Topic "WinSCP 4.1.8 freeze on changing local directory"
thankfuluser
Hi, I use 4.1.8 to connect via SFTP in Norton Command view on Win XP SP 3. When I try to change local folder from D:\My Documents to E:\ after program start via the drive dropdown list the program freezes in 50-75% of all cases and I have to kill it via task manager. If it does not freeze, everything works fine after directory change.
This problem might be related to the fact that I have moved the document folder from E: to D: I suspect a bug or problem with the proper handling of CSIDL_PERSONAL/CSIDL_MYDOCUMENTS.
Also, this problem could be easily circumvented if WinSCP would not ignore any specific startup folder specified in a windows shortcut (I would just give the proper local dir as startup dir and hopefully prevent the freeze that way)
Thanks & keep up the good work!
Can you provide me your email address, so I can send you a debug version of WinSCP to track the problem? If you do not want to post the address here, you can send me an email. You will find my address (if you log in) in my forum profile. Please include link to this topic. Thanks.
thankful
Thank you for such a fast reply. Not at all, send it to <removed>.
Am I correct that winscp currently ignores any start folder settings? If so, I would gladly like to submit that as a feature request.
Thanks again!
Will do soon.
Correct. You can specify initial local directory on Directories tab of login dialog. If I make WinSCP start in startup folder by default, it would affect existing installations. All the icons created by previous versions have icons setup with startup folder in installation folder.
Same problem. 100% reproducible.
Very useful pice of information. Thanks.
x_art
I've sent you an email with problem description and a screenshot.
Pallieter
I run Vista Pro 32-bit, even with only 1 session open if I wait a while WinSCP will freeze (have now had it happen 30+ times, even after a reboot).
Can you send me an email, so I can send you back a debug version of WinSCP to track the problem? You will find my address (if you log in) in my forum profile. Please include link back to this topic. Thanks.
