Topic "WinSCP on a Windows XP machine"
gtg179r
I'm new to using this. I have to use this program on my school campus and I was wondering if it were possible to set up the SCP connection between two windows computers (ie my desktop and laptop) that way if I need a file from my desktop, and I'm in class, I can just login and transfer it? Or do I have to connect strictly to a UNIX machine? I'm new to this so all the help I can get yould be great.
gtg179r
spiff
after some googling i found this; http://lexa.mckenna.edu/sshwindows/ , which you would have to set up on your desktop and could thenn access it with WinSCP from your laptop.
I would have recommended you the same software, if you had not have found it already Smile I use it to test WinSCP.
