Topic "Proxy connections using telnet"
RobertGonzalez
Not sure if I am asking this right or even in the right place. Forgive me if this is not correctly worded or asked in the wrong forum.
Right now our network setup (yes, I know, convoluted at best) is such that for me to get to one of our world accessible web servers I need to telnet into a machine (right now using putty) and then at the prompt issue the "connect hostname" command where hostname is the name of the machine I am really trying to get to. From there I am prompted with a username and password prompt after which, if I am authenticated, I am allowed shell access to the machine.
I know that WinSCP has the capability to proxy. What I am unsure of is how to set up the preliminary connection then the subsequent proxy connection so that I can get to the machine using WinSCP. I can do it using putty, but I would really love a GUI.
I have used HummingbirdFTP in the past, but it is a slug and would really like something better. Like WinSCP.
RobertGonzalez
... but the instructions are not working at all and I am not sure why. I have followed them to the "T" but WinSCP always dies when trying to hit the firewall. For the record, PuTTY does also when I try the same thing in it.
I am wondering if there is an issue with the \n or \r not be read properly. I have tried both \n and \r to no avail. I have not yet tried them together to see if that would have an affect on this. Regardless, the manual's instructions are not working for me at all.
http://winscp.net/eng/docs/ui_login_proxy#telnet_local_proxy_command
Please post a log file.
Crosspost
RobertGonzalez
Sorry for the double posting. I thought my original got buried because I replied to myself. I apologize for that.
Where is the WinSCP log? I can post it as soon as I find it.
See Logging tab of login dialog (you need to check Advanced options).
RobertGonzalez
This was the most recent attempt:
. 2009-02-02 10:05:01.016 --------------------------------------------------------------------------
. 2009-02-02 10:05:01.016 WinSCP Version 4.1.8 (Build 415) (OS 5.1.2600 Service Pack 2)
. 2009-02-02 10:05:01.016 Login time: Monday, February 02, 2009 10:05:01 AM
. 2009-02-02 10:05:01.016 Session name: Spaceley:via:Firewall:
. 2009-02-02 10:05:01.016 Host name: spaceley-dmz (Port: 22)
. 2009-02-02 10:05:01.016 User name: www-mgr (Password: Yes, Key file: No)
. 2009-02-02 10:05:01.016 Tunnel: No
. 2009-02-02 10:05:01.016 Transfer Protocol: SFTP (SCP)
. 2009-02-02 10:05:01.016 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2009-02-02 10:05:01.016 Proxy: Telnet
. 2009-02-02 10:05:01.016 HostName: firewall (Port: 23); Username: rgonzale; Passwd: Yes
. 2009-02-02 10:05:01.016 Telnet command: %user\r%pass\rconnect %host\r
. 2009-02-02 10:05:01.016 SSH protocol version: 2; Compression: No
. 2009-02-02 10:05:01.016 Bypass authentication: No
. 2009-02-02 10:05:01.016 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2009-02-02 10:05:01.016 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2009-02-02 10:05:01.016 SSH Bugs: -,-,-,-,-,-,-,-
. 2009-02-02 10:05:01.016 SFTP Bugs: -,-
. 2009-02-02 10:05:01.016 Return code variable: Autodetect; Lookup user groups: Yes
. 2009-02-02 10:05:01.016 Shell: default, EOL: 0
. 2009-02-02 10:05:01.016 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2009-02-02 10:05:01.016 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2009-02-02 10:05:01.016 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2009-02-02 10:05:01.016 Cache directory changes: Yes, Permanent: Yes
. 2009-02-02 10:05:01.016 DST mode: 1
. 2009-02-02 10:05:01.048 Looking up host "spaceley-dmz"
. 2009-02-02 10:05:01.048 Connecting to 192.168.100.241 port 23
. 2009-02-02 10:05:01.048 Selecting events 63 for socket 984
. 2009-02-02 10:05:01.048 Waiting for the server to continue with the initialisation
. 2009-02-02 10:05:01.048 Looking for incoming data
. 2009-02-02 10:05:01.048 Looking for network events
. 2009-02-02 10:05:01.048 Detected network event
. 2009-02-02 10:05:01.048 Enumerating network events for socket 984
. 2009-02-02 10:05:01.048 Enumerated 18 network events making 18 cumulative events for socket 984
. 2009-02-02 10:05:01.048 Handling network write event on socket 984 with error 0
. 2009-02-02 10:05:01.048 Handling network connect event on socket 984 with error 0
. 2009-02-02 10:05:01.063 Detected network event
. 2009-02-02 10:05:01.063 Enumerating network events for socket 984
. 2009-02-02 10:05:01.063 Enumerated 1 network events making 1 cumulative events for socket 984
. 2009-02-02 10:05:01.063 Handling network read event on socket 984 with error 0
. 2009-02-02 10:05:01.063 Selecting events 63 for socket 984
. 2009-02-02 10:05:01.063 Waiting for the server to continue with the initialisation
. 2009-02-02 10:05:01.063 Looking for incoming data
. 2009-02-02 10:05:01.063 Looking for network events
. 2009-02-02 10:05:01.235 Detected network event
. 2009-02-02 10:05:01.235 Enumerating network events for socket 984
. 2009-02-02 10:05:01.235 Enumerated 1 network events making 1 cumulative events for socket 984
. 2009-02-02 10:05:01.235 Handling network read event on socket 984 with error 0
. 2009-02-02 10:05:01.235 Waiting for the server to continue with the initialisation
. 2009-02-02 10:05:01.235 Looking for incoming data
. 2009-02-02 10:05:01.235 Looking for network events
. 2009-02-02 10:05:01.438 Detected network event
. 2009-02-02 10:05:01.438 Enumerating network events for socket 984
. 2009-02-02 10:05:01.438 Enumerated 1 network events making 1 cumulative events for socket 984
. 2009-02-02 10:05:01.438 Handling network read event on socket 984 with error 0
. 2009-02-02 10:05:01.438 Waiting for the server to continue with the initialisation
. 2009-02-02 10:05:01.438 Looking for incoming data
. 2009-02-02 10:05:01.438 Looking for network events
. 2009-02-02 10:05:01.641 Detected network event
. 2009-02-02 10:05:01.641 Enumerating network events for socket 984
. 2009-02-02 10:05:01.641 Enumerated 1 network events making 1 cumulative events for socket 984
. 2009-02-02 10:05:01.641 Handling network read event on socket 984 with error 0
. 2009-02-02 10:05:01.641 Waiting for the server to continue with the initialisation
. 2009-02-02 10:05:01.641 Looking for incoming data
. 2009-02-02 10:05:01.641 Looking for network events
. 2009-02-02 10:05:03.532 Detected network event
. 2009-02-02 10:05:03.532 Enumerating network events for socket 984
. 2009-02-02 10:05:03.532 Enumerated 1 network events making 1 cumulative events for socket 984
. 2009-02-02 10:05:03.532 Handling network read event on socket 984 with error 0
. 2009-02-02 10:05:03.532 Waiting for the server to continue with the initialisation
. 2009-02-02 10:05:03.532 Looking for incoming data
. 2009-02-02 10:05:03.532 Looking for network events
. 2009-02-02 10:05:05.532 Detected network event
. 2009-02-02 10:05:05.532 Enumerating network events for socket 984
. 2009-02-02 10:05:05.532 Enumerated 1 network events making 1 cumulative events for socket 984
. 2009-02-02 10:05:05.532 Handling network read event on socket 984 with error 0
. 2009-02-02 10:05:05.532 Waiting for the server to continue with the initialisation
. 2009-02-02 10:05:05.532 Looking for incoming data
. 2009-02-02 10:05:05.532 Looking for network events
. 2009-02-02 10:05:07.548 Detected network event
. 2009-02-02 10:05:07.548 Enumerating network events for socket 984
. 2009-02-02 10:05:07.548 Enumerated 1 network events making 1 cumulative events for socket 984
. 2009-02-02 10:05:07.548 Handling network read event on socket 984 with error 0
. 2009-02-02 10:05:07.548 Waiting for the server to continue with the initialisation
. 2009-02-02 10:05:07.548 Looking for incoming data
. 2009-02-02 10:05:07.548 Looking for network events
. 2009-02-02 10:05:07.673 Detected network event
. 2009-02-02 10:05:07.673 Enumerating network events for socket 984
. 2009-02-02 10:05:07.673 Enumerated 1 network events making 1 cumulative events for socket 984
. 2009-02-02 10:05:07.673 Handling network read event on socket 984 with error 0
. 2009-02-02 10:05:07.673 Waiting for the server to continue with the initialisation
. 2009-02-02 10:05:07.673 Looking for incoming data
. 2009-02-02 10:05:07.673 Looking for network events
. 2009-02-02 10:05:22.673 Timeout waiting for network events
. 2009-02-02 10:05:22.673 Waiting for data timed out, asking user what to do.
. 2009-02-02 10:05:22.673 Asking user:
. 2009-02-02 10:05:22.673 Host has not answered for 15 seconds.
. 2009-02-02 10:05:22.673 Wait for another 15 seconds? ()
. 2009-02-02 10:05:23.173 Pooling for data in case they finally arrives
. 2009-02-02 10:05:23.173 Looking for network events
. 2009-02-02 10:05:23.173 Timeout waiting for network events
. 2009-02-02 10:05:23.673 Pooling for data in case they finally arrives
. 2009-02-02 10:05:23.673 Looking for network events
. 2009-02-02 10:05:23.673 Timeout waiting for network events
. 2009-02-02 10:05:24.173 Pooling for data in case they finally arrives
. 2009-02-02 10:05:24.173 Looking for network events
. 2009-02-02 10:05:24.173 Timeout waiting for network events
. 2009-02-02 10:05:24.673 Pooling for data in case they finally arrives
. 2009-02-02 10:05:24.673 Looking for network events
. 2009-02-02 10:05:24.673 Timeout waiting for network events
. 2009-02-02 10:05:25.173 Pooling for data in case they finally arrives
. 2009-02-02 10:05:25.173 Looking for network events
. 2009-02-02 10:05:25.173 Timeout waiting for network events
. 2009-02-02 10:05:25.673 Pooling for data in case they finally arrives
. 2009-02-02 10:05:25.673 Looking for network events
. 2009-02-02 10:05:25.673 Timeout waiting for network events
. 2009-02-02 10:05:26.173 Pooling for data in case they finally arrives
. 2009-02-02 10:05:26.173 Looking for network events
. 2009-02-02 10:05:26.173 Timeout waiting for network events
. 2009-02-02 10:05:26.673 Pooling for data in case they finally arrives
. 2009-02-02 10:05:26.673 Looking for network events
. 2009-02-02 10:05:26.673 Timeout waiting for network events
. 2009-02-02 10:05:27.173 Pooling for data in case they finally arrives
. 2009-02-02 10:05:27.173 Looking for network events
. 2009-02-02 10:05:27.173 Timeout waiting for network events
. 2009-02-02 10:05:27.673 Pooling for data in case they finally arrives
. 2009-02-02 10:05:27.673 Looking for network events
. 2009-02-02 10:05:27.673 Timeout waiting for network events
. 2009-02-02 10:05:28.173 Pooling for data in case they finally arrives
. 2009-02-02 10:05:28.173 Looking for network events
. 2009-02-02 10:05:28.173 Timeout waiting for network events
. 2009-02-02 10:05:28.673 Pooling for data in case they finally arrives
. 2009-02-02 10:05:28.673 Looking for network events
. 2009-02-02 10:05:28.673 Timeout waiting for network events
. 2009-02-02 10:05:29.173 Pooling for data in case they finally arrives
. 2009-02-02 10:05:29.173 Looking for network events
. 2009-02-02 10:05:29.173 Timeout waiting for network events
. 2009-02-02 10:05:29.673 Pooling for data in case they finally arrives
. 2009-02-02 10:05:29.673 Looking for network events
. 2009-02-02 10:05:29.673 Timeout waiting for network events
. 2009-02-02 10:05:30.173 Pooling for data in case they finally arrives
. 2009-02-02 10:05:30.173 Looking for network events
. 2009-02-02 10:05:30.173 Timeout waiting for network events
. 2009-02-02 10:05:30.673 Pooling for data in case they finally arrives
. 2009-02-02 10:05:30.673 Looking for network events
. 2009-02-02 10:05:30.673 Timeout waiting for network events
. 2009-02-02 10:05:31.173 Pooling for data in case they finally arrives
. 2009-02-02 10:05:31.173 Looking for network events
. 2009-02-02 10:05:31.173 Timeout waiting for network events
. 2009-02-02 10:05:31.673 Pooling for data in case they finally arrives
. 2009-02-02 10:05:31.673 Looking for network events
. 2009-02-02 10:05:31.673 Timeout waiting for network events
. 2009-02-02 10:05:32.173 Pooling for data in case they finally arrives
. 2009-02-02 10:05:32.173 Looking for network events
. 2009-02-02 10:05:32.173 Timeout waiting for network events
. 2009-02-02 10:05:32.673 Pooling for data in case they finally arrives
. 2009-02-02 10:05:32.673 Looking for network events
. 2009-02-02 10:05:32.673 Timeout waiting for network events
. 2009-02-02 10:05:33.173 Pooling for data in case they finally arrives
. 2009-02-02 10:05:33.173 Looking for network events
. 2009-02-02 10:05:33.173 Timeout waiting for network events
. 2009-02-02 10:05:33.673 Pooling for data in case they finally arrives
. 2009-02-02 10:05:33.673 Looking for network events
. 2009-02-02 10:05:33.673 Timeout waiting for network events
. 2009-02-02 10:05:34.173 Pooling for data in case they finally arrives
. 2009-02-02 10:05:34.173 Looking for network events
. 2009-02-02 10:05:34.173 Timeout waiting for network events
. 2009-02-02 10:05:34.673 Pooling for data in case they finally arrives
. 2009-02-02 10:05:34.673 Looking for network events
. 2009-02-02 10:05:34.673 Timeout waiting for network events
. 2009-02-02 10:05:35.173 Pooling for data in case they finally arrives
. 2009-02-02 10:05:35.173 Looking for network events
. 2009-02-02 10:05:35.173 Timeout waiting for network events
. 2009-02-02 10:05:35.673 Pooling for data in case they finally arrives
. 2009-02-02 10:05:35.673 Looking for network events
. 2009-02-02 10:05:35.673 Timeout waiting for network events
. 2009-02-02 10:05:36.173 Pooling for data in case they finally arrives
. 2009-02-02 10:05:36.173 Looking for network events
. 2009-02-02 10:05:36.173 Timeout waiting for network events
. 2009-02-02 10:05:36.673 Pooling for data in case they finally arrives
. 2009-02-02 10:05:36.673 Looking for network events
. 2009-02-02 10:05:36.673 Timeout waiting for network events
. 2009-02-02 10:05:37.173 Pooling for data in case they finally arrives
. 2009-02-02 10:05:37.173 Looking for network events
. 2009-02-02 10:05:37.173 Timeout waiting for network events
. 2009-02-02 10:05:37.673 Pooling for data in case they finally arrives
. 2009-02-02 10:05:37.673 Looking for network events
. 2009-02-02 10:05:37.673 Timeout waiting for network events
. 2009-02-02 10:05:38.173 Pooling for data in case they finally arrives
. 2009-02-02 10:05:38.173 Looking for network events
. 2009-02-02 10:05:38.173 Timeout waiting for network events
. 2009-02-02 10:05:38.673 Pooling for data in case they finally arrives
. 2009-02-02 10:05:38.673 Looking for network events
. 2009-02-02 10:05:38.673 Timeout waiting for network events
. 2009-02-02 10:05:39.173 Pooling for data in case they finally arrives
. 2009-02-02 10:05:39.173 Looking for network events
. 2009-02-02 10:05:39.173 Timeout waiting for network events
. 2009-02-02 10:05:39.673 Pooling for data in case they finally arrives
. 2009-02-02 10:05:39.673 Looking for network events
. 2009-02-02 10:05:39.673 Timeout waiting for network events
. 2009-02-02 10:05:40.173 Pooling for data in case they finally arrives
. 2009-02-02 10:05:40.173 Looking for network events
. 2009-02-02 10:05:40.173 Timeout waiting for network events
. 2009-02-02 10:05:40.673 Pooling for data in case they finally arrives
. 2009-02-02 10:05:40.673 Looking for network events
. 2009-02-02 10:05:40.673 Timeout waiting for network events
. 2009-02-02 10:05:41.173 Pooling for data in case they finally arrives
. 2009-02-02 10:05:41.173 Looking for network events
. 2009-02-02 10:05:41.173 Timeout waiting for network events
. 2009-02-02 10:05:41.673 Pooling for data in case they finally arrives
. 2009-02-02 10:05:41.673 Looking for network events
. 2009-02-02 10:05:41.673 Timeout waiting for network events
. 2009-02-02 10:05:42.173 Pooling for data in case they finally arrives
. 2009-02-02 10:05:42.173 Looking for network events
. 2009-02-02 10:05:42.173 Timeout waiting for network events
. 2009-02-02 10:05:42.673 Pooling for data in case they finally arrives
. 2009-02-02 10:05:42.673 Looking for network events
. 2009-02-02 10:05:42.673 Timeout waiting for network events
. 2009-02-02 10:05:43.173 Pooling for data in case they finally arrives
. 2009-02-02 10:05:43.173 Looking for network events
. 2009-02-02 10:05:43.173 Timeout waiting for network events
. 2009-02-02 10:05:43.673 Pooling for data in case they finally arrives
. 2009-02-02 10:05:43.673 Looking for network events
. 2009-02-02 10:05:43.673 Timeout waiting for network events
. 2009-02-02 10:05:44.173 Pooling for data in case they finally arrives
. 2009-02-02 10:05:44.173 Looking for network events
. 2009-02-02 10:05:44.173 Timeout waiting for network events
. 2009-02-02 10:05:44.673 Pooling for data in case they finally arrives
. 2009-02-02 10:05:44.673 Looking for network events
. 2009-02-02 10:05:44.673 Timeout waiting for network events
. 2009-02-02 10:05:45.173 Pooling for data in case they finally arrives
. 2009-02-02 10:05:45.173 Looking for network events
. 2009-02-02 10:05:45.173 Timeout waiting for network events
. 2009-02-02 10:05:45.673 Pooling for data in case they finally arrives
. 2009-02-02 10:05:45.673 Looking for network events
. 2009-02-02 10:05:45.673 Timeout waiting for network events
. 2009-02-02 10:05:46.173 Pooling for data in case they finally arrives
. 2009-02-02 10:05:46.173 Looking for network events
. 2009-02-02 10:05:46.173 Timeout waiting for network events
. 2009-02-02 10:05:46.673 Pooling for data in case they finally arrives
. 2009-02-02 10:05:46.673 Looking for network events
. 2009-02-02 10:05:46.673 Timeout waiting for network events
. 2009-02-02 10:05:46.782 Attempt to close connection due to fatal exception:
* 2009-02-02 10:05:46.782 Terminated by user.
. 2009-02-02 10:05:46.782 Closing connection.
. 2009-02-02 10:05:46.782 Sending special code: 12
. 2009-02-02 10:05:46.782 Selecting events 0 for socket 984
* 2009-02-02 10:05:46.798 (ESshFatal) Terminated by user.
Does the log look the same if you use \n instead of \r?
RobertGonzalez
Yeah, pretty much the same thing:
. 2009-02-04 09:44:36.369 --------------------------------------------------------------------------
. 2009-02-04 09:44:36.369 WinSCP Version 4.1.8 (Build 415) (OS 5.1.2600 Service Pack 2)
. 2009-02-04 09:44:36.369 Login time: Wednesday, February 04, 2009 9:44:36 AM
. 2009-02-04 09:44:36.369 Session name: Spaceley:via:Firewall:
. 2009-02-04 09:44:36.369 Host name: spaceley-dmz (Port: 22)
. 2009-02-04 09:44:36.369 User name: www-mgr (Password: Yes, Key file: No)
. 2009-02-04 09:44:36.369 Tunnel: No
. 2009-02-04 09:44:36.369 Transfer Protocol: SFTP (SCP)
. 2009-02-04 09:44:36.369 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2009-02-04 09:44:36.369 Proxy: Telnet
. 2009-02-04 09:44:36.369 HostName: firewall (Port: 23); Username: rgonzale; Passwd: Yes
. 2009-02-04 09:44:36.369 Telnet command: %user\n%pass\nconnect %host\n
. 2009-02-04 09:44:36.369 SSH protocol version: 2; Compression: No
. 2009-02-04 09:44:36.369 Bypass authentication: No
. 2009-02-04 09:44:36.369 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2009-02-04 09:44:36.369 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2009-02-04 09:44:36.369 SSH Bugs: -,-,-,-,-,-,-,-
. 2009-02-04 09:44:36.369 SFTP Bugs: -,-
. 2009-02-04 09:44:36.369 Return code variable: Autodetect; Lookup user groups: Yes
. 2009-02-04 09:44:36.369 Shell: default, EOL: 0
. 2009-02-04 09:44:36.369 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2009-02-04 09:44:36.369 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2009-02-04 09:44:36.369 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2009-02-04 09:44:36.369 Cache directory changes: Yes, Permanent: Yes
. 2009-02-04 09:44:36.369 DST mode: 1
. 2009-02-04 09:44:36.415 Looking up host "spaceley-dmz"
. 2009-02-04 09:44:36.415 Connecting to 192.168.100.241 port 23
. 2009-02-04 09:44:36.494 Selecting events 63 for socket 672
. 2009-02-04 09:44:36.494 Waiting for the server to continue with the initialisation
. 2009-02-04 09:44:36.494 Looking for incoming data
. 2009-02-04 09:44:36.494 Looking for network events
. 2009-02-04 09:44:36.494 Detected network event
. 2009-02-04 09:44:36.494 Enumerating network events for socket 672
. 2009-02-04 09:44:36.494 Enumerated 18 network events making 18 cumulative events for socket 672
. 2009-02-04 09:44:36.494 Handling network write event on socket 672 with error 0
. 2009-02-04 09:44:36.494 Handling network connect event on socket 672 with error 0
. 2009-02-04 09:44:36.509 Detected network event
. 2009-02-04 09:44:36.509 Enumerating network events for socket 672
. 2009-02-04 09:44:36.509 Enumerated 1 network events making 1 cumulative events for socket 672
. 2009-02-04 09:44:36.509 Handling network read event on socket 672 with error 0
. 2009-02-04 09:44:36.509 Selecting events 63 for socket 672
. 2009-02-04 09:44:36.509 Waiting for the server to continue with the initialisation
. 2009-02-04 09:44:36.509 Looking for incoming data
. 2009-02-04 09:44:36.509 Looking for network events
. 2009-02-04 09:44:36.619 Detected network event
. 2009-02-04 09:44:36.619 Enumerating network events for socket 672
. 2009-02-04 09:44:36.619 Enumerated 1 network events making 1 cumulative events for socket 672
. 2009-02-04 09:44:36.619 Handling network read event on socket 672 with error 0
. 2009-02-04 09:44:36.619 Waiting for the server to continue with the initialisation
. 2009-02-04 09:44:36.619 Looking for incoming data
. 2009-02-04 09:44:36.619 Looking for network events
. 2009-02-04 09:44:36.822 Detected network event
. 2009-02-04 09:44:36.822 Enumerating network events for socket 672
. 2009-02-04 09:44:36.822 Enumerated 1 network events making 1 cumulative events for socket 672
. 2009-02-04 09:44:36.822 Handling network read event on socket 672 with error 0
. 2009-02-04 09:44:36.822 Waiting for the server to continue with the initialisation
. 2009-02-04 09:44:36.822 Looking for incoming data
. 2009-02-04 09:44:36.822 Looking for network events
. 2009-02-04 09:44:37.025 Detected network event
. 2009-02-04 09:44:37.025 Enumerating network events for socket 672
. 2009-02-04 09:44:37.025 Enumerated 1 network events making 1 cumulative events for socket 672
. 2009-02-04 09:44:37.025 Handling network read event on socket 672 with error 0
. 2009-02-04 09:44:37.025 Waiting for the server to continue with the initialisation
. 2009-02-04 09:44:37.025 Looking for incoming data
. 2009-02-04 09:44:37.025 Looking for network events
. 2009-02-04 09:44:38.978 Detected network event
. 2009-02-04 09:44:38.978 Enumerating network events for socket 672
. 2009-02-04 09:44:38.978 Enumerated 1 network events making 1 cumulative events for socket 672
. 2009-02-04 09:44:38.978 Handling network read event on socket 672 with error 0
. 2009-02-04 09:44:38.978 Waiting for the server to continue with the initialisation
. 2009-02-04 09:44:38.978 Looking for incoming data
. 2009-02-04 09:44:38.978 Looking for network events
. 2009-02-04 09:44:40.978 Detected network event
. 2009-02-04 09:44:40.978 Enumerating network events for socket 672
. 2009-02-04 09:44:40.978 Enumerated 1 network events making 1 cumulative events for socket 672
. 2009-02-04 09:44:40.978 Handling network read event on socket 672 with error 0
. 2009-02-04 09:44:40.978 Waiting for the server to continue with the initialisation
. 2009-02-04 09:44:40.978 Looking for incoming data
. 2009-02-04 09:44:40.978 Looking for network events
. 2009-02-04 09:44:42.994 Detected network event
. 2009-02-04 09:44:42.994 Enumerating network events for socket 672
. 2009-02-04 09:44:42.994 Enumerated 1 network events making 1 cumulative events for socket 672
. 2009-02-04 09:44:42.994 Handling network read event on socket 672 with error 0
. 2009-02-04 09:44:42.994 Waiting for the server to continue with the initialisation
. 2009-02-04 09:44:42.994 Looking for incoming data
. 2009-02-04 09:44:42.994 Looking for network events
. 2009-02-04 09:44:43.150 Detected network event
. 2009-02-04 09:44:43.150 Enumerating network events for socket 672
. 2009-02-04 09:44:43.150 Enumerated 1 network events making 1 cumulative events for socket 672
. 2009-02-04 09:44:43.150 Handling network read event on socket 672 with error 0
. 2009-02-04 09:44:43.150 Waiting for the server to continue with the initialisation
. 2009-02-04 09:44:43.150 Looking for incoming data
. 2009-02-04 09:44:43.150 Looking for network events
. 2009-02-04 09:44:58.150 Timeout waiting for network events
. 2009-02-04 09:44:58.150 Waiting for data timed out, asking user what to do.
. 2009-02-04 09:44:58.150 Asking user:
. 2009-02-04 09:44:58.150 Host has not answered for 15 seconds.
. 2009-02-04 09:44:58.150 Wait for another 15 seconds? ()
. 2009-02-04 09:44:58.650 Pooling for data in case they finally arrives
. 2009-02-04 09:44:58.650 Looking for network events
. 2009-02-04 09:44:58.650 Timeout waiting for network events
. 2009-02-04 09:44:59.150 Pooling for data in case they finally arrives
. 2009-02-04 09:44:59.150 Looking for network events
. 2009-02-04 09:44:59.150 Timeout waiting for network events
. 2009-02-04 09:44:59.650 Pooling for data in case they finally arrives
. 2009-02-04 09:44:59.650 Looking for network events
. 2009-02-04 09:44:59.650 Timeout waiting for network events
. 2009-02-04 09:45:00.150 Pooling for data in case they finally arrives
. 2009-02-04 09:45:00.150 Looking for network events
. 2009-02-04 09:45:00.150 Timeout waiting for network events
. 2009-02-04 09:45:00.650 Pooling for data in case they finally arrives
. 2009-02-04 09:45:00.650 Looking for network events
. 2009-02-04 09:45:00.650 Timeout waiting for network events
. 2009-02-04 09:45:01.150 Pooling for data in case they finally arrives
. 2009-02-04 09:45:01.150 Looking for network events
. 2009-02-04 09:45:01.150 Timeout waiting for network events
. 2009-02-04 09:45:01.650 Pooling for data in case they finally arrives
. 2009-02-04 09:45:01.650 Looking for network events
. 2009-02-04 09:45:01.650 Timeout waiting for network events
. 2009-02-04 09:45:02.150 Pooling for data in case they finally arrives
. 2009-02-04 09:45:02.150 Looking for network events
. 2009-02-04 09:45:02.150 Timeout waiting for network events
. 2009-02-04 09:45:02.650 Pooling for data in case they finally arrives
. 2009-02-04 09:45:02.650 Looking for network events
. 2009-02-04 09:45:02.650 Timeout waiting for network events
. 2009-02-04 09:45:03.150 Attempt to close connection due to fatal exception:
* 2009-02-04 09:45:03.150 Terminated by user.
. 2009-02-04 09:45:03.150 Closing connection.
. 2009-02-04 09:45:03.150 Sending special code: 12
. 2009-02-04 09:45:03.150 Selecting events 0 for socket 672
* 2009-02-04 09:45:03.150 (ESshFatal) Terminated by user.
OK, what you are trying this using putty, does anything show up on the terminal window before it dies?
RobertGonzalez
When I do this in putty this is the output (I have asterisked out the domain names for security):
Username: rgonzale
Password: ############
Login Accepted
*****.********.com telnet proxy (Version V6.0) ready:
telnet>
From there I issue the connect <hostname> command:
telnet>connect spaceley-dmz
Trying 192.168.1.50 port 23...
Connected to spaceley-dmz.
    ********.********.com (Linux release 2.6.9-42.0.3.ELsmp #1 SMP Mon Sep 25 17:28:02 EDT 2006) (1)
login: *******
Password for *******:
login: Cannot resolve network address for KDC in requested realm while getting initial credentials
Last login: Wed Feb  4 10:25:24 from fw-dmz
[www-mgr@<host> ~]$
So that is the interaction in PuTTY.
I've meant the case when you try to use the proxy command with PuTTY.
RobertGonzalez
I haven't gotten that to work yet either. The interface is different in PuTTY than WinSCP. I was trying to look for the similarities but haven't found the right combination yet.
For the time being I am going to go back to Hummingbird. But if I can get through this with WinSCP I would be overjoyed. Hummingbird sucks on so many levels.
