Topic "Create Multiple tar or zip's"
Ezdub
Is there a custom command that will create multiple tar's or zip's.
I have a lot of folders that contain either images or files.
What I would like is to have a custom command to take the folder name and make a tar or zip of the folder and it's contents.
So if I selected say 10 folders and their contents it would make a seperate tar or zip of each folder, instead of just 1 archive.
Hope I have explained myself on that one.
Following will do:
tar -cz -f "!.tar" "!"
Do not forget to check Apply to directories.
Ezdub
prikryl wrote:
Following will do:
Perfect that is just what I needed.
Many thanks.
djrino
Hi
and for zip format?
i want to zip all the file in customer account but shure liki zipname.zip and into it all the publichtml files
tnx
