Topic "Backup script special characters"
namit
Hey I have a script that backups my computer every night but it crashes out when i comes across any file that has special characters that are not English like Ukranian ones or ??? marks in them. How do i get around this?
It seams to come back with file does not exist skip(S) retry(R) abort(A) but it just aborts.
# VPSLink Sample Backup Script for WinSCP
option exclude "*.mp4; *.lnk; *.exe; *.msi; My Pictures; My Music; My Videos; @college; .metadata;"
# Comment out the next two lines to test
option batch on
# Connect - format: user:password@host
open user:pass@server.org
# Force binary mode transfer
option transfer binary
# Download backup file to remote directory
synchronize remote F:\+myfiles\ /home/user/recent
# Disconnect
close
# Exit WinSCP
only seams to happen with script not with GUI but can not schedule the gui to run every night.
Can you post a log file, both from GUI and the script?
namit
Backup started at 10/11/2008
exclude      *.mp4; *.lnk; *.exe; *.msi; My Pictures; My Music; My Videos; @college; .metadata; *.cab; *.exe; *.msi;
batch        on
confirm      off
Searching for host...
Connecting to host...
Authenticating...
Using username "test".
Authenticated.
Starting the session...
File or folder 'C:\Shared Docs\Update 21 April 2008\Shared Docs\Ukraine\13-17 ?ctober - Key Notes.doc' does not exist.
- Hide quoted text -
System Error.  Code: 123.
The filename, directory name, or volume label syntax is incorrect
Session 'test@server.server.org' closed.
No session.
Error: 09/11/2008
This is the output of script backup.
namit
Gui shows
but i would prefer to have it all scripted.
namit
Think its this corrupt file problem i am coming across.
http://winscp.net/forum/viewtopic.php?t=3422
Has this been fixed, is there a way to set a skip option for corrupt files.
namit
I put in thing below to my script and it solved it for some copying
option exclude "*.mp4; *.lnk; *.exe; *.msi; My Pictures; My Music; My Videos; @college; .metadata; *.cab; *.exe; *.msi; *_?*; ~$?*; *-?*; Tatjana;"
but have a corrupt file that is called
???? ???? ?? .doc
but putting *?* just stops copying everything.
Think because ? is being picked up as a regex am i right?
If so is there a way of solving this and making it not come out as a regex.
Thanks again
You can try to specify full file name "???? ???? ?? .doc" and hope it does not match another file. However I do not think that the question marks are actually question marks. So it may not help.
namit
Think its because the file is corrupted, is there a way in scripts like the gui to say if file name is two long or corrupt to skip over it and not abort?
You can use "option batch continue".
Anant
when I am trying to login through winscp to remote system it is given me connection refused error
Sorry, your post does not include enough information.
Please read how to troubleshoot problems with WinSCP. If it turns out that you are not able to help yourself, read how to ask for support or report bugs efficiently, so others can help you.
Also start a new thread as I do not see any relation to this one.
iannis
I have exactly the same problem (code 123) with french accented characters in the filename. "Skip" button in the GUI works ok. However in the script, although "option batch continue" answers with "Skip", the script exits after that.
Version 4.3.6 build 1655.
Thanks for this great software!
Can you try unicode 5.0.5 beta?
Problem solved in 5.0.5 beta, no more errors with Code 123.
Filenames with accents in unnicode encoding (the usual case) are synchronized without problem.
Some files, saved from mail attachments, contain accented letters not in unicode. These files are first deleted during synchronization ("synchronize remote -delete") and then transfered again; this happens in every synchronization. I had just to rename these files and type again the accented characters so that they become unicode and everything is fine now, they are synchronized only once.
Thanks again.
Thanks for your feedback!
