Topic "WinSCP Attempting to Connect to Cygwin"
Jamie
Hi there,
Can't find anything anywhere on how to solve this issue I am having.
I have a Cygwin installation on a SBS 2003 box and I am attempting to connect using WinSCP from an XP Pro client on the same network.
I have created a brand new account in AD, and created passwd and group files in the Cygwin directory.
When I attempt to connect using the new username, the password is denied even though I know for a fact it is correct. There are a few accounts that have no issue with connecting using exactly the same setup though... I have tried creating the account from scratch, and I have tried creating the new account by replicating my own account (which works without issue)
Here is the log from WinSCP:
. 2008-10-30 11:30:02.697 --------------------------------------------------------------------------
. 2008-10-30 11:30:02.697 WinSCP Version 3.8.2 (Build 330) (OS 5.1.2600 Service Pack 3)
. 2008-10-30 11:30:02.697 Login time: 30 October 2008 11:30:02
. 2008-10-30 11:30:02.697 Session name: <username>@<IP address>
. 2008-10-30 11:30:02.697 Host name: <IP Address> (Port: 22)
. 2008-10-30 11:30:02.697 User name: <Username> (Password: Yes, Key file: No)
. 2008-10-30 11:30:02.697 Transfer Protocol: SFTP (SCP)
. 2008-10-30 11:30:02.697 SSH protocol version: 2; Compression: No
. 2008-10-30 11:30:02.697 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2008-10-30 11:30:02.697 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2008-10-30 11:30:02.697 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2008-10-30 11:30:02.697 SSH Bugs: -,-,-,-,-,-,-,-
. 2008-10-30 11:30:02.697 SFTP Bugs: -,-,-
. 2008-10-30 11:30:02.697 Proxy: none
. 2008-10-30 11:30:02.697 Return code variable: Autodetect; Lookup user groups: Yes
. 2008-10-30 11:30:02.697 Shell: default, EOL: 0
. 2008-10-30 11:30:02.697 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2008-10-30 11:30:02.697 Cache directory changes: Yes, Permanent: Yes
. 2008-10-30 11:30:02.697 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2008-10-30 11:30:02.697 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2008-10-30 11:30:02.697 Looking up host "<IP Address>"
. 2008-10-30 11:30:02.697 Connecting to <IP Address> port 22
. 2008-10-30 11:30:02.900 Server version: SSH-2.0-OpenSSH_4.7
. 2008-10-30 11:30:02.900 We claim version: SSH-2.0-WinSCP_release_3.8.2
. 2008-10-30 11:30:02.900 Using SSH protocol version 2
. 2008-10-30 11:30:03.072 Doing Diffie-Hellman group exchange
. 2008-10-30 11:30:03.322 Doing Diffie-Hellman key exchange
. 2008-10-30 11:30:03.650 Host key fingerprint is:
. 2008-10-30 11:30:03.650 ssh-rsa 2048 e8:6e:e2:43:95:a4:e1:df:b3:ee:7d:6e:fc:11:c9:79
. 2008-10-30 11:30:03.666 Initialised AES-256 client->server encryption
. 2008-10-30 11:30:03.666 Initialised HMAC-SHA1 client->server MAC algorithm
. 2008-10-30 11:30:03.666 Initialised AES-256 server->client encryption
. 2008-10-30 11:30:03.666 Initialised HMAC-SHA1 server->client MAC algorithm
! 2008-10-30 11:30:03.884 Using username "<Username>".
. 2008-10-30 11:30:03.962 Keyboard-interactive authentication refused
. 2008-10-30 11:30:03.962 Session password prompt (<Username>@<IP Address>'s password: )
. 2008-10-30 11:30:03.962 Using stored password.
! 2008-10-30 11:30:03.962 Authenticating with pre-entered password.
. 2008-10-30 11:30:03.962 Sent password
! 2008-10-30 11:30:04.259 Access denied.
. 2008-10-30 11:30:04.259 Access denied
. 2008-10-30 11:30:04.259 Session password prompt (<Username>@<IP Address>'s password: )
. 2008-10-30 11:30:04.259 Asking user for password.
. 2008-10-30 11:30:05.931 Unable to authenticate
. 2008-10-30 11:30:05.931 Attempt to close connection due to fatal exception:
* 2008-10-30 11:30:05.931 Unable to authenticate
. 2008-10-30 11:30:05.931 Closing connection.
* 2008-10-30 11:30:05.946 (ESshFatal) Authentication failed.
* 2008-10-30 11:30:05.946 Authentication log (see session log for details):
* 2008-10-30 11:30:05.946 Using username "<Username>".
* 2008-10-30 11:30:05.946 Authenticating with pre-entered password.
* 2008-10-30 11:30:05.946 Access denied.
* 2008-10-30 11:30:05.946 Unable to authenticate
________________________________________________________________________________
Thanks in advance!
Jamie
Have you used mkpasswd command?
