Topic "Script hangs on prompt to accept new host key"
alani
I have a problem when the winscp host key has been deleted on a remote machine.
Next time we connect with a script, it hangs on the prompt "The server's host key was not found in the cache. You have no guarantee that the server is the computer you think it is..."
Is there a way to get the session to time out and fail?
Use "option batch abort" before connecting.
alani
Thanks Martin - that works if I use open in the script.
Is there a way to get it to work if we invoke using
winscp.com xxx /script=sss
where xxx is the stored session name?
Alan
No. You should not do this at all. If you still need to pass session name on command line, you can do:
winscp.com /command "option batch abort" "open xxx" /script=sss
But make sure there are no spaces in session name.
