Topic "Scripting: "Keine Sitzung""
DGorthat
thanks for the very helpfull piece of software.
I am using the batch jobs connecting to different sftp servers doing different copy and move jobs with no problems yet.
Now I tried to create a another job to a new server where I get a problem with a message that the session is not started.
option batch on
open USERNAME:PASSWORD@SERVER
option transfer binary
put localfile /target/
The log from winscp.com gives the following results:
batch on
confirm off
transfer binary
Keine Sitzung
When I do a manual login doing the folliwing steps, it works:
option batch on
open (wait for "Enter the hostname")
SERVER (wait for "Enter the username:" answere of the server)
USERNAME (wait for "Enter the password:" answer of the server)
PASSWORD
I am using WinSCP.com Version 2.0.0.84, Winscp.exe 4.0.7.370.
Is this a configuration problem on the server? Or is there anything I can do on winscp side?
The reason why I am running the old version of winscp is that the server on which winscp is currently running will be changed in the next weeks. I plan an update to the newest version of winscp not before that server update.
Thank you in advance
Dirk
Please send me your script file by an email. You will find my address (if you log in) in my forum profile. Please include link to this topic. Thanks.
This bug has been added to tracker.
