topic "for an old version 3.6.7, what is the shell winscp is using?"
Eric_Gao
Hi Guys,
I got a problem when run this version with scp protocol. on tab environment/scp, if I choose "default", I am always getting error "Error skipping startup message. Your shell is probably imcompatible with the application".
if I change Environment/SCP shell to enter followed by any available shells, it works fine.
Just wondering waht is the the "default" option using? should it be one of the available shell that I had tried? why it is only working after I specified explicitly?
Thanks.
It is using the default shell of your user account.
Eric_Gao
Thanks prikryl for clarification.
In case it is using the default shell of user account (/bin/ksh), why winscp is always failing.
while after I ticked it to "/bin/ksh", the same default shell, it became working. Still can't explain this to my customer.
The difference may be that on Unix the default shell is started by operating system with --login switch. While WinSCP does not do that for explicitly specified shells.
