Topic "Error while "call nohup command &""
Mercury
When I try typing
> open somesession
> cd somedirectory
> call nohup somecommand &
WinScp outputs
> Searching for host...
> Connecting to host...
> Authenticating...
> Using username "someuser".
> Authenticating with pre-entered password.
> Authenticated.
> Starting the session...
> Reading remote directory...
> Session started.
> -sh: Syntax error: ";" unexpected
> Connection has been unexpectedly closed. Server sent command exit status 2.
> Session 'somesession' closed.
> No session.
The command DOES work in PuTTY. The reason is clearly "&" at the end of command.
What to do?
I guess you cannot use & without TTY.
See documentation for more details about limitation of terminal in WinSCP.
Mercury
Well, how to circumvent this?
(I use WinSCP to start some task automatically, so I cannot use PuTTY)
Try plink from PuTTY package.
Mercury
And what to do if I need to upload some file automatically and run some command (automatically, too)? Use two programs just for the sake of some "&"?
What about not using the &?
zac80
Martin, is there any way I can forward a command to the remote server such that WinSCP does not hang while the command is executed? Particularly, I would like to run the command "nohup ./file.bin &".
You can workaround syntactical problem with & by invoking the command from child shell, like:
/bin/sh -c "nohup ./file.bin &"
