Topic ""Could not delete /Volume/file: No such file or directory""
lutfisk
Hi!
I am having i problem with deleting files on a ftp with WinSCP. It works in Filezilla, but i prefer to use winscp!
the log:
DELE /Volume/file
550 Could not delete /Volume/file: No such file or directory
Asking user:
Fel vid borttagning av filen 'file'. ("Could not delete /Volume/file: No such file or directory")
but in filezilla log:
Command: DELE File
Answer: 250 Deleted File
the server is on a d-link dns-323
please help! i have searched everywhere Sad
Can you post a log file from Filezilla as well?
lutfisk
thank you for your reply!
I am not home atm, but the log says nothing fancy what i can tell. The difference between winscp and filezilla log seems like when winscp includes file directory when executing the delete command, filezilla does not. if i manually write "DELE [filename]" in winscp, it works.
i can post full log when i come home if you want.
lutfisk
winscp log:
Ansluter till XXXXXXXXXXXXXXX ...
Ansluten med XXXXXXXXXXXXX. Vntar p vlkomstmeddelande...
220---------- Welcome to Pure-FTPd ----------
220-You are user number 1 of 10 allowed.
220-Local time is now 16:50. Server port: 21.
220 You will be disconnected after 10 minutes of inactivity.
USER XXXXXXXXXXXXX
331 User XXXXXXXXX OK. Password required
PASS ************
230 OK. Current restricted directory is /
SYST
215 UNIX Type: L8
FEAT
211-Extensions supported:
EPRT
IDLE
MDTM
SIZE
REST STREAM
MLST type*;size*;sizd*;modify*;UNIX.mode*;UNIX.uid*;UNIX.gid*;unique*;
MLSD
TVFS
ESTP
PASV
EPSV
SPSV
ESTA
211 End.
Ansluten
Using FTP protocol.
Doing startup conversation with host.
PWD
257 "/" is your current location
Getting current directory name.
terfr listing av kataloger...
TYPE A
200 TYPE is now ASCII
PORT 192,168,0,192,192,176
200 PORT command successful
LIST -a
150 Connecting to port 64091
226-Options: -a -l
226 5 matches total
Listing av kataloger lyckad
Startup conversation with host finished.
Cached directory change via "Volume_2" to "/Volume_2".
CWD /Volume_2/
250 OK. Current directory is /Volume_2
PWD
257 "/Volume_2" is your current location
TYPE A
PORT 192,168,0,192,192,177
LIST -a
150 Connecting to port 60143
226-Options: -a -l
226 8 matches total
Deleting file ".DS_Store".
DELE /Volume_2/.DS_Store
550 Could not delete /Volume_2/.DS_Store: No such file or directory
Asking user:
Fel vid borttagning av filen '.DS_Store'. ("Could not delete /Volume_2/.DS_Store: No such file or directory")
full filezilla log:
Status: Ansluter till XXXXXXXXXXXX...
Status: Anslutningen etablerad, vntar p vlkomstmeddelande...
Svar: 220---------- Welcome to Pure-FTPd ----------
Svar: 220-You are user number 2 of 10 allowed.
Svar: 220-Local time is now 16:52. Server port: 21.
Svar: 220 You will be disconnected after 10 minutes of inactivity.
Kommando: USER XXXXXXX
Svar: 331 User XXXXXXXX OK. Password required
Kommando: PASS ************
Svar: 230 OK. Current restricted directory is /
Status: Ansluten
Status: Hmtar kataloglistning...
Kommando: PWD
Svar: 257 "/" is your current location
Kommando: TYPE I
Svar: 200 TYPE is now 8-bit binary
Kommando: PORT 192,168,0,192,192,215
Svar: 200 PORT command successful
Kommando: LIST
Svar: 150 Connecting to port 61311
Svar: 226-ASCII
Svar: 226-Options: -l
Svar: 226 3 matches total
Kommando: PORT 192,168,0,192,192,216
Kommando: LIST -a
Svar: 150 Connecting to port 61655
Svar: 226-ASCII
Svar: 226-Options: -a -l
Svar: 226 5 matches total
Status: Kataloglistningen lyckades
Kommando: CWD Volume_2
Svar: 250 OK. Current directory is /Volume_2
Kommando: PWD
Svar: 257 "/Volume_2" is your current location
Kommando: PORT 192,168,0,192,192,217
Kommando: LIST -a
Svar: 150 Connecting to port 61939
Svar: 226-ASCII
Svar: 226 8 matches total
Status: Berknar serverns tidzonsskillnad...
Kommando: MDTM .DS_Store
Svar: 213 20081203234135
Status: Tidszonsskillnader: Servern: 0 sekunder. Lokalt: 3600 sekunder. Skillnad: 3600 sekunder.
Kommando: DELE .DS_Store
Svar: 250 Deleted .DS_Store
OK, so it seems rather like server-side bug, doesn't it?
According to FTP specification DELE command is followed by path to a file (not only a filename).
