Topic "Relative putty.exe path"
linuxamp
I read the forum posts about relative RND and keyfile paths as well as the "portable" section on the manual page but the path to putty.exe must still be absolute.
./putty.exe not found.
Correct path on Windows is .\putty.exe
linuxamp
Sorry, I typed it wrong here in the forum. It was .\putty.exe which didn't work.
Will try that. But first, are you aware that the path is relative to WinSCP startup directory, not to path, where winscp.exe is located?
