Topic "Window state/position is not remembered since 4.1.x"
markus
Hi all,
I'm using WinSCP in Windows 2000. The latest version of WinSCP, 4.1.8 does not remeber the Window state/position. The I tried with 4.1.7, and the same problem. Then 4.1.6, and so on.
It was working ok until version 4.0.7, which is the one I'm using now. When opening the application is stays maximized. But this does not work on any 4.1.x version I tried.
Other than that, the program rocks! Thank you very much for all the great work.
Cheers
I'm aware of WinSCP not restoring to maximization on Windows 2000. See tracker. But it should remember non-maximized position.
markus
http://winscp.net/forum/viewtopic.php?t=5422
You may wish to close my topic. I'll post in the other one. Thanks for the pointer.
There's always more than one way to do it.
