Topic "DragExt on Windows 7 build 7000"
yelv
I have a bug with DragExt on Windows 7, it doesn't work, creates only empty scp***** folder and says it wasn't able to detect folder, where the file were dropped, sometimes no error, only empty scp***** folder.
Tried both stable and beta versions. I think windows doesn't fully load that extension or something like that. When I do "regsvr32 Dragext.dll" it says extension is loaded, but the problem still exists. Tried to unregister->reboot->register->reboot... nothing.
Under uncertain conditions it really DOES work, after long standby (> 10h), sometimes not. But it works only until the first reboot|logout.
After all WinSCP is a really good piece of software, thanks.
OK, thanks for your information. However, I'm not able to test WinSCP in Windows 7 now, so this needs to wait until later.
