Topic "copying of a file aborts - got reply 2004 to the command 4"
Herbee
im running latest winscp 4.1.7. on XP pro SP3
i created a FTP session with the gui
- connected to the server
- the login works
- the change of the remote directory works
- but copying of a file aborts directly:
the log:
. 2008-12-01 16:00:33.308 Changing directory to "e:/ftproot/exh/input".
. 2008-12-01 16:00:33.308 FtpControlSocket.cpp(1283): FtpCommand(CWD e:/ftproot/exh/input) OpMode=0 OpState=-1 caller=0x01da3010
> 2008-12-01 16:00:33.308 CWD e:/ftproot/exh/input
. 2008-12-01 16:00:33.386 FtpControlSocket.cpp(878): OnReceive(0) OpMode=2 OpState=-1 caller=0x01da3010
< 2008-12-01 16:00:33.386 250 CWD command successful. "e:/ftproot/exh/input/" is current directory.
. 2008-12-01 16:00:33.386 FtpControlSocket.cpp(4198): ResetOperation(1) OpMode=2 OpState=-1 caller=0x01da3010
. 2008-12-01 16:00:33.386 Got reply 1 to the command 16
. 2008-12-01 16:00:33.386 Getting current directory name.
. 2008-12-01 16:00:33.386 FtpControlSocket.cpp(1283): FtpCommand(PWD) OpMode=0 OpState=-1 caller=0x01da3010
> 2008-12-01 16:00:33.386 PWD
. 2008-12-01 16:00:34.433 FtpControlSocket.cpp(878): OnReceive(0) OpMode=2 OpState=-1 caller=0x01da3010
< 2008-12-01 16:00:34.433 257 "e:/ftproot/exh/input/" is current directory.
. 2008-12-01 16:00:34.433 FtpControlSocket.cpp(4198): ResetOperation(1) OpMode=2 OpState=-1 caller=0x01da3010
. 2008-12-01 16:00:34.433 Got reply 1 to the command 16
. 2008-12-01 16:00:34.433 Session upkeep
. 2008-12-01 16:00:34.433 Copying 1 files/directories to remote directory "e:/ftproot/exh/input/"
. 2008-12-01 16:00:34.433 PrTime: Yes; PrRO: Yes; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2008-12-01 16:00:34.433 TM: M; ClAr: No; CPS: 0; ExclM(Yes): *.xml; *.csv
. 2008-12-01 16:00:34.433 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2008-12-01 16:00:34.433 File: "\\WS-35\Daten\gpl\out\test.xml"
. 2008-12-01 16:00:34.433 Copying "\\WS-35\Daten\gpl\out\test.xml" to remote directory started.
. 2008-12-01 16:00:34.433 Ascii transfer mode selected.
. 2008-12-01 16:00:34.433 FtpControlSocket.cpp(2121): FileTransfer(31178092, FALSE, 0) OpMode=0 OpState=-1 caller=0x01da3010
. 2008-12-01 16:00:34.433 Beginne \\WS-35\Daten\gpl\out\test.xml heraufzuladen
> 2008-12-01 16:00:34.433 CWD e:/ftproot/exh/input/e:/ftproot/exh/input/
. 2008-12-01 16:00:34.480 FtpControlSocket.cpp(878): OnReceive(0) OpMode=40 OpState=1 caller=0x01da3010
< 2008-12-01 16:00:34.480 250 CWD command successful. "e:/ftproot/exh/input/" is current directory.
. 2008-12-01 16:00:34.480 FtpControlSocket.cpp(2121): FileTransfer(0, FALSE, 0) OpMode=40 OpState=1 caller=0x01da3010
> 2008-12-01 16:00:34.480 PWD
. 2008-12-01 16:00:34.527 FtpControlSocket.cpp(878): OnReceive(0) OpMode=40 OpState=4 caller=0x01da3010
< 2008-12-01 16:00:34.527 257 "e:/ftproot/exh/input/" is current directory.
. 2008-12-01 16:00:34.527 FtpControlSocket.cpp(2121): FileTransfer(0, FALSE, 0) OpMode=40 OpState=4 caller=0x01da3010
. 2008-12-01 16:00:34.527 FtpControlSocket.cpp(2770): Real path and requested remote path do not match: "4100 0 2 e: 7 ftproot 3 exh 5 input" "4100 0 2 e: 7 ftproot 3 exh 5 input 2 e: 7 ftproot 3 exh 5 input" caller=0x01da3010
. 2008-12-01 16:00:34.527 FtpControlSocket.cpp(4198): ResetOperation(8192) OpMode=40 OpState=4 caller=0x01da3010
. 2008-12-01 16:00:34.527 Kopieren von Dateien auf den entfernten Rechner schlug fehl.
. 2008-12-01 16:00:34.527 Got reply 2004 to the command 4
* 2008-12-01 16:00:34.527 (ExtException) Kopieren von Dateien auf den entfernten Rechner schlug fehl.
* 2008-12-01 16:00:34.527 "e:/ftproot/exh/input/" is current directory.
. 2008-12-01 16:00:34.527 Asking user:
. 2008-12-01 16:00:34.527 Fehler beim der bertragung der Datei '\\WS-35\Daten\gpl\out\test.xml'. ("Kopieren von Dateien auf den entfernten Rechner schlug fehl.","""e:/ftproot/exh/input/"" is current directory.")
* 2008-12-01 16:00:34.527 (EScpSkipFile) Fehler beim der bertragung der Datei '\\WS-35\Daten\gpl\out\test.xml'.
* 2008-12-01 16:00:34.527 Kopieren von Dateien auf den entfernten Rechner schlug fehl.
note: transfer with filezilla works fine.
