Topic "WinSCP Scripting with No Resume"
Nobble
As you can see from the log below I'm having issues with sending a file to one particular ftp site.
Just to give some background I'm using your fine sftp program to send files to a number of dftp sites. The same code works fine for all customers apart for one, where I get the 'turn off transfer resume support' error message. This leads me to understand we have no file rename permissions on this particular ftp server. So as the error message states I need to disable transfer resume support.
I do this with the ini file
C:\Program Files\WinSCP>winscp.com /ini="c:\program files\winscp\WinSCP.ini" /log="c:\program files\winscp\log.log"
But I still get this error transfering the file
can anyone help?
log file:
. 2009-02-23 15:34:47.756 --------------------------------------------------------------------------
. 2009-02-23 15:34:47.756 WinSCP Version 4.1.8 (Build 415) (OS 6.0.6001 Service Pack 1)
. 2009-02-23 15:34:47.756 Login time: 23 February 2009 15:34:47
. 2009-02-23 15:34:47.756 Session name: W839014@195.11.199.76
. 2009-02-23 15:34:47.756 Host name: 195.11.199.76 (Port: 22)
. 2009-02-23 15:34:47.756 User name: W839014 (Password: Yes, Key file: No)
. 2009-02-23 15:34:47.756 Tunnel: No
. 2009-02-23 15:34:47.756 Transfer Protocol: SFTP
. 2009-02-23 15:34:47.756 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2009-02-23 15:34:47.756 Proxy: none
. 2009-02-23 15:34:47.756 SSH protocol version: 2; Compression: No
. 2009-02-23 15:34:47.756 Bypass authentication: No
. 2009-02-23 15:34:47.756 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2009-02-23 15:34:47.756 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2009-02-23 15:34:47.756 SSH Bugs: -,-,-,-,-,-,-,-
. 2009-02-23 15:34:47.756 SFTP Bugs: -,-
. 2009-02-23 15:34:47.756 Return code variable: Autodetect; Lookup user groups: Yes
. 2009-02-23 15:34:47.756 Shell: default, EOL: 0
. 2009-02-23 15:34:47.756 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2009-02-23 15:34:47.756 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2009-02-23 15:34:47.756 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2009-02-23 15:34:47.756 Cache directory changes: Yes, Permanent: Yes
. 2009-02-23 15:34:47.756 DST mode: 1
. 2009-02-23 15:34:47.756 Looking up host "195.11.199.76"
. 2009-02-23 15:34:47.756 Connecting to 195.11.199.76 port 22
. 2009-02-23 15:34:47.975 Server version: SSH-2.0-1.36 sshlib: GlobalScape
. 2009-02-23 15:34:47.975 We claim version: SSH-2.0-WinSCP_release_4.1.8
. 2009-02-23 15:34:47.975 SSPI: acquired credentials for: administrator@ADVANTIS.LOCAL
. 2009-02-23 15:34:47.975 Cannot convert IP address to SPN: DNS is not trusted
. 2009-02-23 15:34:47.975 GSSKEX disabled: The operation completed successfully.
. 2009-02-23 15:34:47.975 Using SSH protocol version 2
. 2009-02-23 15:34:47.975 Using Diffie-Hellman with standard group "group1"
. 2009-02-23 15:34:47.975 Doing Diffie-Hellman key exchange with hash SHA-1
. 2009-02-23 15:34:48.427 Host key fingerprint is:
. 2009-02-23 15:34:48.427 ssh-dss 1024 65:ec:d8:10:2a:33:4c:08:56:61:7b:a7:30:b6:77:a8
. 2009-02-23 15:34:48.427 Initialised Blowfish-128 CBC client->server encryption
. 2009-02-23 15:34:48.427 Initialised HMAC-SHA1 client->server MAC algorithm
. 2009-02-23 15:34:48.427 Initialised Blowfish-128 CBC server->client encryption
. 2009-02-23 15:34:48.427 Initialised HMAC-SHA1 server->client MAC algorithm
! 2009-02-23 15:34:48.786 Using username "W839014".
. 2009-02-23 15:34:48.926 Prompt (6, SSH password, , &Password: )
. 2009-02-23 15:34:48.926 Using stored password.
. 2009-02-23 15:34:48.942 Sent password
. 2009-02-23 15:34:48.989 Access granted
. 2009-02-23 15:34:49.036 Opened channel for session
. 2009-02-23 15:34:49.129 Started a shell/command
. 2009-02-23 15:34:49.129 --------------------------------------------------------------------------
. 2009-02-23 15:34:49.129 Using SFTP protocol.
. 2009-02-23 15:34:49.129 Doing startup conversation with host.
> 2009-02-23 15:34:49.129 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2009-02-23 15:34:49.254 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2009-02-23 15:34:49.254 SFTP version 3 negotiated.
. 2009-02-23 15:34:49.254 We believe the server has signed timestamps bug
. 2009-02-23 15:34:49.254 We will use UTF-8 strings for status messages only
. 2009-02-23 15:34:49.254 Getting current directory name.
. 2009-02-23 15:34:49.254 Getting real path for '.'
> 2009-02-23 15:34:49.254 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2009-02-23 15:34:49.316 Type: SSH_FXP_NAME, Size: 23, Number: 16
. 2009-02-23 15:34:49.316 Real path is '/'
. 2009-02-23 15:34:49.316 Startup conversation with host finished.
. 2009-02-23 15:34:52.437 Copying 1 files/directories to remote directory "/"
. 2009-02-23 15:34:52.437   PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2009-02-23 15:34:52.437   TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2009-02-23 15:34:52.437   AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2009-02-23 15:34:52.437 File: "\\advserv01\backoffice\Trace Data\GB\trace20090219.xls"
. 2009-02-23 15:34:52.468 Copying "\\advserv01\backoffice\Trace Data\GB\trace20090219.xls" to remote directory started.
. 2009-02-23 15:34:52.468 Binary transfer mode selected.
. 2009-02-23 15:34:52.468 Checking existence of file.
> 2009-02-23 15:34:52.468 Type: SSH_FXP_LSTAT, Size: 27, Number: 263
< 2009-02-23 15:34:52.515 Type: SSH_FXP_STATUS, Size: 33, Number: 263
< 2009-02-23 15:34:52.515 Status/error code: 2
. 2009-02-23 15:34:52.515 Checking existence of partially transfered file.
> 2009-02-23 15:34:52.515 Type: SSH_FXP_LSTAT, Size: 36, Number: 519
< 2009-02-23 15:34:52.577 Type: SSH_FXP_STATUS, Size: 33, Number: 519
< 2009-02-23 15:34:52.577 Status/error code: 2
. 2009-02-23 15:34:52.577 Opening remote file.
> 2009-02-23 15:34:52.577 Type: SSH_FXP_OPEN, Size: 52, Number: 771
< 2009-02-23 15:34:52.842 Type: SSH_FXP_HANDLE, Size: 10, Number: 771
> 2009-02-23 15:34:52.842 Type: SSH_FXP_WRITE, Size: 4118, Number: 1286
. 2009-02-23 15:35:01.111 60 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2009-02-23 15:35:01.111 Type: SSH_FXP_CLOSE, Size: 10, Number: 9476
< 2009-02-23 15:35:01.641 Type: SSH_FXP_STATUS, Size: 21, Number: 8710
< 2009-02-23 15:35:02.093 Type: SSH_FXP_STATUS, Size: 21, Number: 8966
< 2009-02-23 15:35:02.140 Type: SSH_FXP_STATUS, Size: 21, Number: 9222
< 2009-02-23 15:35:02.140 Type: SSH_FXP_STATUS, Size: 21, Number: 9476
< 2009-02-23 15:35:02.140 Status/error code: 0
> 2009-02-23 15:35:02.140 Type: SSH_FXP_RENAME, Size: 58, Number: 9746
< 2009-02-23 15:35:02.218 Type: SSH_FXP_STATUS, Size: 33, Number: 9746
< 2009-02-23 15:35:02.218 Status/error code: 2, Message: 9746, Server: File not found, Language: en
* 2009-02-23 15:35:02.218 (ETerminal) No such file or directory.
* 2009-02-23 15:35:02.218 Error code: 2
* 2009-02-23 15:35:02.218 Error message from server (en): File not found
* 2009-02-23 15:35:02.218 Request code: 18
. 2009-02-23 15:35:02.218 Asking user:
. 2009-02-23 15:35:02.218 Transfer was succesfully finished, but temporary transfer file 'trace20090219.xls.filepart' could not be renamed to target file name 'trace20090219.xls'. If the problem persists, you may try to turn off transfer resume support. ("No such file or directory.
. 2009-02-23 15:35:02.218 Error code: 2
. 2009-02-23 15:35:02.218 Error message from server (en): File not found
. 2009-02-23 15:35:02.218 Request code: 18")
* 2009-02-23 15:35:04.090 (EScpSkipFile) Transfer was succesfully finished, but temporary transfer file 'trace20090219.xls.filepart' could not be renamed to target file name 'trace20090219.xls'. If the problem persists, you may try to turn off transfer resume support.
* 2009-02-23 15:35:04.090 No such file or directory.
* 2009-02-23 15:35:04.090 Error code: 2
* 2009-02-23 15:35:04.090 Error message from server (en): File not found
* 2009-02-23 15:35:04.090 Request code: 18
. 2009-02-23 15:35:06.836 Deleting file "trace20090219.xls.filepart".
> 2009-02-23 15:35:06.836 Type: SSH_FXP_REMOVE, Size: 36, Number: 9997
< 2009-02-23 15:35:06.914 Type: SSH_FXP_STATUS, Size: 21, Number: 9997
< 2009-02-23 15:35:06.914 Status/error code: 0
. 2009-02-23 15:35:10.346 Closing connection.
. 2009-02-23 15:35:10.346 Sending special code: 12
. 2009-02-23 15:35:10.346 Sent EOF message
ini file:
[Configuration\CDCache]
advantis@213.152.63.146=412F3D2F2F0D0A
W839014@195.11.199.76=412F3D2F2F0D0A2F66726F6D636C693D2F2F0D0A
[SshHostKeys]
dss@22:213.152.63.146=0xc3335c10d24c0aa28c28a98477cbe3efce...
dss@22:195.11.199.76=0xc1052551bce64a21923c3ea7e0c05b6e76b...
[Configuration\Interface]
RandomSeedFile=%25APPDATA%25%5Cwinscp.rnd
PuttyRegistryStorageKey=Software%5CSimonTatham%5CPuTTY
ConfirmOverwriting=1
ConfirmResume=1
AutoReadDirectoryAfterOp=1
SessionReopenAuto=5000
SessionReopenBackground=2000
TunnelLocalPortNumberLow=50000
TunnelLocalPortNumberHigh=50099
CacheDirectoryChangesMaxSize=100
ShowFtpWelcomeMessage=0
CopyParamDialogExpanded=0
ContinueOnError=0
ConfirmCommandSession=1
SynchronizeParams=66
SynchronizeOptions=5
SynchronizeModeAuto=-1
SynchronizeMode=0
MaxWatchDirectories=500
QueueTransfersLimit=2
QueueAutoPopup=1
QueueRememberPassword=0
PuttySession=WinSCP%20temporary%20session
PuttyPath=%25PROGRAMFILES%25%5CPuTTY%5Cputty.exe
PuttyPassword=0
TelnetForFtpInPutty=1
IgnoreCancelBeforeFinish=DFBC9A785634023F
BeepOnFinish=0
BeepOnFinishAfter=176CC1166CC1363F
SynchronizeBrowsing=0
KeepUpToDateChangeDelay=500
ChecksumAlg=md5
Interface=0
ShowAdvancedLoginOptions=0
CopyOnDoubleClick=2
CopyOnDoubleClickConfirmation=0
DDAllowMove=0
DDAllowMoveInit=0
DDTransferConfirmation=1
DDTemporaryDirectory=
DDWarnLackOfTempSpace=1
DDWarnLackOfTempSpaceRatio=9A9999999999F13F
DeleteToRecycleBin=1
DimmHiddenFiles=1
SelectDirectories=0
SelectMask=%2A.%2A
ShowHiddenFiles=1
ShowInaccesibleDirectories=1
ConfirmTransferring=1
ConfirmDeleting=1
ConfirmRecycling=1
ConfirmClosingSession=1
ConfirmExitOnCompletion=1
AutoStartSession=
UseLocationProfiles=0
LocaleSafe=1033
DDExtEnabled=1
DDExtTimeout=1000
DefaultDirIsHome=1
TemporaryDirectoryCleanup=1
ConfirmTemporaryDirectoryCleanup=1
PreservePanelState=1
Theme=OfficeXP
PathInCaption=0
MinimizeToTray=0
BalloonNotifications=1
NotificationsTimeout=10
NotificationsStickTime=2
CopyParamAutoSelectNotice=1
SessionToolbarAutoShown=0
LockToolbars=0
AutoOpenInPutty=0
LastMonitor=0
[Configuration\Logging]
Logging=0
LogFileName=
LogFileAppend=1
LogWindowLines=100
LogProtocol=0
LogView=0
LogWindowOnStartup=1
LogWindowParams=-1;-1;500;400
[Configuration\Interface\CopyParam]
AddXToDirectories=1
Masks=%2A.%2Ahtml;%20%2A.htm;%20%2A.txt;%20%2A.php;%20%2A.php3;%20%2A.cgi;%20%2A.c;%20%2A.cpp;%20%2A.h;%20%2A.pas;%20%2A.bas;%20%2A.tex;%20%2A.pl;%20.htaccess;%20%2A.xtml;%20%2A.css;%20%2A.cfg;%20%2A.ini;%20%2A.sh;%20%2A.xml
FileNameCase=0
PreserveReadOnly=0
PreserveTime=1
PreserveRights=0
IgnorePermErrors=0
Text=rw-r--r--
TransferMode=2
ResumeSupport=1
ResumeThreshold=102400
ReplaceInvalidChars=1
LocalInvalidChars=/%5C:%2A%3F"<>|
CalculateSize=1
ExcludeFileMask=
NegativeExclude=0
ClearArchive=0
CPSLimit=0
Queue=0
QueueNoConfirmation=1
NewerOnly=0
CopyParamList=-1
[Configuration\Interface\NewDirectory]
Valid=00
[Configuration\Interface\SynchronizeChecklist]
WindowParams=0;-1;-1;600;450;0
ListParams=1;1|150,1;100,1;80,1;130,1;25,1;100,1;80,1;130,1|0;1;2;3;4;5;6;7
[Configuration\Interface\ConsoleWin]
WindowSize=570,430
[Configuration\History\SpeedLimit]
0=Unlimited
1=1024
2=512
3=256
4=128
5=64
6=32
7=16
8=8
[Configuration\History\Mask]
0=%2A.%2Ahtml;%20%2A.htm;%20%2A.txt;%20%2A.php;%20%2A.php3;%20%2A.cgi;%20%2A.c;%20%2A.cpp;%20%2A.h;%20%2A.pas;%20%2A.bas;%20%2A.tex;%20%2A.pl;%20.htaccess;%20%2A.xtml;%20%2A.css;%20%2A.cfg;%20%2A.ini;%20%2A.sh;%20%2A.xml
[Configuration\Interface\Editor]
FontName=Courier%20New
FontHeight=-12
FontStyle=0
FontCharset=1
WordWrap=0
FindTextA=
ReplaceTextA=
FindMatchCase=0
FindWholeWord=0
FindDown=1
TabSize=7
MaxEditors=500
EarlyClose=2
[Configuration\Interface\QueueView]
Height=100
Layout=70,160,160,80,80,80
Show=1
LastHideShow=1
ToolBar=0
[Configuration\Interface\Updates]
Period=7
LastCheck=0000000000000000
HaveResults=0
ShownResults=0
ConnectionType=1
ProxyHost=
ProxyPort=8080
ForVersion=0
Version=0
Message=
Critical=0
Release=
Disabled=0
Url=
UrlButton=
[Configuration\Interface\Explorer]
ToolbarsLayout=Queue_Visible=1,Queue_LastDock=QueueDock,...
DirViewParams=0;1;0|150,1;70,1;101,1;79,1;62,1;55,1;20,0;150,0;125,0|0;1;8;2;3;4;5;6;7
LastLocalTargetDirectory=C:%5CUsers%5Cadministrator.advantis%5CDocuments
StatusBar=1
WindowParams=-1;-1;600;400;0
ViewStyle=0
ShowFullAddress=1
DriveView=1
DriveViewWidth=180
[Configuration\Interface\Commander]
CurrentPanel=0
LocalPanelWidth=000000000000E03F
SwappedPanels=0
StatusBar=1
WindowParams=-1;-1;850;650;0
ExplorerStyleSelection=0
PreserveLocalDirectory=0
CompareByTime=1
CompareBySize=0
FullRowSelect=1
[Configuration\Interface\Commander\LocalPanel]
DirViewParams=0;1;0|150,1;70,1;101,1;79,1;62,1;55,0|0;1;2;3;4;5
StatusBar=1
DriveView=0
DriveViewHeight=100
[Configuration\Interface\Commander\RemotePanel]
DirViewParams=0;1;0|150,1;70,1;101,1;79,1;62,1;55,0;20,0;150,0;125,0|0;1;8;2;3;4;5;6;7
StatusBar=1
DriveView=0
DriveViewHeight=100
[Configuration\Interface\Editor\0]
FileMask=%2A.%2A
Editor=0
ExternalEditor=
ExternalEditorText=1
MDIExternalEditor=0
DetectMDIExternalEditor=1
[Configuration\Interface\Editor\1]
FileMask=%2A.%2A
Editor=1
ExternalEditor=notepad.exe
MDIExternalEditor=0
[Configuration\History\LocalTarget]
0=C:%5CUsers%5Cadministrator.advantis%5CDesktop%5C%2A.%2A
1=C:%5CUsers%5Cadministrator.advantis%5CDocuments%5C%2A.%2A
Resume is enabled in the INI file:
ResumeSupport=1
ResumeSupport must be zero.
Nobble
thanks... trying that now...
umm.. still getting the error ... any other ideas?
its running on a server 2008 x64
. 2009-02-25 15:39:47.740 --------------------------------------------------------------------------
. 2009-02-25 15:39:47.740 WinSCP Version 4.1.8 (Build 415) (OS 6.0.6001 Service Pack 1)
. 2009-02-25 15:39:47.740 Login time: 25 February 2009 15:39:47
. 2009-02-25 15:39:47.740 Session name: W839014@195.11.199.76
. 2009-02-25 15:39:47.740 Host name: 195.11.199.76 (Port: 22)
. 2009-02-25 15:39:47.740 User name: W839014 (Password: Yes, Key file: No)
. 2009-02-25 15:39:47.740 Tunnel: No
. 2009-02-25 15:39:47.740 Transfer Protocol: SFTP
. 2009-02-25 15:39:47.740 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2009-02-25 15:39:47.740 Proxy: none
. 2009-02-25 15:39:47.740 SSH protocol version: 2; Compression: No
. 2009-02-25 15:39:47.740 Bypass authentication: No
. 2009-02-25 15:39:47.740 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2009-02-25 15:39:47.740 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2009-02-25 15:39:47.740 SSH Bugs: -,-,-,-,-,-,-,-
. 2009-02-25 15:39:47.740 SFTP Bugs: -,-
. 2009-02-25 15:39:47.740 Return code variable: Autodetect; Lookup user groups: Yes
. 2009-02-25 15:39:47.740 Shell: default, EOL: 0
. 2009-02-25 15:39:47.756 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2009-02-25 15:39:47.756 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2009-02-25 15:39:47.756 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2009-02-25 15:39:47.756 Cache directory changes: Yes, Permanent: Yes
. 2009-02-25 15:39:47.756 DST mode: 1
. 2009-02-25 15:39:47.756 --------------------------------------------------------------------------
. 2009-02-25 15:39:47.756 Looking up host "195.11.199.76"
. 2009-02-25 15:39:47.756 Connecting to 195.11.199.76 port 22
. 2009-02-25 15:39:47.865 Server version: SSH-2.0-1.36 sshlib: GlobalScape
. 2009-02-25 15:39:47.865 We claim version: SSH-2.0-WinSCP_release_4.1.8
. 2009-02-25 15:39:47.880 SSPI: acquired credentials for: administrator@ADVANTIS.LOCAL
. 2009-02-25 15:39:47.880 Cannot convert IP address to SPN: DNS is not trusted
. 2009-02-25 15:39:47.880 GSSKEX disabled: The operation completed successfully.. 2009-02-25 15:39:47.880 Using SSH protocol
version 2
. 2009-02-25 15:39:47.880 Using Diffie-Hellman with standard group "group1"
. 2009-02-25 15:39:47.880 Doing Diffie-Hellman key exchange with hash SHA-1
. 2009-02-25 15:39:48.224 Host key fingerprint is:
. 2009-02-25 15:39:48.224 ssh-dss 1024 65:ec:d8:10:2a:33:4c:08:56:61:7b:a7:30:b6:77:a8
. 2009-02-25 15:39:48.224 Initialised Blowfish-128 CBC client->server encryption
. 2009-02-25 15:39:48.224 Initialised HMAC-SHA1 client->server MAC algorithm
. 2009-02-25 15:39:48.224 Initialised Blowfish-128 CBC server->client encryption
. 2009-02-25 15:39:48.224 Initialised HMAC-SHA1 server->client MAC algorithm
! 2009-02-25 15:39:48.458 Using username "W839014".
. 2009-02-25 15:39:48.520 Prompt (6, SSH password, , &Password: )
. 2009-02-25 15:39:48.520 Using stored password.
. 2009-02-25 15:39:48.520 Sent password
. 2009-02-25 15:39:48.583 Access granted
. 2009-02-25 15:39:48.645 Opened channel for session
. 2009-02-25 15:39:48.723 Started a shell/command
. 2009-02-25 15:39:48.723 --------------------------------------------------------------------------
. 2009-02-25 15:39:48.723 Using SFTP protocol.
. 2009-02-25 15:39:48.723 Doing startup conversation with host.
> 2009-02-25 15:39:48.723 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2009-02-25 15:39:48.785 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2009-02-25 15:39:48.785 SFTP version 3 negotiated.
. 2009-02-25 15:39:48.785 We believe the server has signed timestamps bug
. 2009-02-25 15:39:48.785 We will use UTF-8 strings for status messages only
. 2009-02-25 15:39:48.801 Getting current directory name.
. 2009-02-25 15:39:48.801 Getting real path for '.'
> 2009-02-25 15:39:48.801 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2009-02-25 15:39:48.848 Type: SSH_FXP_NAME, Size: 23, Number: 16
. 2009-02-25 15:39:48.848 Real path is '/'
. 2009-02-25 15:39:48.848 Startup conversation with host finished.
. 2009-02-25 15:39:52.873 Copying 1 files/directories to remote directory "/"
. 2009-02-25 15:39:52.873   PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: Y (102400); CalcS: No;
Mask:
. 2009-02-25 15:39:52.873   TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2009-02-25 15:39:52.873   AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl;
. 2009-02-25 15:39:52.873 File: "\\advserv01\backoffice\Trace Data\GB\trace20090219.xls"
. 2009-02-25 15:39:52.904 Copying "\\advserv01\backoffice\Trace Data\GB\trace20090219.xls" to remote directory started.
. 2009-02-25 15:39:52.904 Binary transfer mode selected.
. 2009-02-25 15:39:52.904 Checking existence of file.
> 2009-02-25 15:39:52.904 Type: SSH_FXP_LSTAT, Size: 27, Number: 263
< 2009-02-25 15:39:52.951 Type: SSH_FXP_STATUS, Size: 33, Number: 263
< 2009-02-25 15:39:52.951 Status/error code: 2
. 2009-02-25 15:39:52.951 Checking existence of partially transfered file.
> 2009-02-25 15:39:52.951 Type: SSH_FXP_LSTAT, Size: 36, Number: 519
< 2009-02-25 15:39:53.013 Type: SSH_FXP_STATUS, Size: 33, Number: 519
< 2009-02-25 15:39:53.013 Status/error code: 2
. 2009-02-25 15:39:53.013 Opening remote file.
> 2009-02-25 15:39:53.013 Type: SSH_FXP_OPEN, Size: 52, Number: 771
< 2009-02-25 15:39:53.060 Type: SSH_FXP_HANDLE, Size: 10, Number: 771
> 2009-02-25 15:39:53.075 Type: SSH_FXP_WRITE, Size: 4118, Number: 1286
. 2009-02-25 15:39:57.880 60 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2009-02-25 15:39:57.880 Type: SSH_FXP_CLOSE, Size: 10, Number: 9476
< 2009-02-25 15:39:58.146 Type: SSH_FXP_STATUS, Size: 21, Number: 8710
< 2009-02-25 15:39:58.395 Type: SSH_FXP_STATUS, Size: 21, Number: 8966
< 2009-02-25 15:39:58.395 Type: SSH_FXP_STATUS, Size: 21, Number: 9222
< 2009-02-25 15:39:58.395 Type: SSH_FXP_STATUS, Size: 21, Number: 9476
< 2009-02-25 15:39:58.395 Status/error code: 0
> 2009-02-25 15:39:58.395 Type: SSH_FXP_RENAME, Size: 58, Number: 9746
< 2009-02-25 15:39:58.458 Type: SSH_FXP_STATUS, Size: 33, Number: 9746
< 2009-02-25 15:39:58.458 Status/error code: 2, Message: 9746, Server: File not found, Language: en
* 2009-02-25 15:39:58.458 (ETerminal) No such file or directory.
* 2009-02-25 15:39:58.458 Error code: 2
* 2009-02-25 15:39:58.458 Error message from server (en): File not found
* 2009-02-25 15:39:58.458 Request code: 18
. 2009-02-25 15:39:58.458 Asking user:
. 2009-02-25 15:39:58.458 Transfer was succesfully finished, but temporary transfer file 'trace20090219.xls.filepart' could not be
. 2009-02-25 15:39:58.458 Error code: 2
. 2009-02-25 15:39:58.458 Error message from server (en): File not found
. 2009-02-25 15:39:58.458 Request code: 18")
* 2009-02-25 15:39:59.394 (EScpSkipFile) Transfer was succesfully finished, but temporary transfer file
* 2009-02-25 15:39:59.394 No such file or directory.
* 2009-02-25 15:39:59.394 Error code: 2
* 2009-02-25 15:39:59.394 Error message from server (en): File not found
* 2009-02-25 15:39:59.394 Request code: 18
. 2009-02-25 15:40:00.688 Deleting file "trace20090219.xls.filepart".
> 2009-02-25 15:40:00.688 Type: SSH_FXP_REMOVE, Size: 36, Number: 9997
< 2009-02-25 15:40:00.735 Type: SSH_FXP_STATUS, Size: 21, Number: 9997
< 2009-02-25 15:40:00.735 Status/error code: 0
. 2009-02-25 15:40:01.905 Closing connection.
. 2009-02-25 15:40:01.905 Sending special code: 12
. 2009-02-25 15:40:01.905 Sent EOF message
[SshHostKeys]
dss@22:213.152.63.146=0xc3335c10d24c0aa28c28a98477cbe3ef...
dss@22:195.11.199.76=0xc1052551bce64a21923c3ea7e0c05b6e7...
ConfirmResume=1
ContinueOnError=0
SynchronizeMode=0
QueueAutoPopup=1
PuttyPassword=0
BeepOnFinish=0
ChecksumAlg=md5
Interface=0
CopyOnDoubleClick=2
DDAllowMove=0
DDAllowMoveInit=0
DimmHiddenFiles=1
SelectDirectories=0
SelectMask=%2A.%2A
ShowHiddenFiles=1
ConfirmDeleting=1
ConfirmRecycling=1
AutoStartSession=
LocaleSafe=1033
DDExtEnabled=1
DDExtTimeout=1000
DefaultDirIsHome=1
Theme=OfficeXP
PathInCaption=0
MinimizeToTray=0
LockToolbars=0
AutoOpenInPutty=0
LastMonitor=0
Logging=0
LogFileName=
LogFileAppend=1
LogWindowLines=100
LogProtocol=0
LogView=0
AddXToDirectories=1
FileNameCase=0
PreserveReadOnly=0
PreserveTime=1
PreserveRights=0
IgnorePermErrors=0
Text=rw-r--r--
TransferMode=2
ResumeSupport=0
CalculateSize=1
ExcludeFileMask=
NegativeExclude=0
ClearArchive=0
CPSLimit=0
Queue=0
NewerOnly=0
CopyParamList=-1
Valid=00
WindowSize=570,430
0=Unlimited
1=1024
2=512
3=256
4=128
5=64
6=32
7=16
8=8
FontHeight=-12
FontStyle=0
FontCharset=1
WordWrap=0
FindTextA=
ReplaceTextA=
FindMatchCase=0
FindWholeWord=0
FindDown=1
TabSize=7
MaxEditors=500
EarlyClose=2
Height=100
Show=1
LastHideShow=1
ToolBar=0
Period=7
HaveResults=0
ShownResults=0
ConnectionType=1
ProxyHost=
ProxyPort=8080
ForVersion=0
Version=0
Message=
Critical=0
Release=
Disabled=0
Url=
UrlButton=
ToolbarsLayout=Queue_Visible=1,Queue_LastDock=QueueDock,Queue_DockRow=0,...
StatusBar=1
ViewStyle=0
ShowFullAddress=1
DriveView=1
DriveViewWidth=180
CurrentPanel=0
SwappedPanels=0
StatusBar=1
CompareByTime=1
CompareBySize=0
FullRowSelect=1
StatusBar=1
DriveView=0
DriveViewHeight=100
StatusBar=1
DriveView=0
DriveViewHeight=100
FileMask=%2A.%2A
Editor=0
ExternalEditor=
MDIExternalEditor=0
FileMask=%2A.%2A
Editor=1
MDIExternalEditor=0
[Sessions\Default%20Settings]
HostName=195.11.199.76
Password=A35C454803BCD32F7FC54902098536EE647F5E94DAE26CC70B646F656...
UserName=W839014
[Configuration\Banners]
W839014@195.11.199.76=5E04E3002BD01A81493B410979EE0179
Sorry, it should have been 2.
Nobble
Thank you that worked Very Happy
