Topic "Problems listing directory with 4.2.1 build 428"
WhiteKnight
Hi
I've been using version 3.2.8 build 330, because I kept having problems with 4.1.x. Version 3.2.8 and the latest version of PSFTP can list the SFTP directory, but version 4.2.1 build 428 can't. If there is over a certain number of files in a directory, then version 3.2.8 can't list the directory either, which I was hoping was fix in 4.2.1 with the recent GlobalSCAPE packet size limit work around. PSFTP can list the directory even when the number of files in the directory cause WinSCP 3.2.8 to be unable to list the directory.
I've replace some of the log data with X. If you require any of it I could PM it.
. 2009-03-11 08:54:40.725 --------------------------------------------------------------------------
. 2009-03-11 08:54:40.725 WinSCP Version 4.2.1 (Build 428) (OS 5.2.3790 Service Pack 2)
. 2009-03-11 08:54:40.725 Login time: 11 March 2009 08:54:40
. 2009-03-11 08:54:40.725 Session name: X@X.X.X.X
. 2009-03-11 08:54:40.725 Host name: X.X.X.X (Port: X)
. 2009-03-11 08:54:40.725 User name: X (Password: No, Key file: No)
. 2009-03-11 08:54:40.725 Tunnel: No
. 2009-03-11 08:54:40.725 Transfer Protocol: SFTP
. 2009-03-11 08:54:40.725 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2009-03-11 08:54:40.725 Proxy: none
. 2009-03-11 08:54:40.725 SSH protocol version: 2; Compression: No
. 2009-03-11 08:54:40.725 Bypass authentication: No
. 2009-03-11 08:54:40.725 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2009-03-11 08:54:40.725 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2009-03-11 08:54:40.725 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2009-03-11 08:54:40.725 SFTP Bugs: -,-
. 2009-03-11 08:54:40.725 Return code variable: Autodetect; Lookup user groups: Yes
. 2009-03-11 08:54:40.725 Shell: default, EOL: 0
. 2009-03-11 08:54:40.725 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2009-03-11 08:54:40.725 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2009-03-11 08:54:40.725 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2009-03-11 08:54:40.725 Cache directory changes: Yes, Permanent: Yes
. 2009-03-11 08:54:40.725 DST mode: 1
. 2009-03-11 08:54:41.037 Looking up host "X.X.X.X"
. 2009-03-11 08:54:41.037 Connecting to X.X.X.X port X
. 2009-03-11 08:54:41.287 Selecting events 63 for socket 896
. 2009-03-11 08:54:41.287 Waiting for the server to continue with the initialisation
. 2009-03-11 08:54:41.287 Looking for incoming data
. 2009-03-11 08:54:41.287 Looking for network events
. 2009-03-11 08:54:41.287 Detected network event
. 2009-03-11 08:54:41.287 Enumerating network events for socket 896
. 2009-03-11 08:54:41.287 Enumerated 18 network events making 18 cumulative events for socket 896
. 2009-03-11 08:54:41.287 Handling network write event on socket 896 with error 0
. 2009-03-11 08:54:41.287 Handling network connect event on socket 896 with error 0
. 2009-03-11 08:54:41.553 Detected network event
. 2009-03-11 08:54:41.553 Enumerating network events for socket 896
. 2009-03-11 08:54:41.553 Enumerated 1 network events making 1 cumulative events for socket 896
. 2009-03-11 08:54:41.553 Handling network read event on socket 896 with error 0
. 2009-03-11 08:54:41.553 Server version: SSH-2.0-1.36 sshlib: GlobalScape
. 2009-03-11 08:54:41.553 We believe remote version ignores SSH-2 maximum packet size
. 2009-03-11 08:54:41.553 Using SSH protocol version 2
. 2009-03-11 08:54:41.553 We claim version: SSH-2.0-WinSCP_release_4.2.1
. 2009-03-11 08:54:41.553 Waiting for the server to continue with the initialisation
. 2009-03-11 08:54:41.553 Looking for incoming data
. 2009-03-11 08:54:41.553 Looking for network events
. 2009-03-11 08:54:41.553 Using Diffie-Hellman with standard group "group1"
. 2009-03-11 08:54:41.553 Doing Diffie-Hellman key exchange with hash SHA-1
. 2009-03-11 08:54:41.568 Waiting for the server to continue with the initialisation
. 2009-03-11 08:54:41.568 Looking for incoming data
. 2009-03-11 08:54:41.568 Looking for network events
. 2009-03-11 08:54:42.100 Detected network event
. 2009-03-11 08:54:42.100 Enumerating network events for socket 896
. 2009-03-11 08:54:42.100 Enumerated 1 network events making 1 cumulative events for socket 896
. 2009-03-11 08:54:42.100 Handling network read event on socket 896 with error 0
. 2009-03-11 08:54:42.131 Selecting events 63 for socket 896
. 2009-03-11 08:54:42.131 Host key fingerprint is:
. 2009-03-11 08:54:42.131 ssh-dss 1024 ed:32:c4:8c:c1:ff:05:34:f6:00:c8:fa:8b:d8:d2:63
. 2009-03-11 08:54:42.131 Initialised AES-256 CBC client->server encryption
. 2009-03-11 08:54:42.131 Initialised HMAC-SHA1 client->server MAC algorithm
. 2009-03-11 08:54:42.131 Initialised AES-256 CBC server->client encryption
. 2009-03-11 08:54:42.131 Initialised HMAC-SHA1 server->client MAC algorithm
. 2009-03-11 08:54:42.131 Waiting for the server to continue with the initialisation
. 2009-03-11 08:54:42.131 Looking for incoming data
. 2009-03-11 08:54:42.131 Looking for network events
. 2009-03-11 08:54:42.818 Detected network event
. 2009-03-11 08:54:42.818 Enumerating network events for socket 896
. 2009-03-11 08:54:42.818 Enumerated 1 network events making 1 cumulative events for socket 896
. 2009-03-11 08:54:42.818 Handling network read event on socket 896 with error 0
! 2009-03-11 08:54:42.818 Using username "X".
. 2009-03-11 08:54:42.834 Waiting for the server to continue with the initialisation
. 2009-03-11 08:54:42.834 Looking for incoming data
. 2009-03-11 08:54:42.834 Looking for network events
. 2009-03-11 08:54:43.084 Detected network event
. 2009-03-11 08:54:43.084 Enumerating network events for socket 896
. 2009-03-11 08:54:43.084 Enumerated 1 network events making 1 cumulative events for socket 896
. 2009-03-11 08:54:43.084 Handling network read event on socket 896 with error 0
. 2009-03-11 08:54:44.115 Prompt (6, SSH password, , &Password: )
. 2009-03-11 08:54:48.256 Sent password
. 2009-03-11 08:54:48.256 Waiting for the server to continue with the initialisation
. 2009-03-11 08:54:48.256 Looking for incoming data
. 2009-03-11 08:54:48.256 Looking for network events
. 2009-03-11 08:54:48.521 Detected network event
. 2009-03-11 08:54:48.521 Enumerating network events for socket 896
. 2009-03-11 08:54:48.521 Enumerated 1 network events making 1 cumulative events for socket 896
. 2009-03-11 08:54:48.521 Handling network read event on socket 896 with error 0
. 2009-03-11 08:54:48.521 Access granted
. 2009-03-11 08:54:48.521 Waiting for the server to continue with the initialisation
. 2009-03-11 08:54:48.521 Looking for incoming data
. 2009-03-11 08:54:48.521 Looking for network events
. 2009-03-11 08:54:48.787 Detected network event
. 2009-03-11 08:54:48.787 Enumerating network events for socket 896
. 2009-03-11 08:54:48.787 Enumerated 1 network events making 1 cumulative events for socket 896
. 2009-03-11 08:54:48.787 Handling network read event on socket 896 with error 0
. 2009-03-11 08:54:48.787 Opened channel for session
. 2009-03-11 08:54:48.787 Waiting for the server to continue with the initialisation
. 2009-03-11 08:54:48.787 Looking for incoming data
. 2009-03-11 08:54:48.787 Looking for network events
. 2009-03-11 08:54:49.568 Detected network event
. 2009-03-11 08:54:49.568 Enumerating network events for socket 896
. 2009-03-11 08:54:49.568 Enumerated 1 network events making 1 cumulative events for socket 896
. 2009-03-11 08:54:49.568 Handling network read event on socket 896 with error 0
. 2009-03-11 08:54:49.568 Started a shell/command
. 2009-03-11 08:54:49.568 --------------------------------------------------------------------------
. 2009-03-11 08:54:49.568 Using SFTP protocol.
. 2009-03-11 08:54:49.568 Doing startup conversation with host.
> 2009-03-11 08:54:49.568 Type: SSH_FXP_INIT, Size: 5, Number: -1
> 2009-03-11 08:54:49.568 01,00,00,00,05,
. 2009-03-11 08:54:49.568 Sent 9 bytes
. 2009-03-11 08:54:49.568 There are 0 bytes remaining in the send buffer
. 2009-03-11 08:54:49.568 Looking for network events
. 2009-03-11 08:54:49.568 Timeout waiting for network events
. 2009-03-11 08:54:49.568 Waiting for another 4 bytes
. 2009-03-11 08:54:49.568 Looking for incoming data
. 2009-03-11 08:54:49.834 Detected network event
. 2009-03-11 08:54:49.834 Enumerating network events for socket 896
. 2009-03-11 08:54:49.834 Enumerated 1 network events making 1 cumulative events for socket 896
. 2009-03-11 08:54:49.834 Handling network read event on socket 896 with error 0
. 2009-03-11 08:54:49.834 Received 9 bytes (0)
. 2009-03-11 08:54:49.834 Read 4 bytes (5 pending)
. 2009-03-11 08:54:49.834 Read 5 bytes (0 pending)
< 2009-03-11 08:54:49.834 Type: SSH_FXP_VERSION, Size: 5, Number: -1
< 2009-03-11 08:54:49.834 02,00,00,00,03,
. 2009-03-11 08:54:49.834 SFTP version 3 negotiated.
. 2009-03-11 08:54:49.834 We believe the server has signed timestamps bug
. 2009-03-11 08:54:49.834 We will use UTF-8 strings for status messages only
. 2009-03-11 08:54:49.834 Getting current directory name.
. 2009-03-11 08:54:49.834 Getting real path for '.'
> 2009-03-11 08:54:49.834 Type: SSH_FXP_REALPATH, Size: 10, Number: 9232
> 2009-03-11 08:54:49.834 10,00,00,24,10,00,00,00,01,2E,
. 2009-03-11 08:54:49.834 Sent 14 bytes
. 2009-03-11 08:54:49.834 There are 0 bytes remaining in the send buffer
. 2009-03-11 08:54:49.834 Looking for network events
. 2009-03-11 08:54:49.834 Timeout waiting for network events
. 2009-03-11 08:54:49.834 Waiting for another 4 bytes
. 2009-03-11 08:54:49.834 Looking for incoming data
. 2009-03-11 08:54:50.115 Detected network event
. 2009-03-11 08:54:50.115 Enumerating network events for socket 896
. 2009-03-11 08:54:50.115 Enumerated 1 network events making 1 cumulative events for socket 896
. 2009-03-11 08:54:50.115 Handling network read event on socket 896 with error 0
. 2009-03-11 08:54:50.115 Received 105 bytes (0)
. 2009-03-11 08:54:50.115 Read 4 bytes (101 pending)
. 2009-03-11 08:54:50.115 Read 101 bytes (0 pending)
< 2009-03-11 08:54:50.115 Type: SSH_FXP_NAME, Size: 101, Number: 9232
< 2009-03-11 08:54:50.115 68,00,00,24,10,00,00,00,01,00,00,00,28,2F,49,6E,65,74,70,75,62,2F,41,70,70,
< 2009-03-11 08:54:50.115 6C,69,63,61,74,69,6F,6E,20,4C,6F,67,20,46,69,6C,65,73,2F,49,4D,53,54,48,41,
< 2009-03-11 08:54:50.115 53,30,36,00,00,00,28,2F,49,6E,65,74,70,75,62,2F,41,70,70,6C,69,63,61,74,69,
< 2009-03-11 08:54:50.115 6F,6E,20,4C,6F,67,20,46,69,6C,65,73,2F,49,4D,53,54,48,41,53,30,36,00,00,00,
< 2009-03-11 08:54:50.115 00,
. 2009-03-11 08:54:50.115 Real path is 'X'
. 2009-03-11 08:54:50.115 Listing directory "X".
> 2009-03-11 08:54:50.115 Type: SSH_FXP_OPENDIR, Size: 49, Number: 9483
> 2009-03-11 08:54:50.115 0B,00,00,25,0B,00,00,00,28,2F,49,6E,65,74,70,75,62,2F,41,70,70,6C,69,63,61,
> 2009-03-11 08:54:50.115 74,69,6F,6E,20,4C,6F,67,20,46,69,6C,65,73,2F,49,4D,53,54,48,41,53,30,36,
. 2009-03-11 08:54:50.115 Sent 53 bytes
. 2009-03-11 08:54:50.115 There are 0 bytes remaining in the send buffer
. 2009-03-11 08:54:50.115 Looking for network events
. 2009-03-11 08:54:50.115 Timeout waiting for network events
. 2009-03-11 08:54:50.115 Waiting for another 4 bytes
. 2009-03-11 08:54:50.115 Looking for incoming data
. 2009-03-11 08:54:50.365 Detected network event
. 2009-03-11 08:54:50.381 Enumerating network events for socket 896
. 2009-03-11 08:54:50.381 Enumerated 1 network events making 1 cumulative events for socket 896
. 2009-03-11 08:54:50.381 Handling network read event on socket 896 with error 0
. 2009-03-11 08:54:50.381 Received 14 bytes (0)
. 2009-03-11 08:54:50.381 Read 4 bytes (10 pending)
. 2009-03-11 08:54:50.381 Read 10 bytes (0 pending)
< 2009-03-11 08:54:50.381 Type: SSH_FXP_HANDLE, Size: 10, Number: 9483
< 2009-03-11 08:54:50.381 66,00,00,25,0B,00,00,00,01,31,
> 2009-03-11 08:54:50.381 Type: SSH_FXP_READDIR, Size: 10, Number: 9740
> 2009-03-11 08:54:50.381 0C,00,00,26,0C,00,00,00,01,31,
. 2009-03-11 08:54:50.381 Sent 14 bytes
. 2009-03-11 08:54:50.381 There are 0 bytes remaining in the send buffer
. 2009-03-11 08:54:50.381 Looking for network events
. 2009-03-11 08:54:50.381 Timeout waiting for network events
. 2009-03-11 08:54:50.381 Waiting for another 4 bytes
. 2009-03-11 08:54:50.381 Looking for incoming data
. 2009-03-11 08:54:50.646 Detected network event
. 2009-03-11 08:54:50.646 Enumerating network events for socket 896
. 2009-03-11 08:54:50.646 Enumerated 1 network events making 1 cumulative events for socket 896
. 2009-03-11 08:54:50.646 Handling network read event on socket 896 with error 0
. 2009-03-11 08:54:50.646 Received 805 bytes (0)
. 2009-03-11 08:54:50.646 Read 4 bytes (801 pending)
. 2009-03-11 08:54:50.646 Read 801 bytes (0 pending)
< 2009-03-11 08:54:50.646 Type: SSH_FXP_NAME, Size: 801, Number: 9740
< 2009-03-11 08:54:50.646 68,00,00,26,0C,00,00,00,08,00,00,00,07,61,72,63,68,69,76,65,00,00,00,3E,64,
< 2009-03-11 08:54:50.646 72,77,78,72,77,2D,72,77,2D,20,20,20,31,20,75,73,65,72,20,20,20,20,20,67,72,
< 2009-03-11 08:54:50.646 6F,75,70,20,20,20,20,20,20,20,20,20,20,20,30,20,44,65,63,20,31,31,20,20,32,
< 2009-03-11 08:54:50.646 30,30,38,20,61,72,63,68,69,76,65,00,00,00,0C,00,00,41,F6,49,40,FB,9A,49,40,
< 2009-03-11 08:54:50.646 FB,9A,00,00,00,06,43,6F,6E,73,69,73,00,00,00,3D,64,72,77,78,72,77,2D,72,77,
< 2009-03-11 08:54:50.646 2D,20,20,20,31,20,75,73,65,72,20,20,20,20,20,67,72,6F,75,70,20,20,20,20,20,
< 2009-03-11 08:54:50.646 20,20,20,20,20,20,30,20,44,65,63,20,33,30,20,20,32,30,30,38,20,43,6F,6E,73,
< 2009-03-11 08:54:50.646 69,73,00,00,00,0C,00,00,41,F6,49,5A,77,E4,49,5A,77,E4,00,00,00,03,45,54,50,
< 2009-03-11 08:54:50.646 00,00,00,3A,64,72,77,78,72,77,2D,72,77,2D,20,20,20,31,20,75,73,65,72,20,20,
< 2009-03-11 08:54:50.646 20,20,20,67,72,6F,75,70,20,20,20,20,20,20,20,20,20,20,20,30,20,4E,6F,76,20,
< 2009-03-11 08:54:50.646 31,31,20,20,32,30,30,38,20,45,54,50,00,00,00,0C,00,00,41,F6,49,19,44,40,49,
< 2009-03-11 08:54:50.646 19,44,40,00,00,00,0B,4D,61,69,6C,53,65,72,76,69,63,65,00,00,00,42,64,72,77,
< 2009-03-11 08:54:50.646 78,72,77,2D,72,77,2D,20,20,20,31,20,75,73,65,72,20,20,20,20,20,67,72,6F,75,
< 2009-03-11 08:54:50.646 70,20,20,20,20,20,20,20,20,20,20,20,30,20,4A,61,6E,20,32,33,20,31,33,3A,34,
< 2009-03-11 08:54:50.646 35,20,4D,61,69,6C,53,65,72,76,69,63,65,00,00,00,0C,00,00,41,F6,49,79,C9,DD,
< 2009-03-11 08:54:50.646 49,79,C9,DD,00,00,00,08,4F,72,64,65,72,69,6E,67,00,00,00,3F,64,72,77,78,72,
< 2009-03-11 08:54:50.646 77,2D,72,77,2D,20,20,20,31,20,75,73,65,72,20,20,20,20,20,67,72,6F,75,70,20,
< 2009-03-11 08:54:50.646 20,20,20,20,20,20,20,20,20,20,30,20,44,65,63,20,33,31,20,20,32,30,30,38,20,
< 2009-03-11 08:54:50.646 4F,72,64,65,72,69,6E,67,00,00,00,0C,00,00,41,F6,49,5A,BC,01,49,5A,BC,01,00,
< 2009-03-11 08:54:50.646 00,00,17,50,68,61,72,6D,61,73,79,73,5F,43,6F,6E,73,69,73,20,55,70,64,61,74,
< 2009-03-11 08:54:50.646 65,00,00,00,4E,64,72,77,78,72,77,2D,72,77,2D,20,20,20,31,20,75,73,65,72,20,
< 2009-03-11 08:54:50.646 20,20,20,20,67,72,6F,75,70,20,20,20,20,20,20,20,20,20,20,20,30,20,4E,6F,76,
< 2009-03-11 08:54:50.646 20,32,30,20,20,32,30,30,38,20,50,68,61,72,6D,61,73,79,73,5F,43,6F,6E,73,69,
< 2009-03-11 08:54:50.646 73,20,55,70,64,61,74,65,00,00,00,0C,00,00,41,F6,49,25,27,F8,49,25,27,F8,00,
< 2009-03-11 08:54:50.646 00,00,0C,72,6F,62,6F,63,6F,70,79,2E,6C,6F,67,00,00,00,43,2D,72,77,2D,72,77,
< 2009-03-11 08:54:50.646 2D,72,77,2D,20,20,20,31,20,75,73,65,72,20,20,20,20,20,67,72,6F,75,70,20,20,
< 2009-03-11 08:54:50.646 20,20,20,32,33,39,33,31,38,39,20,4D,61,72,20,31,30,20,31,37,3A,32,32,20,72,
< 2009-03-11 08:54:50.646 6F,62,6F,63,6F,70,79,2E,6C,6F,67,00,00,00,0D,00,00,00,00,00,24,84,65,00,00,
< 2009-03-11 08:54:50.646 81,B6,49,B6,A1,F0,49,B6,A1,F0,00,00,00,06,72,6F,6D,62,75,73,00,00,00,3D,64,
< 2009-03-11 08:54:50.646 6F,75,70,20,20,20,20,20,20,20,20,20,20,20,30,20,4A,61,6E,20,20,35,20,31,34,
< 2009-03-11 08:54:50.646 3A,30,35,20,72,6F,6D,62,75,73,00,00,00,0C,00,00,41,F6,49,62,13,8C,49,62,13,
< 2009-03-11 08:54:50.646 8C,
> 2009-03-11 08:54:50.646 Type: SSH_FXP_READDIR, Size: 10, Number: 9996
> 2009-03-11 08:54:50.646 0C,00,00,27,0C,00,00,00,01,31,
. 2009-03-11 08:54:50.646 Sent 14 bytes
. 2009-03-11 08:54:50.646 There are 0 bytes remaining in the send buffer
. 2009-03-11 08:54:50.646 Looking for network events
. 2009-03-11 08:54:50.646 Timeout waiting for network events
. 2009-03-11 08:54:50.646 Read file 'X' from listing
. 2009-03-11 08:54:50.646 Waiting for another 4 bytes
. 2009-03-11 08:54:50.646 Looking for incoming data
. 2009-03-11 08:54:50.896 Detected network event
. 2009-03-11 08:54:50.896 Enumerating network events for socket 896
. 2009-03-11 08:54:50.896 Enumerated 1 network events making 1 cumulative events for socket 896
. 2009-03-11 08:54:50.896 Handling network read event on socket 896 with error 0
. 2009-03-11 08:54:50.896 Received 26 bytes (0)
. 2009-03-11 08:54:50.896 Read 4 bytes (22 pending)
. 2009-03-11 08:54:50.896 Read 22 bytes (0 pending)
< 2009-03-11 08:54:50.896 Type: SSH_FXP_STATUS, Size: 22, Number: 9996
< 2009-03-11 08:54:50.896 65,00,00,27,0C,00,00,00,01,00,00,00,03,65,6F,66,00,00,00,02,65,6E,
< 2009-03-11 08:54:50.896 Status/error code: 1
> 2009-03-11 08:54:50.896 Type: SSH_FXP_CLOSE, Size: 10, Number: 10244
> 2009-03-11 08:54:50.896 04,00,00,28,04,00,00,00,01,31,
. 2009-03-11 08:54:50.896 Sent 14 bytes
. 2009-03-11 08:54:50.896 There are 0 bytes remaining in the send buffer
. 2009-03-11 08:54:50.896 Looking for network events
. 2009-03-11 08:54:50.896 Timeout waiting for network events
. 2009-03-11 08:54:50.896 Startup conversation with host finished.
. 2009-03-11 08:54:51.021 Session upkeep
. 2009-03-11 08:54:51.021 Looking for network events
. 2009-03-11 08:54:51.021 Timeout waiting for network events
. 2009-03-11 08:54:51.287 Session upkeep
. 2009-03-11 08:54:51.287 Looking for network events
. 2009-03-11 08:54:51.287 Detected network event
. 2009-03-11 08:54:51.287 Enumerating network events for socket 896
. 2009-03-11 08:54:51.287 Enumerated 1 network events making 1 cumulative events for socket 896
. 2009-03-11 08:54:51.287 Handling network read event on socket 896 with error 0
. 2009-03-11 08:54:51.287 Received 25 bytes (0)
. 2009-03-11 08:54:51.787 Session upkeep
. 2009-03-11 08:54:51.787 Looking for network events
. 2009-03-11 08:54:51.787 Timeout waiting for network events
. 2009-03-11 08:54:52.287 Session upkeep
. 2009-03-11 08:54:52.287 Looking for network events
. 2009-03-11 08:54:52.287 Timeout waiting for network events
. 2009-03-11 08:54:52.787 Session upkeep
. 2009-03-11 08:54:52.787 Looking for network events
. 2009-03-11 08:54:52.787 Timeout waiting for network events
. 2009-03-11 08:54:53.287 Session upkeep
. 2009-03-11 08:54:53.287 Looking for network events
. 2009-03-11 08:54:53.287 Timeout waiting for network events
. 2009-03-11 08:54:53.646 Cached directory change via "X" to "X".
. 2009-03-11 08:54:53.646 Getting current directory name.
. 2009-03-11 08:54:53.646 Listing directory "X".
> 2009-03-11 08:54:53.646 Type: SSH_FXP_OPENDIR, Size: 58, Number: 10507
> 2009-03-11 08:54:53.646 0B,00,00,29,0B,00,00,00,31,2F,49,6E,65,74,70,75,62,2F,41,70,70,6C,69,63,61,
> 2009-03-11 08:54:53.646 74,69,6F,6E,20,4C,6F,67,20,46,69,6C,65,73,2F,49,4D,53,54,48,41,53,30,36,2F,
> 2009-03-11 08:54:53.646 4F,72,64,65,72,69,6E,67,
. 2009-03-11 08:54:53.646 Sent 62 bytes
. 2009-03-11 08:54:53.646 There are 0 bytes remaining in the send buffer
. 2009-03-11 08:54:53.646 Looking for network events
. 2009-03-11 08:54:53.646 Timeout waiting for network events
. 2009-03-11 08:54:53.646 Read 4 bytes (21 pending)
. 2009-03-11 08:54:53.646 Read 21 bytes (0 pending)
< 2009-03-11 08:54:53.646 Type: SSH_FXP_STATUS, Size: 21, Number: 10244
< 2009-03-11 08:54:53.646 65,00,00,28,04,00,00,00,00,00,00,00,02,4F,6B,00,00,00,02,65,6E,
. 2009-03-11 08:54:53.646 Discarding reserved response
. 2009-03-11 08:54:53.646 Waiting for another 4 bytes
. 2009-03-11 08:54:53.646 Looking for incoming data
. 2009-03-11 08:54:53.896 Detected network event
. 2009-03-11 08:54:53.896 Enumerating network events for socket 896
. 2009-03-11 08:54:53.896 Enumerated 1 network events making 1 cumulative events for socket 896
. 2009-03-11 08:54:53.896 Handling network read event on socket 896 with error 0
. 2009-03-11 08:54:53.896 Received 14 bytes (0)
. 2009-03-11 08:54:53.896 Read 4 bytes (10 pending)
. 2009-03-11 08:54:53.896 Read 10 bytes (0 pending)
< 2009-03-11 08:54:53.896 Type: SSH_FXP_HANDLE, Size: 10, Number: 10507
< 2009-03-11 08:54:53.896 66,00,00,29,0B,00,00,00,01,31,
> 2009-03-11 08:54:53.896 Type: SSH_FXP_READDIR, Size: 10, Number: 10764
> 2009-03-11 08:54:53.896 0C,00,00,2A,0C,00,00,00,01,31,
. 2009-03-11 08:54:53.896 Sent 14 bytes
. 2009-03-11 08:54:53.896 There are 0 bytes remaining in the send buffer
. 2009-03-11 08:54:53.896 Looking for network events
. 2009-03-11 08:54:53.896 Timeout waiting for network events
. 2009-03-11 08:54:53.896 Waiting for another 4 bytes
. 2009-03-11 08:54:53.896 Looking for incoming data
. 2009-03-11 08:54:54.162 Detected network event
. 2009-03-11 08:54:54.162 Enumerating network events for socket 896
. 2009-03-11 08:54:54.162 Enumerated 1 network events making 1 cumulative events for socket 896
. 2009-03-11 08:54:54.162 Handling network read event on socket 896 with error 0
. 2009-03-11 08:54:54.162 Received 468 bytes (0)
. 2009-03-11 08:54:54.162 Read 4 bytes (464 pending)
. 2009-03-11 08:54:54.162 Read 464 bytes (0 pending)
< 2009-03-11 08:54:54.162 Type: SSH_FXP_NAME, Size: 464, Number: 10764
< 2009-03-11 08:54:54.162 68,00,00,2A,0C,00,00,00,05,00,00,00,03,41,41,48,00,00,00,3A,64,72,77,78,72,
< 2009-03-11 08:54:54.162 77,2D,72,77,2D,20,20,20,31,20,75,73,65,72,20,20,20,20,20,67,72,6F,75,70,20,
< 2009-03-11 08:54:54.162 20,20,20,20,20,20,20,20,20,20,30,20,4E,6F,76,20,31,31,20,20,32,30,30,38,20,
< 2009-03-11 08:54:54.162 41,41,48,00,00,00,0C,00,00,41,F6,49,19,44,42,49,19,44,42,00,00,00,04,4C,6F,
< 2009-03-11 08:54:54.162 67,73,00,00,00,3B,64,72,77,78,72,77,2D,72,77,2D,20,20,20,31,20,75,73,65,72,
< 2009-03-11 08:54:54.162 20,20,20,20,20,67,72,6F,75,70,20,20,20,20,20,20,20,20,20,20,20,30,20,4D,61,
< 2009-03-11 08:54:54.162 72,20,31,30,20,31,37,3A,32,31,20,4C,6F,67,73,00,00,00,0C,00,00,41,F6,49,B6,
< 2009-03-11 08:54:54.162 A1,AB,49,B6,A1,AB,00,00,00,09,4D,61,77,64,73,6C,65,79,73,00,00,00,40,64,72,
< 2009-03-11 08:54:54.162 77,78,72,77,2D,72,77,2D,20,20,20,31,20,75,73,65,72,20,20,20,20,20,67,72,6F,
< 2009-03-11 08:54:54.162 75,70,20,20,20,20,20,20,20,20,20,20,20,30,20,44,65,63,20,33,31,20,20,32,30,
< 2009-03-11 08:54:54.162 30,38,20,4D,61,77,64,73,6C,65,79,73,00,00,00,0C,00,00,41,F6,49,5A,BC,01,49,
< 2009-03-11 08:54:54.162 5A,BC,01,00,00,00,07,53,61,6E,67,65,72,73,00,00,00,3E,64,72,77,78,72,77,2D,
< 2009-03-11 08:54:54.162 72,77,2D,20,20,20,31,20,75,73,65,72,20,20,20,20,20,67,72,6F,75,70,20,20,20,
< 2009-03-11 08:54:54.162 20,20,20,20,20,20,20,20,30,20,4E,6F,76,20,31,31,20,20,32,30,30,38,20,53,61,
< 2009-03-11 08:54:54.162 6E,67,65,72,73,00,00,00,0C,00,00,41,F6,49,19,F1,55,49,19,F1,55,00,00,00,07,
< 2009-03-11 08:54:54.162 55,6E,69,63,68,65,6D,00,00,00,3E,64,72,77,78,72,77,2D,72,77,2D,20,20,20,31,
< 2009-03-11 08:54:54.162 20,75,73,65,72,20,20,20,20,20,67,72,6F,75,70,20,20,20,20,20,20,20,20,20,20,
< 2009-03-11 08:54:54.162 20,30,20,4E,6F,76,20,31,31,20,20,32,30,30,38,20,55,6E,69,63,68,65,6D,00,00,
< 2009-03-11 08:54:54.162 00,0C,00,00,41,F6,49,19,44,5E,49,19,44,5E,
> 2009-03-11 08:54:54.162 Type: SSH_FXP_READDIR, Size: 10, Number: 11020
> 2009-03-11 08:54:54.162 0C,00,00,2B,0C,00,00,00,01,31,
. 2009-03-11 08:54:54.162 Sent 14 bytes
. 2009-03-11 08:54:54.162 There are 0 bytes remaining in the send buffer
. 2009-03-11 08:54:54.162 Looking for network events
. 2009-03-11 08:54:54.162 Timeout waiting for network events
. 2009-03-11 08:54:54.162 Read file 'X' from listing
. 2009-03-11 08:54:54.162 Waiting for another 4 bytes
. 2009-03-11 08:54:54.162 Looking for incoming data
. 2009-03-11 08:54:54.428 Detected network event
. 2009-03-11 08:54:54.428 Enumerating network events for socket 896
. 2009-03-11 08:54:54.428 Enumerated 1 network events making 1 cumulative events for socket 896
. 2009-03-11 08:54:54.428 Handling network read event on socket 896 with error 0
. 2009-03-11 08:54:54.428 Received 26 bytes (0)
. 2009-03-11 08:54:54.428 Read 4 bytes (22 pending)
. 2009-03-11 08:54:54.428 Read 22 bytes (0 pending)
< 2009-03-11 08:54:54.428 Type: SSH_FXP_STATUS, Size: 22, Number: 11020
< 2009-03-11 08:54:54.428 65,00,00,2B,0C,00,00,00,01,00,00,00,03,65,6F,66,00,00,00,02,65,6E,
< 2009-03-11 08:54:54.428 Status/error code: 1
> 2009-03-11 08:54:54.428 Type: SSH_FXP_CLOSE, Size: 10, Number: 11268
> 2009-03-11 08:54:54.428 04,00,00,2C,04,00,00,00,01,31,
. 2009-03-11 08:54:54.428 Sent 14 bytes
. 2009-03-11 08:54:54.428 There are 0 bytes remaining in the send buffer
. 2009-03-11 08:54:54.428 Looking for network events
. 2009-03-11 08:54:54.428 Timeout waiting for network events
. 2009-03-11 08:54:54.443 Session upkeep
. 2009-03-11 08:54:54.443 Looking for network events
. 2009-03-11 08:54:54.443 Timeout waiting for network events
. 2009-03-11 08:54:54.787 Session upkeep
. 2009-03-11 08:54:54.787 Looking for network events
. 2009-03-11 08:54:54.787 Detected network event
. 2009-03-11 08:54:54.787 Enumerating network events for socket 896
. 2009-03-11 08:54:54.787 Enumerated 1 network events making 1 cumulative events for socket 896
. 2009-03-11 08:54:54.787 Handling network read event on socket 896 with error 0
. 2009-03-11 08:54:54.787 Received 25 bytes (0)
. 2009-03-11 08:54:55.287 Session upkeep
. 2009-03-11 08:54:55.287 Looking for network events
. 2009-03-11 08:54:55.287 Timeout waiting for network events
. 2009-03-11 08:54:55.787 Session upkeep
. 2009-03-11 08:54:55.787 Looking for network events
. 2009-03-11 08:54:55.787 Timeout waiting for network events
. 2009-03-11 08:54:56.287 Session upkeep
. 2009-03-11 08:54:56.287 Looking for network events
. 2009-03-11 08:54:56.287 Timeout waiting for network events
. 2009-03-11 08:54:56.787 Session upkeep
. 2009-03-11 08:54:56.787 Looking for network events
. 2009-03-11 08:54:56.787 Timeout waiting for network events
. 2009-03-11 08:54:57.287 Session upkeep
. 2009-03-11 08:54:57.287 Looking for network events
. 2009-03-11 08:54:57.287 Timeout waiting for network events
. 2009-03-11 08:54:57.787 Session upkeep
. 2009-03-11 08:54:57.787 Looking for network events
. 2009-03-11 08:54:57.787 Timeout waiting for network events
. 2009-03-11 08:54:58.006 Cached directory change via "X" to "X".
. 2009-03-11 08:54:58.006 Getting current directory name.
. 2009-03-11 08:54:58.006 Listing directory "X".
> 2009-03-11 08:54:58.006 Type: SSH_FXP_OPENDIR, Size: 66, Number: 11531
> 2009-03-11 08:54:58.006 0B,00,00,2D,0B,00,00,00,39,2F,49,6E,65,74,70,75,62,2F,41,70,70,6C,69,63,61,
> 2009-03-11 08:54:58.006 74,69,6F,6E,20,4C,6F,67,20,46,69,6C,65,73,2F,49,4D,53,54,48,41,53,30,36,2F,
> 2009-03-11 08:54:58.006 4F,72,64,65,72,69,6E,67,2F,53,61,6E,67,65,72,73,
. 2009-03-11 08:54:58.006 Sent 70 bytes
. 2009-03-11 08:54:58.006 There are 0 bytes remaining in the send buffer
. 2009-03-11 08:54:58.006 Looking for network events
. 2009-03-11 08:54:58.006 Timeout waiting for network events
. 2009-03-11 08:54:58.006 Read 4 bytes (21 pending)
. 2009-03-11 08:54:58.006 Read 21 bytes (0 pending)
< 2009-03-11 08:54:58.006 Type: SSH_FXP_STATUS, Size: 21, Number: 11268
< 2009-03-11 08:54:58.006 65,00,00,2C,04,00,00,00,00,00,00,00,02,4F,6B,00,00,00,02,65,6E,
. 2009-03-11 08:54:58.006 Discarding reserved response
. 2009-03-11 08:54:58.006 Waiting for another 4 bytes
. 2009-03-11 08:54:58.006 Looking for incoming data
. 2009-03-11 08:54:58.256 Detected network event
. 2009-03-11 08:54:58.256 Enumerating network events for socket 896
. 2009-03-11 08:54:58.256 Enumerated 1 network events making 1 cumulative events for socket 896
. 2009-03-11 08:54:58.256 Handling network read event on socket 896 with error 0
. 2009-03-11 08:54:58.256 Received 14 bytes (0)
. 2009-03-11 08:54:58.256 Read 4 bytes (10 pending)
. 2009-03-11 08:54:58.256 Read 10 bytes (0 pending)
< 2009-03-11 08:54:58.256 Type: SSH_FXP_HANDLE, Size: 10, Number: 11531
< 2009-03-11 08:54:58.256 66,00,00,2D,0B,00,00,00,01,31,
> 2009-03-11 08:54:58.256 Type: SSH_FXP_READDIR, Size: 10, Number: 11788
> 2009-03-11 08:54:58.256 0C,00,00,2E,0C,00,00,00,01,31,
. 2009-03-11 08:54:58.256 Sent 14 bytes
. 2009-03-11 08:54:58.256 There are 0 bytes remaining in the send buffer
. 2009-03-11 08:54:58.256 Looking for network events
. 2009-03-11 08:54:58.256 Timeout waiting for network events
. 2009-03-11 08:54:58.256 Waiting for another 4 bytes
. 2009-03-11 08:54:58.256 Looking for incoming data
. 2009-03-11 08:54:58.521 Detected network event
. 2009-03-11 08:54:58.521 Enumerating network events for socket 896
. 2009-03-11 08:54:58.521 Enumerated 1 network events making 1 cumulative events for socket 896
. 2009-03-11 08:54:58.521 Handling network read event on socket 896 with error 0
. 2009-03-11 08:54:58.521 Received 387 bytes (0)
. 2009-03-11 08:54:58.521 Read 4 bytes (383 pending)
. 2009-03-11 08:54:58.521 Read 383 bytes (0 pending)
< 2009-03-11 08:54:58.521 Type: SSH_FXP_NAME, Size: 383, Number: 11788
< 2009-03-11 08:54:58.521 68,00,00,2E,0C,00,00,00,04,00,00,00,09,44,42,46,61,69,6C,75,72,65,00,00,00,
< 2009-03-11 08:54:58.521 40,64,72,77,78,72,77,2D,72,77,2D,20,20,20,31,20,75,73,65,72,20,20,20,20,20,
< 2009-03-11 08:54:58.521 67,72,6F,75,70,20,20,20,20,20,20,20,20,20,20,20,30,20,4D,61,72,20,31,30,20,
< 2009-03-11 08:54:58.521 31,37,3A,32,32,20,44,42,46,61,69,6C,75,72,65,00,00,00,0C,00,00,41,F6,49,B6,
< 2009-03-11 08:54:58.521 A1,C7,49,B6,A1,C7,00,00,00,05,45,72,72,6F,72,00,00,00,3C,64,72,77,78,72,77,
< 2009-03-11 08:54:58.521 2D,72,77,2D,20,20,20,31,20,75,73,65,72,20,20,20,20,20,67,72,6F,75,70,20,20,
< 2009-03-11 08:54:58.521 20,20,20,20,20,20,20,20,20,30,20,4D,61,72,20,31,30,20,31,37,3A,32,32,20,45,
< 2009-03-11 08:54:58.521 72,72,6F,72,00,00,00,0C,00,00,41,F6,49,B6,A1,C8,49,B6,A1,C8,00,00,00,07,52,
< 2009-03-11 08:54:58.521 65,71,75,65,73,74,00,00,00,3E,64,72,77,78,72,77,2D,72,77,2D,20,20,20,31,20,
< 2009-03-11 08:54:58.521 75,73,65,72,20,20,20,20,20,67,72,6F,75,70,20,20,20,20,20,20,20,20,20,20,20,
< 2009-03-11 08:54:58.521 30,20,4D,61,72,20,31,30,20,31,37,3A,32,32,20,52,65,71,75,65,73,74,00,00,00,
< 2009-03-11 08:54:58.521 0C,00,00,41,F6,49,B6,A1,C3,49,B6,A1,C3,00,00,00,08,52,65,73,70,6F,6E,73,65,
< 2009-03-11 08:54:58.521 00,00,00,3F,64,72,77,78,72,77,2D,72,77,2D,20,20,20,31,20,75,73,65,72,20,20,
< 2009-03-11 08:54:58.521 20,20,20,67,72,6F,75,70,20,20,20,20,20,20,20,20,20,20,20,30,20,4D,61,72,20,
< 2009-03-11 08:54:58.521 31,30,20,31,37,3A,32,32,20,52,65,73,70,6F,6E,73,65,00,00,00,0C,00,00,41,F6,
< 2009-03-11 08:54:58.521 49,B6,A1,C7,49,B6,A1,C7,
> 2009-03-11 08:54:58.521 Type: SSH_FXP_READDIR, Size: 10, Number: 12044
> 2009-03-11 08:54:58.521 0C,00,00,2F,0C,00,00,00,01,31,
. 2009-03-11 08:54:58.521 Sent 14 bytes
. 2009-03-11 08:54:58.521 There are 0 bytes remaining in the send buffer
. 2009-03-11 08:54:58.521 Looking for network events
. 2009-03-11 08:54:58.521 Timeout waiting for network events
. 2009-03-11 08:54:58.521 Read file 'X' from listing
. 2009-03-11 08:54:58.521 Waiting for another 4 bytes
. 2009-03-11 08:54:58.521 Looking for incoming data
. 2009-03-11 08:54:58.787 Detected network event
. 2009-03-11 08:54:58.787 Enumerating network events for socket 896
. 2009-03-11 08:54:58.787 Enumerated 1 network events making 1 cumulative events for socket 896
. 2009-03-11 08:54:58.787 Handling network read event on socket 896 with error 0
. 2009-03-11 08:54:58.787 Received 26 bytes (0)
. 2009-03-11 08:54:58.787 Read 4 bytes (22 pending)
. 2009-03-11 08:54:58.787 Read 22 bytes (0 pending)
< 2009-03-11 08:54:58.787 Type: SSH_FXP_STATUS, Size: 22, Number: 12044
< 2009-03-11 08:54:58.787 65,00,00,2F,0C,00,00,00,01,00,00,00,03,65,6F,66,00,00,00,02,65,6E,
< 2009-03-11 08:54:58.787 Status/error code: 1
> 2009-03-11 08:54:58.787 Type: SSH_FXP_CLOSE, Size: 10, Number: 12292
> 2009-03-11 08:54:58.787 04,00,00,30,04,00,00,00,01,31,
. 2009-03-11 08:54:58.787 Sent 14 bytes
. 2009-03-11 08:54:58.787 There are 0 bytes remaining in the send buffer
. 2009-03-11 08:54:58.787 Looking for network events
. 2009-03-11 08:54:58.787 Timeout waiting for network events
. 2009-03-11 08:54:58.803 Session upkeep
. 2009-03-11 08:54:58.803 Looking for network events
. 2009-03-11 08:54:58.803 Timeout waiting for network events
. 2009-03-11 08:54:59.287 Session upkeep
. 2009-03-11 08:54:59.287 Looking for network events
. 2009-03-11 08:54:59.287 Detected network event
. 2009-03-11 08:54:59.287 Enumerating network events for socket 896
. 2009-03-11 08:54:59.287 Enumerated 1 network events making 1 cumulative events for socket 896
. 2009-03-11 08:54:59.287 Handling network read event on socket 896 with error 0
. 2009-03-11 08:54:59.287 Received 25 bytes (0)
. 2009-03-11 08:54:59.787 Session upkeep
. 2009-03-11 08:54:59.787 Looking for network events
. 2009-03-11 08:54:59.787 Timeout waiting for network events
. 2009-03-11 08:55:00.287 Session upkeep
. 2009-03-11 08:55:00.287 Looking for network events
. 2009-03-11 08:55:00.287 Timeout waiting for network events
. 2009-03-11 08:55:00.506 Cached directory change via "X" to "X".
. 2009-03-11 08:55:00.506 Getting current directory name.
. 2009-03-11 08:55:00.506 Listing directory "X".
> 2009-03-11 08:55:00.506 Type: SSH_FXP_OPENDIR, Size: 74, Number: 12555
> 2009-03-11 08:55:00.506 0B,00,00,31,0B,00,00,00,41,2F,49,6E,65,74,70,75,62,2F,41,70,70,6C,69,63,61,
> 2009-03-11 08:55:00.506 74,69,6F,6E,20,4C,6F,67,20,46,69,6C,65,73,2F,49,4D,53,54,48,41,53,30,36,2F,
> 2009-03-11 08:55:00.506 4F,72,64,65,72,69,6E,67,2F,53,61,6E,67,65,72,73,2F,52,65,71,75,65,73,74,
. 2009-03-11 08:55:00.506 Sent 78 bytes
. 2009-03-11 08:55:00.506 There are 0 bytes remaining in the send buffer
. 2009-03-11 08:55:00.506 Looking for network events
. 2009-03-11 08:55:00.506 Timeout waiting for network events
. 2009-03-11 08:55:00.506 Read 4 bytes (21 pending)
. 2009-03-11 08:55:00.506 Read 21 bytes (0 pending)
< 2009-03-11 08:55:00.506 Type: SSH_FXP_STATUS, Size: 21, Number: 12292
< 2009-03-11 08:55:00.506 65,00,00,30,04,00,00,00,00,00,00,00,02,4F,6B,00,00,00,02,65,6E,
. 2009-03-11 08:55:00.506 Discarding reserved response
. 2009-03-11 08:55:00.506 Waiting for another 4 bytes
. 2009-03-11 08:55:00.506 Looking for incoming data
. 2009-03-11 08:55:00.787 Detected network event
. 2009-03-11 08:55:00.787 Enumerating network events for socket 896
. 2009-03-11 08:55:00.787 Enumerated 1 network events making 1 cumulative events for socket 896
. 2009-03-11 08:55:00.787 Handling network read event on socket 896 with error 0
. 2009-03-11 08:55:00.787 Received 14 bytes (0)
. 2009-03-11 08:55:00.787 Read 4 bytes (10 pending)
. 2009-03-11 08:55:00.787 Read 10 bytes (0 pending)
< 2009-03-11 08:55:00.787 Type: SSH_FXP_HANDLE, Size: 10, Number: 12555
< 2009-03-11 08:55:00.787 66,00,00,31,0B,00,00,00,01,31,
> 2009-03-11 08:55:00.787 Type: SSH_FXP_READDIR, Size: 10, Number: 12812
> 2009-03-11 08:55:00.787 0C,00,00,32,0C,00,00,00,01,31,
. 2009-03-11 08:55:00.787 Sent 14 bytes
. 2009-03-11 08:55:00.787 There are 0 bytes remaining in the send buffer
. 2009-03-11 08:55:00.787 Looking for network events
. 2009-03-11 08:55:00.787 Timeout waiting for network events
. 2009-03-11 08:55:00.787 Waiting for another 4 bytes
. 2009-03-11 08:55:00.787 Looking for incoming data
. 2009-03-11 08:55:01.037 Detected network event
. 2009-03-11 08:55:01.037 Enumerating network events for socket 896
. 2009-03-11 08:55:01.037 Enumerated 1 network events making 1 cumulative events for socket 896
. 2009-03-11 08:55:01.037 Handling network read event on socket 896 with error 0
. 2009-03-11 08:55:01.037 Waiting for another 4 bytes
. 2009-03-11 08:55:01.037 Looking for incoming data
. 2009-03-11 08:55:01.037 Looking for network events
. 2009-03-11 08:55:01.053 Detected network event
. 2009-03-11 08:55:01.053 Enumerating network events for socket 896
. 2009-03-11 08:55:01.053 Enumerated 1 network events making 1 cumulative events for socket 896
. 2009-03-11 08:55:01.053 Handling network read event on socket 896 with error 0
. 2009-03-11 08:55:01.053 Waiting for another 4 bytes
. 2009-03-11 08:55:01.053 Looking for incoming data
. 2009-03-11 08:55:01.053 Looking for network events
. 2009-03-11 08:55:01.068 Detected network event
. 2009-03-11 08:55:01.068 Enumerating network events for socket 896
. 2009-03-11 08:55:01.068 Enumerated 1 network events making 1 cumulative events for socket 896
. 2009-03-11 08:55:01.068 Handling network read event on socket 896 with error 0
. 2009-03-11 08:55:01.068 Waiting for another 4 bytes
. 2009-03-11 08:55:01.068 Looking for incoming data
. 2009-03-11 08:55:01.068 Looking for network events
. 2009-03-11 08:55:01.084 Detected network event
. 2009-03-11 08:55:01.084 Enumerating network events for socket 896
. 2009-03-11 08:55:01.084 Enumerated 1 network events making 1 cumulative events for socket 896
. 2009-03-11 08:55:01.084 Handling network read event on socket 896 with error 0
. 2009-03-11 08:55:01.084 Waiting for another 4 bytes
. 2009-03-11 08:55:01.084 Looking for incoming data
. 2009-03-11 08:55:01.084 Looking for network events
. 2009-03-11 08:55:01.099 Detected network event
. 2009-03-11 08:55:01.099 Enumerating network events for socket 896
. 2009-03-11 08:55:01.099 Enumerated 1 network events making 1 cumulative events for socket 896
. 2009-03-11 08:55:01.099 Handling network read event on socket 896 with error 0
. 2009-03-11 08:55:01.099 Waiting for another 4 bytes
. 2009-03-11 08:55:01.099 Looking for incoming data
. 2009-03-11 08:55:01.099 Looking for network events
. 2009-03-11 08:55:01.115 Detected network event
. 2009-03-11 08:55:01.115 Enumerating network events for socket 896
. 2009-03-11 08:55:01.115 Enumerated 1 network events making 1 cumulative events for socket 896
. 2009-03-11 08:55:01.115 Handling network read event on socket 896 with error 0
. 2009-03-11 08:55:01.115 Waiting for another 4 bytes
. 2009-03-11 08:55:01.115 Looking for incoming data
. 2009-03-11 08:55:01.115 Looking for network events
. 2009-03-11 08:55:01.131 Detected network event
. 2009-03-11 08:55:01.131 Enumerating network events for socket 896
. 2009-03-11 08:55:01.131 Enumerated 1 network events making 1 cumulative events for socket 896
. 2009-03-11 08:55:01.131 Handling network read event on socket 896 with error 0
. 2009-03-11 08:55:01.131 Waiting for another 4 bytes
. 2009-03-11 08:55:01.131 Looking for incoming data
. 2009-03-11 08:55:01.131 Looking for network events
. 2009-03-11 08:55:01.146 Detected network event
. 2009-03-11 08:55:01.146 Enumerating network events for socket 896
. 2009-03-11 08:55:01.146 Enumerated 1 network events making 1 cumulative events for socket 896
. 2009-03-11 08:55:01.146 Handling network read event on socket 896 with error 0
. 2009-03-11 08:55:01.146 Waiting for another 4 bytes
. 2009-03-11 08:55:01.146 Looking for incoming data
. 2009-03-11 08:55:01.146 Looking for network events
. 2009-03-11 08:55:01.287 Detected network event
. 2009-03-11 08:55:01.287 Enumerating network events for socket 896
. 2009-03-11 08:55:01.287 Enumerated 1 network events making 1 cumulative events for socket 896
. 2009-03-11 08:55:01.287 Handling network read event on socket 896 with error 0
. 2009-03-11 08:55:01.287 Waiting for another 4 bytes
. 2009-03-11 08:55:01.287 Looking for incoming data
. 2009-03-11 08:55:01.287 Looking for network events
. 2009-03-11 08:55:01.303 Detected network event
. 2009-03-11 08:55:01.303 Enumerating network events for socket 896
. 2009-03-11 08:55:01.303 Enumerated 1 network events making 1 cumulative events for socket 896
. 2009-03-11 08:55:01.303 Handling network read event on socket 896 with error 0
. 2009-03-11 08:55:01.303 Waiting for another 4 bytes
. 2009-03-11 08:55:01.303 Looking for incoming data
. 2009-03-11 08:55:01.303 Looking for network events
. 2009-03-11 08:55:01.584 Detected network event
. 2009-03-11 08:55:01.584 Enumerating network events for socket 896
. 2009-03-11 08:55:01.584 Enumerated 1 network events making 1 cumulative events for socket 896
. 2009-03-11 08:55:01.584 Handling network read event on socket 896 with error 0
. 2009-03-11 08:55:01.584 Waiting for another 4 bytes
. 2009-03-11 08:55:01.584 Looking for incoming data
. 2009-03-11 08:55:01.584 Looking for network events
. 2009-03-11 08:55:01.584 Selecting events 0 for socket 896
. 2009-03-11 08:55:01.584 No valid incoming packet found
* 2009-03-11 08:55:01.599 (ESshFatal) No valid incoming packet found
* 2009-03-11 08:55:01.599 Error listing directory 'X'.
* 2009-03-11 08:55:01.599 Error changing directory to 'X'.
Thank you
Thanks for your post. This issue is being tracked already.
WhiteKnight
Thank you for your quick response. Sorry I tried to search the tracker list, before I posted but missed it.
