Synchronize Local
Smack
Synchronize Local
Backstory: I started using a Scripted WinSCP to do some backups of a webserver. I decided to synchronize both, so if someone deleted everything on the webserver it would come back. Worked like a champ. I get a new server to do this with, and it synchronizes the remote directory with the local one, deleting everything. I changed nothing, but I chalk it up to a fluke.
Now, fearing a deletion of everything again, I set the synchronize command to be local, so I just have a backup of it and not an auto-replacing one. However, there are certain directories that now always backup/download the files. Nothing has changed with them ever, and yet they always back up. Set -critera=both, =time, and =size, and it behaves the same.
I set it back to Synchronize Both, and it behaves like you'd expect, only copying locally the new or changed files.
Re: Synchronize Local
First, WinSCP has preview enabled by default, so you should have been "warned" about the deletion, haven't you?
Please read FAQ first. If that does not help, come back.
Smack
I definitely read the FAQ first, guess I should have mentioned it. Also, the initial deletion was probably my own fault, and it's not really the part that bothers me.
The part that I'm confused about is why [synchronize local] would continually download the same files every time it runs, regardless of the criteria it's supposed to match.
I believe that possible reason is explained in the FAQ, isn't it?
Smack
Although that is possibly a problem, the question is why does it work if it's set to Local, and not Remote? It still has to check for updates and it does so correctly if it's set to Local.
OK I see. Can you enable preview and post a screenshot for "local" synchronization showing the files there are always synchronized?
