Topic "saving files problem - cutting off the files"
Hi, I used internal editor to edit the files. After saving the changes, the file was cutted off in half. the file should have had 30 lines but had only 15. But the funny thing is that the size changed only a little bit(50 bytes) but there was missing maybe 500 letters(signs). Then I tried to use linux environment with the same operations and everything worked properly. Anybody any idea what is going on? Thanks.
What protocol are you using? What is your server?
Zdravim, At first I used SCP protocol and that was causing problems. I tried SFTP protocol and it is working. Thanks.
