Topic "Timing out at the root level"
aldog
V4.0.7 (Build 370)
When connected with SCP to a Linux host running redhat 3.8, if I try to go to the root (/) level, get the message "Host has not answered for more than 15. Still waiting..."
But can click the folder icon and type in "/etc/.." to bypass the GUI selection process.
Running on Windows.
Works on another Linux system of the same build. I'm looking into it further and looking for any assistance.
Al
Can you post a log file?
aldog
This is the log after logging in and before selecting the "/" directory.
Logged in as root and the home directory (/root) listed fine.
Also incresed the "Server response timeout" to 60 from the default of 15 seconds.
Al
< 2009-02-05 16:11:09.187 -rw-r--r-- 1 root root 27805 2008-04-08 16:44:33.000000000 -0600 rpm_list_080408
< 2009-02-05 16:11:09.187 -rw-r--r-- 1 root root 28077 2008-04-08 17:06:10.000000000 -0600 rpm_list_080408_post_update
< 2009-02-05 16:11:09.187 drwxr-xr-x 2 root root 4096 2008-05-20 16:57:16.000000000 -0600 scripts
< 2009-02-05 16:11:09.187 WinSCP: this is end-of-file:0
. 2009-02-05 16:11:09.203 Directory listing with --full-time succeed, next time all errors during directory listing will be displayed immediatelly.
. 2009-02-05 16:11:09.203 Startup conversation with host finished.
. 2009-02-05 16:11:13.609 Cached directory change via "/" to "/".
. 2009-02-05 16:11:13.609 Getting current directory name.
. 2009-02-05 16:11:13.609 Listing current directory.
. 2009-02-05 16:11:13.609 Locating to cached directory "/".
> 2009-02-05 16:11:13.609 cd "/" ; echo "WinSCP: this is end-of-file:$?"
< 2009-02-05 16:11:13.640 WinSCP: this is end-of-file:0
> 2009-02-05 16:11:13.640 ls -la --full-time ; echo "WinSCP: this is end-of-file:$?"
. 2009-02-05 16:12:13.640 Waiting for data timed out, asking user what to do.
. 2009-02-05 16:12:13.640 Asking user:
. 2009-02-05 16:12:13.640 Host has not answered for 60 seconds.
. 2009-02-05 16:12:13.640 Wait for another 60 seconds? ()
. 2009-02-05 16:12:27.812 Attempt to close connection due to fatal exception:
* 2009-02-05 16:12:27.812 Terminated by user.
. 2009-02-05 16:12:27.812 Closing connection.
* 2009-02-05 16:12:27.812 (ESshFatal) Terminated by user.
* 2009-02-05 16:12:27.812 Error listing directory '/'.
* 2009-02-05 16:12:27.812 Error changing directory to '/'.
Well the server simply does not respond.
Have you tried SFTP?
aldog
That's the odd part. I can manually enter "/etc" for example and will work.
I can also do this on some Linux boxes but not this one.
I'm even logged in a root.
SFTP is similar. I just can get a listing of /.
What is similar about SFTP, if you can get to the root?
aldog
I meant "can't".
SFTP is also timing out when listing /.
I'll send you a debug version soon.
