Topic "login sourceforge.net with winscp"
benbenqiao
Hi:
I try to login sourceforge with winscp, and I am really new for both sourceforge and winscp. When I login, I always get the error msg:
Error skipping startup message. Your shell is probably incompatible with the application (BASH is recommended).
I have upload the ssh key to sourceforge account,and I change it many times , but don't work.
Should I do any setting to sf account or winscp?
and here is my login log:
. 2009-02-07 22:26:34.671 --------------------------------------------------------------------------
. 2009-02-07 22:26:34.671 WinSCP Version 4.1.8 (Build 415) (OS 6.0.6001 Service Pack 1)
. 2009-02-07 22:26:34.671 Login time: Saturday, February 07, 2009 10:26:34 PM
. 2009-02-07 22:26:34.671 Session name: tianzhuqiao,bsmedit@shell.sourceforge.net
. 2009-02-07 22:26:34.671 Host name: shell.sourceforge.net (Port: 22)
. 2009-02-07 22:26:34.671 User name: tianzhuqiao,bsmedit (Password: Yes, Key file: Yes)
. 2009-02-07 22:26:34.671 Tunnel: No
. 2009-02-07 22:26:34.671 Transfer Protocol: SCP
. 2009-02-07 22:26:34.671 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2009-02-07 22:26:34.671 Proxy: none
. 2009-02-07 22:26:34.671 SSH protocol version: 2; Compression: No
. 2009-02-07 22:26:34.671 Bypass authentication: No
. 2009-02-07 22:26:34.671 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2009-02-07 22:26:34.671 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2009-02-07 22:26:34.671 SSH Bugs: -,-,-,-,-,-,-,-
. 2009-02-07 22:26:34.671 SFTP Bugs: -,-
. 2009-02-07 22:26:34.671 Return code variable: Autodetect; Lookup user groups: Yes
. 2009-02-07 22:26:34.671 Shell: /bin/bash, EOL: 0
. 2009-02-07 22:26:34.671 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2009-02-07 22:26:34.671 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2009-02-07 22:26:34.671 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2009-02-07 22:26:34.671 Cache directory changes: Yes, Permanent: Yes
. 2009-02-07 22:26:34.671 DST mode: 1
. 2009-02-07 22:26:34.827 Looking up host "shell.sourceforge.net"
. 2009-02-07 22:26:34.827 Connecting to 216.34.181.119 port 22
. 2009-02-07 22:26:35.701 Server version: SSH-1.99-OpenSSH_5.1
. 2009-02-07 22:26:35.701 We claim version: SSH-2.0-WinSCP_release_4.1.8
. 2009-02-07 22:26:35.701 SSPI: acquired credentials for: Tianzhu@Tianzhu-PC
. 2009-02-07 22:26:35.701 Constructed service principal name 'host/shell.sourceforge.net'
. 2009-02-07 22:26:35.701 GSSKEX disabled: No credentials are available in the security package
. 2009-02-07 22:26:35.701 Using SSH protocol version 2
. 2009-02-07 22:26:36.013 Doing Diffie-Hellman group exchange
. 2009-02-07 22:26:36.933 Doing Diffie-Hellman key exchange with hash SHA-1
. 2009-02-07 22:26:37.619 Host key fingerprint is:
. 2009-02-07 22:26:37.619 ssh-rsa 2048 b4:c5:6c:36:f7:ad:2c:23:52:e1:84:3e:77:61:5d:59
. 2009-02-07 22:26:37.619 Initialised AES-256 SDCTR client->server encryption
. 2009-02-07 22:26:37.619 Initialised HMAC-SHA1 client->server MAC algorithm
. 2009-02-07 22:26:37.619 Initialised AES-256 SDCTR server->client encryption
. 2009-02-07 22:26:37.619 Initialised HMAC-SHA1 server->client MAC algorithm
. 2009-02-07 22:26:38.462 Reading private key file "C:\qiaotz\download\sourceforge-ssh\prt.ppk"
! 2009-02-07 22:26:38.462 Using username "tianzhuqiao,bsmedit".
. 2009-02-07 22:26:39.055 Offered public key
. 2009-02-07 22:26:40.615 Offer of public key accepted
! 2009-02-07 22:26:40.615 Authenticating with public key "tianzhuqiao@shell.sourceforge.net"
. 2009-02-07 22:26:40.630 Prompt (2, SSH key passphrase, , Passphrase for key "tianzhuqiao@shell.sourceforge.net": )
. 2009-02-07 22:26:46.153 Access granted
. 2009-02-07 22:26:46.449 Opened channel for session
. 2009-02-07 22:26:46.761 Started a shell/command
. 2009-02-07 22:26:46.761 --------------------------------------------------------------------------
. 2009-02-07 22:26:46.761 Using SCP protocol.
. 2009-02-07 22:26:46.777 Doing startup conversation with host.
. 2009-02-07 22:26:46.777 Skipping host startup message (if any).
> 2009-02-07 22:26:46.777 echo "WinSCP: this is end-of-file:0"
! 2009-02-07 22:26:47.385 You don't have an active shell at this time. For basic file transfers and
! 2009-02-07 22:26:47.385 management, use web.sourceforge.net -- it allows rsync, sftp, and scp access.
! 2009-02-07 22:26:47.385 If you would like to create a shell, use ssh to login using a USER,PROJECT
! 2009-02-07 22:26:47.385 username with the "create" command. If you tell ssh to allocate a tty
! 2009-02-07 22:26:47.385 (e.g. using -t), an interactive shell will be opened when the create is
! 2009-02-07 22:26:47.385 done. Otherwise, the create command will exit when the shell becomes
! 2009-02-07 22:26:47.385 ready for use. An example create that enters the shell when ready:
! 2009-02-07 22:26:47.385 ssh -t USER,PROJECT@shell.sourceforge.net create
. 2009-02-07 22:26:47.385 Server sent command exit status 1
. 2009-02-07 22:26:47.385 Disconnected: All channels closed
* 2009-02-07 22:26:47.385 (ESshFatal) Connection has been unexpectedly closed. Server sent command exit status 1.
* 2009-02-07 22:26:47.385 Error skipping startup message. Your shell is probably incompatible with the application (BASH is recommended).
Well have you red the message you can see in the log?
