Topic "Problem uploading file with Cyrillic file name"
Lugh
Hello!
I'm trying to upload via winscp several file with Cyrillic file name. In windows I can open and use these file without problem but winscp seams to not reconize them. instead the file name I got "????????" and when I try to copy them on my web site I got a meassage "file doesn't exist" "error code 123".
Could someone help me out? is there a way to copy these file (There is a lot of them and I really don't want to rename everyone of them...)
Thanks!
TS
Did you read the FAQ? What protocol are you using? Can you make the transfers with a different client, or is the problem your server?
Lugh
I can transfert it with filezilla so it is not a server problem. I use SFTP protocol and SSH 2 without compression
TS
What version of SFTP (found in commands -> server/protocol information)?
Also what protocol are you using with Filezilla?
Lugh
here are the details :
Protocole de la session = SSH-2
Implmentation SSH = OpenSSH_4.3p2 Debian-9etch3
Chiffrement = aes
Compression = Non
Version protocole de transfert = SFTP-3
But still, if your default local code page is not Cyrillic, WinSCP may not be able to process the filenames correctly.
