Topic "Upgrade from 4.18 to 4.20 breaks Preferences"
sequeira
I've been a happy user for many years, unfortunately the latest upgrade breaks the 'Preferences' Option both from the Saved Sessions screen, and fron the Options Menu.
I get a popup "Ancestor for 'LogFileNameEdit' not found".
I'm using the Norton Commander interface, but the same things happens with the Explorer interface.
This may be relevant, on installation I get the following in a popup, I carried on though:
"Runtime Error (at 85:1058):"
'Internal error: Unknown custom message name "NortonCommanderInterface" in "cm" constant'
O/S Win XP Professional.
Seems to work otherwise, apart from removing the executable bit on Windows transfers, which is why I wanted the Preferences...
3 machines exhibit the same symptoms, all upgraded from 4.18 beta
GaaL
Got the same symptoms on my XP SP3 system where WinSCP 4.18beta was installed before the upgrade to 4.20beta
Each time I use Options/Preferences, the following message appears : ancestor for 'LogFileNameEdit' not found.
Thanks for your posts. These bugs have been added to tracker: 381 and 382
sequeira
I'm impressed, very many thanks for this fix, and the lightning quick turnaround
Regards.
