Topic "winscp.RND location for portable version"
ElTopo
I use portable winscp with portable KeePass passing with proper username and password (in command line), everything works fine but I notice that winscp.RND gets created in many directories.
Is it possible that portable winscp.exe always creates winscp.RND in its own directory (along with winscp.exe and winscp.ini), instead of current working directory (which might not be same as winscp's directory)?
Thanks!
prikryl
No, WinSCP does not support that.
ElTopo
Well,can we have this feature in a future version?
prikryl
This request has been added to tracker.
ElTopo
Thanks!
geeg
I know this is an old topic, but currently the behavior is the same.
To workaround this, I use the following INI param ( under Windows ):
[Configuration\Interface]
RandomSeedFile=nul
