Topic "System error code 32"
Theone5000
When i transfer files to the server, there are a few files that Winscp won't ignore. When the file comes Winscp gives me a system error. code 32
The process doesn't have any rights to the files and tell me if i should abort, retry or skip the file.
Can't open file 'C:\Documents and Settings\NetworkService\Local Settings\Applica
tion Data\Microsoft\Windows\UsrClass.dat'.
System Error.  Code: 32.
Het proces heeft geen toegang tot het bestand omdat
het bestand door een ander proces wordt gebruikt
(A)bort, (R)etry, (S)kip, Ski(p) all:
How can i disable this function so that winscp just goes through the file ignoring wether it's active or not.
Yu can use exclude mask.
