Topic "Problems reading an OMVS Content"
mjfuchs
I am in the need to transfer files in batchmode to an OMVS-System under z/OS 1.9.
I cannot retrieve a directory. I searched your forum and in BUG-Report 49 it is stated that non-Unix-like systems are not supported. Since OMVS is a UNIX-System under z/OS, there must be a possability to commuincate. winscp is so far the only program i found that writes a fine log and handles returncodes. my Logfile follows. Can anyone help ? Is there timeline for correcting the bug/establishing the functionality ?
Regards mjfuchs
. 2009-01-07 11:46:23.343 --------------------------------------------------------------------------
. 2009-01-07 11:46:23.343 WinSCP Version 4.1.8 (Build 415) (OS 5.1.2600 Service Pack 2)
. 2009-01-07 11:46:23.343 Login time: Mittwoch, 7. Januar 2009 11:46:23
. 2009-01-07 11:46:23.343 Session name: zt01@10.201.1.1
. 2009-01-07 11:46:23.343 Host name: 10.201.1.1 (Port: 21)
. 2009-01-07 11:46:23.343 User name: zt01 (Password: Yes, Key file: No)
. 2009-01-07 11:46:23.343 Tunnel: No
. 2009-01-07 11:46:23.343 Transfer Protocol: FTP
. 2009-01-07 11:46:23.343 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2009-01-07 11:46:23.343 Proxy: none
. 2009-01-07 11:46:23.343 FTP: Passive: No
. 2009-01-07 11:46:23.343 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2009-01-07 11:46:23.343 Cache directory changes: Yes, Permanent: Yes
. 2009-01-07 11:46:23.343 DST mode: 1
. 2009-01-07 11:46:23.531 Verbinde mit 10.201.1.1 ...
. 2009-01-07 11:46:23.531 Verbunden mit 10.201.1.1. erwarte Willkommensnachricht ...
< 2009-01-07 11:46:23.546 220-TCPFTP1 IBM FTP CS V1R9 at HELMVS1, 10:47:20 on 2009-01-07.
< 2009-01-07 11:46:23.718 220 Connection will close if idle for more than 240 minutes.
> 2009-01-07 11:46:23.718 USER zt01
< 2009-01-07 11:46:23.828 331 Send password please.
> 2009-01-07 11:46:23.828 PASS ********
< 2009-01-07 11:46:24.000 230 ZT01 is logged on. Working directory is "ZT01.".
> 2009-01-07 11:46:24.000 SYST
< 2009-01-07 11:46:24.000 215 MVS is the operating system of this server. FTP Server is running on z/OS.
> 2009-01-07 11:46:24.000 FEAT
< 2009-01-07 11:46:24.015 211- Extensions supported
< 2009-01-07 11:46:24.125 AUTH TLS
< 2009-01-07 11:46:24.125 PBSZ
< 2009-01-07 11:46:24.125 PROT
< 2009-01-07 11:46:24.125 211 End
. 2009-01-07 11:46:24.125 Verbunden
. 2009-01-07 11:46:24.125 --------------------------------------------------------------------------
. 2009-01-07 11:46:24.125 Using FTP protocol.
. 2009-01-07 11:46:24.125 Doing startup conversation with host.
> 2009-01-07 11:46:24.125 PWD
< 2009-01-07 11:46:24.140 257 "'ZT01.'" is working directory.
. 2009-01-07 11:46:24.140 Getting current directory name.
. 2009-01-07 11:46:24.140 Startup conversation with host finished.
. 2009-01-07 11:46:24.140 Rufe Verzeichnisinhalt ab...
> 2009-01-07 11:46:24.140 CWD /'ZT01.'/'ZT01.'/
< 2009-01-07 11:46:24.140 550 CWD cmd failed : EDC5129I No such file or directory. (errno2=0x0594003D)
. 2009-01-07 11:46:24.140 Konnte Verzeichnisinhalt nicht abrufen
< 2009-01-07 11:46:24.156 550 CWD cmd failed : EDC5129I No such file or directory. (errno2=0x0594003D)
. 2009-01-07 11:46:24.156 Konnte Verzeichnisinhalt nicht abrufen
. 2009-01-07 11:46:24.156 Asking user:
. 2009-01-07 11:46:24.156 Fehler beim Anzeigen des Verzeichnisses "'ZT01.'". ("Konnte Verzeichnisinhalt nicht abrufen","CWD cmd failed : EDC5129I No such file or directory. (errno2=0x0594003D)")
. 2009-01-07 11:46:24.156 Verbindung zum entferneten Rechner abgebrochen
May I have a test account on your server?
BertKoor
Hi there, I have the same issue.
The log file shows that a directory listing can be obtained, but nothing is shown. And I'm sorry, but this server is only accessible from within our company. Access from the outside world is not possible.
WinSCP Version 4.2.4 (Build 610) (OS 5.1.2600 Service Pack 2)
Login time: vrijdag 13 november 2009 10:35:11
Session name: idsko@mainframe
Host name: mainframe (Port: 21)
User name: idsko (Password: No, Key file: No)
Tunnel: No
Proxy: none
FTP: FTPS: None; Passive: No [Force IP: No]
Local directory: default, Remote directory: /appl/was00t/log/glo, Update: No, Cache: No
Cache directory changes: No, Permanent: Yes
DST mode: 1
Password prompt (no password provided or last login attempt failed)
Connecting to mainframe ...
Connected with mainframe. Waiting for welcome message...
220-TCPFTP1 IBM FTP CS V1R8 at ALFAPROD.utr.fortis.nl, 09:35:16 on 2009-11-13.
220 Connection will close if idle for more than 50 minutes.
USER idsko
PASS ********
230 IDSKO is logged on. Working directory is "IDSKO.".
Session upkeep
SYST
FEAT
211 no Extensions supported
Connected
Got reply 1 to the command 1
Using FTP protocol.
PWD
257 "'IDSKO.'" is working directory.
Got reply 1 to the command 16
Changing directory to "/appl/was00t/log/glo".
Synchronizing current directory "'IDSKO.'".
CWD 'IDSKO.'
250 "IDSKO." is the working directory name prefix.
CWD /appl/was00t/log/glo
250 HFS directory /appl/was00t/log/glo is the current working directory
PWD
257 "/appl/was00t/log/glo" is the HFS working directory.
Retrieving directory listing...
TYPE A
200 Representation type is Ascii NonPrint
PORT 10,142,127,114,5,28
200 Port request OK.
LIST -a
125 List started OK
glo_offertetool_STC03714-glue.log
glo_offertetool_STC18880-glue.log
glo_offertetool_STC18880.log
glo_offertetool_STC18963-glue.log
glo_offertetool_STC18963-glue.log.1
glo_offertetool_STC18963-glue.log.2
glo_offertetool_STC18963-glue.log.3
glo_offertetool_STC18963-glue.log.4
glo_offertetool_STC18963-glue.log.5
glo_offertetool_STC18963.log
glo_offertetool_STC18963.log.1
glo_offertetool_STC18963.log.2
glo_offertetool_STC18963.log.3
glo_offertetool_STC18963.log.4
glo_offertetool_STC18963.log.5
glo_offertetool_STC19226-glue.log
glo_offertetool_STC19226.log
glo_offertetool_STC19709-glue.log
glo_offertetool_STC19709-glue.log.1
glo_offertetool_STC19709-glue.log.2
glo_offertetool_STC19709-glue.log.3
glo_offertetool_STC19709-glue.log.4
glo_offertetool_STC19709-glue.log.5
glo_offertetool_STC19709.log
glo_offertetool_STC19709.log.1
glo_offertetool_STC19709.log.2
glo_offertetool_STC19709.log.3
glo_offertetool_STC19709.log.4
glo_offertetool_STC19709.log.5
glo_offertetool_STC27107-glue.log
glo_offertetool_STC27107.log
glo_offertetool_STC27107.log.1
glo_offertetool_STC27107.log.2
glo_offertetool_STC27107.log.3
250 List completed successfully.
Directory listing successful
Got reply 1 to the command 2
Session upkeep
Session upkeep
Session upkeep
BertKoor
Hi there,
It's me again, but now I'm registered so you can contact me by email as well Wink
Oh, and regarding mjfuchs' issue: it looks like the remote directory "ZT01." does not exists. Can be set up under Environment - Directories - Remote Directory. Don't leave it empty!
BertKoor
I just noticed this in the log:
> TYPE A
Could that be why nothing is shown?
I do not know what that means.
dsargent
I'm having the same problem. Trying to connect to our mainframe.
Here is what WSFTP spits back as it is connecting.
Host type (S): IBM MVS
I've tried setting the remote directory the same as I do with WSFTP
PER.FTP.PER814.PPER0241
I get this error
Here is the log
WinSCP Version 4.2.4 (Build 610) (OS 5.2.3790 Service Pack 2)
Login time: Thursday, December 03, 2009 11:15:52 AM
Session name: HRSFTP@wsumvs1.it.wsu.edu
Host name: wsumvs1.it.wsu.edu (Port: 21)
User name: HRSFTP (Password: Yes, Key file: No)
Tunnel: No
Proxy: none
FTP: FTPS: Explicit SSL; Passive: No [Force IP: No]
Local directory: C:\Documents and Settings\dsargent!\My Documents, Remote directory: PER.FTP.PER814.PPER0241, Update: No, Cache: No
DST mode: 1
Connecting to wsumvs1.it.wsu.edu ...
Connected with wsumvs1.it.wsu.edu, negotiating SSL connection...
220-FTPD1 IBM FTP CS V1R9 at WSU0.IT.WSU.EDU, 19:16:25 on 2009-12-03.
220 Connection will close if idle for more than 5 minutes.
AUTH SSL
234 Security environment established - ready for negotiation
SSL connection established. Waiting for welcome message...
USER HRSFTP
PASS ********
230 HRSFTP is logged on. Working directory is "HRSFTP.".
SYST
FEAT
AUTH TLS
PBSZ
PROT
211 End
PBSZ 0
200 Protection buffer size accepted
PROT P
200 Data connection protection set to private
Connected
Using FTP protocol.
PWD
257 "'HRSFTP.'" is working directory.
Changing directory to "PER.FTP.PER814.PPER0241".
Synchronizing current directory "'HRSFTP.'".
CWD 'HRSFTP.'
250 "HRSFTP." is the working directory name prefix.
CWD PER.FTP.PER814.PPER0241
250 "HRSFTP.PER.FTP.PER814.PPER0241." is the working directory name prefix.
PWD
257 "'HRSFTP.PER.FTP.PER814.PPER0241.'" is working directory.
CWD /'HRSFTP.PER.FTP.PER814.PPER0241.'/'HRSFTP.PER.FTP.PER814.PPER0241.'/
(ECommand) Error listing directory ''HRSFTP.PER.FTP.PER814.PPER0241.''.
I'm using the latest beta as of yesterday.
4.2.4 build 610
Chris Curley
Do we have a workaround or fix for this problem ?
No.
