Topic "Synchronize local with "get -delete" on remote"
lnedad
Is there an easy way to use synchronize to get all the new files in a remote directory and then delete them once they are on the local directory. (Also, I never want to delete files from the local directory).
What would you use such function for?
log10
I have hundreds of log files that need to be downloaded from different servers. I would like to download them if they don't exist or are not changed on the local server and delete them on the remote server once they are "safely" on the local server.
So once you do that (e.g. manually), you will end up with no remote files. So the next times you just need to do "get -delete". Right?
AoR
Hello
I have a little problem by using the "get" command within a scripting file. If I use get in this way
get -delete *.csv \\Server-name\directory\
I get an error like
. 2009-01-14 12:00:43.278 Getting current directory name.
. 2009-01-14 12:00:43.278 Listing file "-delete".
> 2009-01-14 12:00:43.278 Type: SSH_FXP_LSTAT, Size: 39, Number: 263
< 2009-01-14 12:00:43.278 Type: SSH_FXP_STATUS, Size: 29, Number: 263
< 2009-01-14 12:00:43.278 Status/error code: 2, Message: 263, Server: No such file, Language:
. 2009-01-14 12:00:43.278 Closing connection.
Which is the correct way to use the "-delete" Switch?
You are using it correctly. However you probably use old version of WinSCP. Switches such as -delete are supported since WinSCP 4.1 only.
AoR
Thanxs! Now it works!
I have added topic on deleting files after synchronization to FAQ.
