Topic "where is the "Command" section for /keepuptodate?"
pstein
When I go to page
http://winscp.net/eng/docs/task_keep_up_to_date
then this page directs me to the "Commands" section
where I should enter something.
However I did not found such a "Comands" section.
Is this a description for an older version of WinSCP?
Is this renamed in the newest WinSCP 417?
Where are the directory specs for /keepuptodate otherwise ?
Commands menu is present in all versions of WinSCP.
pstein
No,Sorry I do NOT find the "commands" menu.
Have a look at the following snapshot.
Where is the "commands" menu entry with the two entry fields for the keepuptodate option?
http://img91.imageshack.us/my.php?image=nocommandsmenuyr1.png
The documentation refers to the menu of the main window, which come out after you login in.
