Topic "Simple one line /command to pull down a file"
appdevman
I'm new to this client, but not new to FTP in general.
I am building a c# application that will essentially just run ONE command-line entry, to pull down a file.
This is what I have so far, but it just wont work: (I put placeholders <private> where necc)
winscp SFTP://<private>:<private>@<private> /command get /Download/BIN/BIN20081107.txt exit
Using console i get this to work fine. I can't get it to work with one simple command though.
Also, can I use a UNC path as a target path for the destination?
I assume that would be right after the file location path, before exit?
THANKS!
Klaus Heim
It would help if you post output of the console.
Anyway, first obvious problem is quoting of the commands. This may work:
winscp SFTP://<private>:<private>@<private> /command "get /Download/BIN/BIN20081107.txt" exit
