Topic "Error while executing unix script from windows thro WinSCP"
Gopal
Hi All,
I am facing the below mentioned error, while executing unix script from windows through WinSCP.exe.
I am using the below command, i am getting the below mentioned error in the production, but in the test environment, i can able to execute the script, kindly help
C:\Gop\WinSCP\WinSCP.exe /console emerg1:Vm41L000@10.20.210.240 /command "call /home/emerg1/test.sh"
Searching for host...
Connecting to host...
Authenticating...
Using username "emerg1".
Authenticated.
Starting the session...
Reading remote directory...
Session started.
Active session: [1] emerg1@10.20.210.240
Authenticating...
Authenticated.
Connection has been unexpectedly closed. Server sent command exit status 255.
Error skipping startup message. Your shell is probably incompatible with the application (BASH is recommended).
winscp>
Gopal
I had gone through the document earlier itself, could you please advice me, why it is not working in production , where as test server it is working fine.......................
Gopal
I have no idea. Check your server log.
jjaramillo
-> Maibe if your user was just created u need to enter using putty and change the password "Is required by the firs time u use the user", after u change thhe password try again to log using winscp.
