Topic "Access dates not being tranffered correctly"
bcomegys
Hi ;
Thanks for a great product. I my users have found an issue when transferring files from a remote site to a local server the date on the remote file shows 12/08/2008 the date on the local file shows 12/31/1997. I first went in and updated the software to the latest release 4.1.8 . I then went in and played with the settings and tried all three none work.
Anybody have any ideas?
Bill
What protocol are you using? What is your server? What is your local file system?
bcomegys
The protocol is SFTP
I do not know what the remote server is I assune *nix
Local machine is Windows XP SP3 using NTFS with a NetWare Client 4.91 SP4 for Windows going to a Netware 6.5 SP7 server.
William
Can you try to download file to local drive instead to network drive (if it is what you are doing)?
