Topic "Automatically reconnect on lost connection"
Max
WinSCP have option "Automatically reconnect session, if it breaks during transfer".
Can you add same option on "Lost connection"?
What should it do exactly?
Max
Reconnect after N seconds
Oh, that I have missed for a long time.
I thought that "Automatically reconnect session, if it breaks during transfer" was the thing,
But I run into problem that winscp is expecting logon credentials in my case after a "lost connection" (Router restart or something (my isp isn't that stable)
So please, we need this!
Thanks in beforehand
//Blaj
WinSCP should restart the connection when it breaks during a transfer for whatever reason. So it does not for you, right? Can you post a log file showing that? Of course, supposing you are using the latest version...
Max
Winscp can't automatically reconect with messages with title "Lost connection":
Timeout detected.
Timeout detected.
Restarting at 0. Send STORE or RETRIEVE to initiate transfer
Timeout detected.
Timeout detected.
Connection failed.
Timeout detected.
Type set to A
Timeout detected.
Type set to I
Disconnected from server
Timeout detected.
Type set to A
Plus sometimes output message:
error listing directory '/dir_name'
Invalid access to memory
With 2 buttons: "Ok" and "Help"
Max
2Martin:
You already have my few logs with "Not Responding" and "Internal error" problems Wink
