Topic "Cant connect to web.sourceforge.net"
hobiwan
I tried to upload files to my project web site at sourceforge using WinSCP. I cant connect to the web.sourceforge.net server. When trying SCP, I get:
. 2009-01-23 12:05:21.109 --------------------------------------------------------------------------
. 2009-01-23 12:05:21.109 WinSCP Version 4.1.8 (Build 415) (OS 5.1.2600 Service Pack 3)
. 2009-01-23 12:05:21.109 Login time: Freitag, 23. Jnner 2009 12:05:21
. 2009-01-23 12:05:21.109 Session name: test1
. 2009-01-23 12:05:21.109 Host name: web.sourceforge.net (Port: 22)
. 2009-01-23 12:05:27.015 Authentication successful
. 2009-01-23 12:05:27.015 Started session
. 2009-01-23 12:05:27.015 --------------------------------------------------------------------------
. 2009-01-23 12:05:27.015 Using SCP protocol.
. 2009-01-23 12:05:27.015 Doing startup conversation with host.
. 2009-01-23 12:05:27.031 Skipping host startup message (if any).
> 2009-01-23 12:05:27.031 echo "WinSCP: this is end-of-file:0"
< 2009-01-23 12:05:27.578 Welcome to frs.sourceforge.net
< 2009-01-23 12:05:27.578 This is a restricted Shell Account
< 2009-01-23 12:05:27.578 You cannot execute anything here.
. 2009-01-23 12:05:27.578 Server sent command exit status 1
. 2009-01-23 12:05:27.578 Disconnected
* 2009-01-23 12:05:27.609 (ESshFatal) Connection has been unexpectedly closed. Server sent command exit status 1.
* 2009-01-23 12:05:27.609 Error skipping startup message. Your shell is probably incompatible with the application (BASH is recommended).
According to sourceforge support this is expected (no commands can be executed via web.sourceforge.net).
Then I tried SFTP (which according to sf should work). It didnt. The error:
. 2009-01-23 11:47:06.015 --------------------------------------------------------------------------
. 2009-01-23 11:47:06.015 WinSCP Version 4.1.8 (Build 415) (OS 5.1.2600 Service Pack 3)
. 2009-01-23 11:47:06.015 Login time: Freitag, 23. Jnner 2009 11:47:06
. 2009-01-23 11:47:06.015 Session name: hobiwan,hodoku@web.sourceforge.net
. 2009-01-23 11:47:06.015 Host name: web.sourceforge.net (Port: 22)
. 2009-01-23 11:47:07.062 Authentication successful
. 2009-01-23 11:47:07.062 Started session
. 2009-01-23 11:47:07.062 --------------------------------------------------------------------------
. 2009-01-23 11:47:07.062 Using SFTP protocol.
. 2009-01-23 11:47:07.062 Doing startup conversation with host.
> 2009-01-23 11:47:07.062 Type: SSH_FXP_INIT, Size: 5, Number: -1
. 2009-01-23 11:47:07.296 Attempt to close connection due to fatal exception:
* 2009-01-23 11:47:07.296 Received too large (173499756 B) SFTP packet. Max supported packet size is 102400 B.
* 2009-01-23 11:47:07.296 The error is typically caused by message printed from startup script (like .profile). The message may start with "0x0A57656C".
. 2009-01-23 11:47:07.296 Closing connection.
. 2009-01-23 11:47:07.296 Sending special code: 12
. 2009-01-23 11:47:07.296 Sent EOF message
* 2009-01-23 11:47:07.312 (ESshFatal) Received too large (173499756 B) SFTP packet. Max supported packet size is 102400 B.
* 2009-01-23 11:47:07.312 The error is typically caused by message printed from startup script (like .profile). The message may start with "0x0A57656C".
* 2009-01-23 11:47:07.312 Cannot initialize SFTP protocol. Is the host running a SFTP server?
Is there a way to connect with WinSCP to web.sourceforge.net?
I found a workaround, but I would prefer the direct way.
Workaround:
    Connect to shell.sourceforge.net using PuTTY with "create" command
    Connect to shell.sourceforge.net using WinSCP and SCP
