Topic "Error "Remove directory operation failed""
DPCEDB
I can create a Directory on my ftp server
I cannot delete it, I get always the same error "Remove directory operation failed"
Is it a known bug ?
Version is 4.1.7 Build (413)
Transfer protocol is FTP
I'm using Explorer interface style
Can you post a log file?
. 2008-10-29 17:24:27.546 Cached directory change via "/shares" to "/shares".
. 2008-10-29 17:24:27.546 Getting current directory name.
. 2008-10-29 17:24:27.546 Listage du rpertoire en cours...
> 2008-10-29 17:24:27.546 CWD /shares/
< 2008-10-29 17:24:27.859 250 Directory successfully changed.
> 2008-10-29 17:24:27.859 PWD
< 2008-10-29 17:24:27.906 257 "/shares/"
> 2008-10-29 17:24:27.906 TYPE A
< 2008-10-29 17:24:27.953 200 Switching to ASCII mode.
> 2008-10-29 17:24:27.953 PASV
< 2008-10-29 17:24:28.062 227 Entering Passive Mode (83,167,146,132,131,219)
> 2008-10-29 17:24:28.062 LIST -a
< 2008-10-29 17:24:28.390 150 Here comes the directory listing.
< 2008-10-29 17:24:32.421 226 Directory send OK.
. 2008-10-29 17:24:32.421 Listage du rpertoire russi
. 2008-10-29 17:24:36.000 Cached directory change via "/shares/Travail EDB" to "/shares/Travail EDB".
. 2008-10-29 17:24:36.000 Getting current directory name.
. 2008-10-29 17:24:36.000 Listage du rpertoire en cours...
> 2008-10-29 17:24:36.000 CWD /shares/Travail EDB/
< 2008-10-29 17:24:36.296 250 Directory successfully changed.
> 2008-10-29 17:24:36.296 PWD
< 2008-10-29 17:24:36.406 257 "/shares/Travail EDB/"
> 2008-10-29 17:24:36.406 TYPE A
< 2008-10-29 17:24:36.484 200 Switching to ASCII mode.
> 2008-10-29 17:24:36.484 PASV
< 2008-10-29 17:24:36.562 227 Entering Passive Mode (83,167,146,132,131,218)
> 2008-10-29 17:24:36.562 LIST -a
< 2008-10-29 17:24:36.765 150 Here comes the directory listing.
< 2008-10-29 17:24:37.265 226 Directory send OK.
. 2008-10-29 17:24:37.281 Listage du rpertoire russi
. 2008-10-29 17:24:44.250 Creating directory "Test".
> 2008-10-29 17:24:44.250 CWD /shares/Travail EDB/
< 2008-10-29 17:24:44.515 250 Directory successfully changed.
> 2008-10-29 17:24:44.515 MKD Test
< 2008-10-29 17:24:44.703 257 "/shares/Travail EDB/Test" created
. 2008-10-29 17:24:44.703 Listage du rpertoire en cours...
> 2008-10-29 17:24:44.703 TYPE A
< 2008-10-29 17:24:44.781 200 Switching to ASCII mode.
> 2008-10-29 17:24:44.781 PASV
< 2008-10-29 17:24:45.171 227 Entering Passive Mode (83,167,146,132,131,217)
> 2008-10-29 17:24:45.171 LIST -a
< 2008-10-29 17:24:45.359 150 Here comes the directory listing.
< 2008-10-29 17:24:45.984 226 Directory send OK.
. 2008-10-29 17:24:45.984 Listage du rpertoire russi
. 2008-10-29 17:24:49.265 Deleting file "Test".
. 2008-10-29 17:24:49.265 Listage du rpertoire en cours...
> 2008-10-29 17:24:49.265 CWD /shares/Travail EDB/Test/
< 2008-10-29 17:24:49.656 250 Directory successfully changed.
> 2008-10-29 17:24:49.656 PWD
< 2008-10-29 17:24:49.765 257 "/shares/Travail EDB/Test/"
> 2008-10-29 17:24:49.765 TYPE A
< 2008-10-29 17:24:49.812 200 Switching to ASCII mode.
> 2008-10-29 17:24:49.812 PASV
< 2008-10-29 17:24:49.906 227 Entering Passive Mode (83,167,146,132,131,216)
> 2008-10-29 17:24:49.906 LIST -a
< 2008-10-29 17:24:50.078 150 Here comes the directory listing.
< 2008-10-29 17:24:50.343 226 Directory send OK.
. 2008-10-29 17:24:50.343 Listage du rpertoire russi
. 2008-10-29 17:24:50.343 Synchronizing current directory "/shares/Travail EDB".
> 2008-10-29 17:24:50.343 CWD /shares/Travail EDB
< 2008-10-29 17:24:53.515 250 Directory successfully changed.
> 2008-10-29 17:24:53.515 RMD /shares/Travail EDB/Test/
< 2008-10-29 17:24:53.734 550 Remove directory operation failed.
. 2008-10-29 17:24:53.734 Asking user:
. 2008-10-29 17:24:53.734 Erreur dans la suppression du fichier 'Test' ("Remove directory operation failed.")
It seems that you do not have permissions to delete the directory. Maybe it is in use by another users or software.
