Topic "Timeout detected. Could not retrieve directory listing"
Lauri
I just downloaded WinSCP. I've tried and tried to get it to connect to the server, but it doesn't work. I've been through the FAQ and all but couldn't find anything to help. this is the error message that I get:
Timeout detected.
Opening ASCII mode data connection for /bin/ls.
Error listing directory '/'.
Can you help me?
Lauri
I'm not sure what you wanted me to see in the documentation. I've uninstalled and re-installed, checked and double checked my settings, host name, passwords, etc., tried both passive and active, and sitll cannot get through to the server. Here's the error message I'm getting now:
Can't open data connection.
It says that it is connected but each time it tries to retrieve the directory it fails. I know that other people are getting through to this server with WinSCP - what is going wrong for me?
Please HELP!
Please post a full log file showing failure with passive mode.
Lauri
SYST
215 Windows_NT
FEAT
211-FEAT
SIZE
MDTM
211 END
Connected
Using FTP protocol.
Doing startup conversation with host.
PWD
257 "/" is current directory.
Getting current directory name.
Retrieving directory listing...
TYPE A
200 Type set to A.
PORT 192,168,1,47,15,209
200 PORT command successful.
LIST -a
150 Opening ASCII mode data connection for /bin/ls.
425 Can't open data connection.
TYPE A
200 Type set to A.
PORT 192,168,1,47,15,211
LIST
(ECommand) Error listing directory '/'.
Startup conversation with host finished.
TYPE A
200 Type set to A.
TYPE A
200 Type set to A.
You haven't posted full log file, so I cannot tell for sure. But from the IP address I suspect this issue is what you are facing.
Lauri
Please explain to me how to get the full log file. Or explain how I can fix this problem.
You cannot fix it. But the problem is tracker already, so it will be resolved eventually.
Lauri wrote:
SYST
215 Windows_NT
FEAT
211-FEAT
SIZE
MDTM
211 END
Connected
Using FTP protocol.
PWD
TYPE A
200 Type set to A.
LIST -a
TYPE A
200 Type set to A.
LIST
TYPE A
200 Type set to A.
TYPE A
200 Type set to A.
Are you using PASSIVE (PASV) connection? If so, you'll need to configure your client accordingly and ensure the proper PASV ports are open on your firewall if you are accessing your FTP server through one. FTP server admin, if other than you, will know the PASSIVE port range.
grouver
Hi, this is a bit old however the problem is STILL not solved. It has been getting on my nerves for a while and if there were decent free Windows FTP clients I would have given up on WinSCP a long time ago. Anyway, my rants aside, here is a work around that you might find useful. If you notice, the error message usually suggests that you try passive mode due to inability to open some port. Now there might be any reasons why a port cannot be opened and WinSCP cannot really change that. Nonetheless the software should be able to automatically switch to a passive connection which it currently most definitely does not do.
You have to tick the passive connection box. The way you do this is tick the Advanced options box. Then under Connection tick the passive one. I also selected IPv4 as the internet protocol (might not work in your case) and under Environment>FTP ticked the Force IP ... option. I'd suggest you save all that as a session and reuse the setting next time. If you are editing a saved session make sure that you save.
Hope this helps!
Since 4.3 passive mode is default.
lmstearn
Had a problem with this for years.
Forgive my "layman's" jargon.
Previous dialogues with site Admin & Tech personnel tried to locate a "problem" with my modem. That ceased when exactly the same "problem" arose with a different ADSL2 modem.
Was a problem then with my broadband connection, which used a shared, not dedicated, address at the exchange.
However, the problem was *only* with remote servers run on Microsoft Windows and was dated to a server upgrade ~3.5 years ago.
Other remote servers e.g. Unix didn't care
Once I changed providers, the problem disappeared altogether.
Until now.
It seems to be a connection speed? issue. I have blown my 2 gigabyte allocation and the transfer speed slows to around 7 kbs.
Logging on to the remote Microsoft Windows FTP server I got no timeout message but:
"Could not retrieve directory listing -Can't open data connection"
I deselected passive mode and removed permanent caching and, bingo, got in.
Hope this helps,
Laurie
Re above, deselecting passive mode,
"Auto" is greyed out, but neither IPv4 nor IPv6 are selected.
What's the story there?
Cheers
Laurie
Hari
. 2011-07-13 12:45:13.218 --------------------------------------------------------------------------
. 2011-07-13 12:45:13.218 WinSCP Version 4.3.3 (Build 1340) (OS 5.1.2600 Service Pack 3)
. 2011-07-13 12:45:13.218 Configuration: HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\
. 2011-07-13 12:45:13.218 Login time: Wednesday, July 13, 2011 12:45:13 PM
. 2011-07-13 12:45:13.218 Session name: CambridgeAssessment@ftps.vizual.co.uk (Ad-Hoc session)
. 2011-07-13 12:45:13.218 Host name: ftps.vizual.co.uk (Port: 990)
. 2011-07-13 12:45:13.218 User name: CambridgeAssessment (Password: Yes, Key file: No)
. 2011-07-13 12:45:13.218 Tunnel: No
. 2011-07-13 12:45:13.218 Transfer Protocol: FTP
. 2011-07-13 12:45:13.218 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2011-07-13 12:45:13.218 Proxy: none
. 2011-07-13 12:45:13.218 FTP: FTPS: Implicit SSL/TLS; Passive: Yes [Force IP: No]
. 2011-07-13 12:45:13.218 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2011-07-13 12:45:13.218 Cache directory changes: Yes, Permanent: Yes
. 2011-07-13 12:45:13.218 DST mode: 1
. 2011-07-13 12:45:13.890 Connecting to ftps.vizual.co.uk:990 ...
. 2011-07-13 12:45:14.031 Connected with ftps.vizual.co.uk:990, negotiating SSL connection...
. 2011-07-13 12:45:14.406 SSL connection established. Waiting for welcome message...
< 2011-07-13 12:45:14.406 220 WELCOME TO FTPS.VIZUAL.CO.UK Vizual Business Tools Secure FTP Site ========
> 2011-07-13 12:45:14.406 USER CambridgeAssessment
< 2011-07-13 12:45:14.593 331 Password required for cambridgeassessment
> 2011-07-13 12:45:14.593 PASS **************************
< 2011-07-13 12:45:14.765 230 Logged on
> 2011-07-13 12:45:14.765 SYST
< 2011-07-13 12:45:14.937 215 UNIX emulated by FileZilla
> 2011-07-13 12:45:14.937 FEAT
< 2011-07-13 12:45:15.125 211-Features:
< 2011-07-13 12:45:15.125 MDTM
< 2011-07-13 12:45:15.125 REST STREAM
< 2011-07-13 12:45:15.125 SIZE
< 2011-07-13 12:45:15.125 MLST type*;size*;modify*;
< 2011-07-13 12:45:15.125 MLSD
< 2011-07-13 12:45:15.125 AUTH SSL
< 2011-07-13 12:45:15.125 AUTH TLS
< 2011-07-13 12:45:15.125 PROT
< 2011-07-13 12:45:15.125 PBSZ
< 2011-07-13 12:45:15.125 UTF8
< 2011-07-13 12:45:15.125 CLNT
< 2011-07-13 12:45:15.125 MFMT
< 2011-07-13 12:45:15.140 211 End
> 2011-07-13 12:45:15.140 PBSZ 0
< 2011-07-13 12:45:15.312 200 PBSZ=0
> 2011-07-13 12:45:15.312 PROT P
< 2011-07-13 12:45:15.484 200 Protection level set to P
. 2011-07-13 12:45:15.484 Connected
. 2011-07-13 12:45:15.484 --------------------------------------------------------------------------
. 2011-07-13 12:45:15.500 Using FTP protocol.
. 2011-07-13 12:45:15.500 Doing startup conversation with host.
> 2011-07-13 12:45:15.515 PWD
< 2011-07-13 12:45:15.687 257 "/" is current directory.
. 2011-07-13 12:45:15.687 Getting current directory name.
. 2011-07-13 12:45:15.703 Retrieving directory listing...
> 2011-07-13 12:45:15.703 TYPE A
< 2011-07-13 12:45:15.875 200 Type set to A
> 2011-07-13 12:45:15.890 PASV
< 2011-07-13 12:45:16.078 227 Entering Passive Mode (172,16,18,6,195,83)
> 2011-07-13 12:45:16.078 LIST -a
< 2011-07-13 12:45:26.609 425 Can't open data connection.
. 2011-07-13 12:45:26.609 Could not retrieve directory listing
. 2011-07-13 12:45:26.625 Retrieving directory listing...
> 2011-07-13 12:45:26.625 TYPE A
< 2011-07-13 12:45:26.796 200 Type set to A
> 2011-07-13 12:45:26.796 PASV
< 2011-07-13 12:45:26.984 227 Entering Passive Mode (172,16,18,6,195,84)
> 2011-07-13 12:45:26.984 LIST
< 2011-07-13 12:45:37.609 425 Can't open data connection.
. 2011-07-13 12:45:37.609 Could not retrieve directory listing
* 2011-07-13 12:45:37.609 (ECommand) Error listing directory '/'.
* 2011-07-13 12:45:37.609 Could not retrieve directory listing
* 2011-07-13 12:45:37.609 Can't open data connection.
I am getting this error "Can't open data connection". please find the log file below
user
find the new one
* 2011-07-13 12:45:37.609 Can't open data connection.[/quote]
Can you try to enable Force IP address for passive mode connections?
http://winscp.net/eng/docs/ui_login_ftp
ok
unable to access
TheJjokerR
Make sure your server session encryption is the same as your server expects, try different settings and see if something works. No encryption is common to work.
TheJjokerR
damn didn't mean to bump this, wrong thread, please move to that more recent thread about this.
More information about "Transfer channel can't be opened" error:
http://winscp.net/eng/docs/message_transfer_channel_cant_be_opened
Daniel D
Try disabling passive mode. Probably not all FTP passive ports are not opened.
For example these all ports must be allowed to use passive mode.
Response: 227 Entering Passive Mode (202,234,195,227,219,190).
This is bit confusing. The numbers in the 227 response are not port numbers! Only the 219 and 190 represent a port number 56254 (219 * 256 + 190). The 202,234,195,227 is an IP address. So there's only one port number in the message.
